starting line controller? #297563
04/23/09 04:21 PM
04/23/09 04:21 PM
South Dakota
dakotahotrodder Offline OP
South Dakota
Educate me please on advantages over say a 2 step, and who uses what. I run super pro with an RTD7, 2 step and t-brake, shift myself for now. Thanks
Re: starting line controller? [Re: dakotahotrodder] #297564
04/23/09 05:34 PM
04/23/09 05:34 PM
Central Oregon
Rodney Offline
Rodney  Offline
Central Oregon
Digital delay box
trans brake set at 4700 rpm
throttle line enhancer opens .8 before the brake
air shifter
leaving in the top bulb
reason:
consistency.
Re: starting line controller? [Re: Rodney] #297565
04/23/09 09:11 PM
04/23/09 09:11 PM
South Dakota
South Dakota
What components are you using, brand & such? Thanks
Re: starting line controller? [Re: dakotahotrodder] #297566
04/23/09 09:20 PM
04/23/09 09:20 PM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
are you talking about SLE? If so I use K&R Prostage and Mega450 that also works as downtrack throttle stop on my doorcar.
On my dragster I have a K&R Procube and single air cylinder that works as SLE only, both cars are controlled by the delay box.
Once you use one you will never want to go back.
The big advantage is if you are the faster car you will go on the launch rpm chip the same amount of time EVERY run.
