23spline & 18 spline tailshaft same? #297086
04/22/09 11:21 PM
04/22/09 11:21 PM
Lexington,VA
68gtxsurvivor Offline OP
Lexington,VA
I am wanting to change the tailshaft on my 69 or back hemi 4 speed to a 70 or up dual pad tail shaft and have plenty of 23 splines, are the tailshafts the same?
Re: 23spline & 18 spline tailshaft same? [Re: 68gtxsurvivor] #297087
04/22/09 11:40 PM
04/22/09 11:40 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
The tail shafts are slightly different. The hemi box uses a bigger rear bearing on the tailshaft. I am pretty sure you can just use the smaller bearing and the 23 splined tail shaft and shaft and be ok. I think I have done that before. It has been a while since I have been into one of those and I don't really do that many of them.
Re: 23spline & 18 spline tailshaft same? [Re: 68gtxsurvivor] #297088
04/23/09 12:21 AM
04/23/09 12:21 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I don't think the tailshaft bearing is different between the two, only the input bearing. Why not go to the Passon or Brewer website and see what you can find ?
Re: 23spline & 18 spline tailshaft same? [Re: 68gtxsurvivor] #297089
04/23/09 12:31 AM
04/23/09 12:31 AM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
66-7 18 spline will be a 307 brg
68-9 18 spline will be a 308, same as the C99539 70-Up B/E tailhousing
A833 4-speeds, parts & services
http://www.brewersperformance.com/
Re: 23spline & 18 spline tailshaft same? [Re: fastmark] #297090
04/23/09 12:32 AM
04/23/09 12:32 AM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
The 18 spline box uses the 308 (large bearing) instead of the smaller 307 bearing. The snap ring also retains on the bearing with the 18 spline tail instead of on the extension housing.
You can use either extension housing as long as you use the appropriate bearing. The output shafts are the same.
I redid my 23 spline box with 18 spline guts and used the 23 spline output shaft, extension housing and bearing.
Re: 23spline & 18 spline tailshaft same? [Re: torkrules] #297091
04/23/09 08:40 AM
04/23/09 08:40 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Someone gave the correct answer above , big block applications of the 23 spline with the B/E tailhousing use the 308 bearings both front and rear , the OP says he has a bunch of 70 up b/e to chose from so he can probably find the tail he needs. OR you can just switch to the 307 bearing if you don't have the right tailhousing , trans will be fine for as little as these cars are used now .
