Re: Painting question
[Re: 6PAX]
#2965726
09/20/21 12:40 PM
09/20/21 12:40 PM
Posts: 1,061 Atlanta, GA
mgoblue9798
Atlanta, GA
If you are looking to fill and block out low spots you want to use a 2k high build primer. If I was going all out for a perfect job, I would media blast strip to bare metal, hammer and dolly as needed, shoot with epoxy primer, scuff and fill any low spots with filler, shoot with 2k high build, block as needed, shot with sealer scuff and then finally paint.
[Re: mgoblue9798]
#2967571
09/26/21 05:31 PM
09/26/21 05:31 PM
Posts: 1,274 Albany, New York
66Plymouth440Six
Albany, New York
If you are looking to fill and block out low spots you want to use a 2k high build primer. If I was going all out for a perfect job, I would media blast strip to bare metal, hammer and dolly as needed, shoot with epoxy primer, scuff and fill any low spots with filler, shoot with 2k high build, block as needed, shot with sealer scuff and then finally paint. The step you list right before paint - "sealer scuff" - What is that? I was interested in this as well as I'll be re-shooting a tailgate this winter. I've heard two different things regards to filler. One said to apply the filler over bare metal and the other said to apply over primer. Thoughts?
