Page 4 of 7 1 2 3 4 5 6 7
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: 70B5Cuda] #2947619
07/26/21 11:46 PM
07/26/21 11:46 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
The quarter panel caps didn't fit very well, so the quarters were massaged to get a better fit.
1970 Barracuda B5 6.1 Hemi/6 speed
1969 Charger survivor in R6 383/727-wrecked 12/24/18
1968 Charger in original burgundy paint "Ribeye"
1968 Charger w/ 6.1L, TR-6060, 9"
1968 Roadrunner w/ 6.1L/6 speed
2011 Dodge Ram w/ 6.7L
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: 70B5Cuda] #2949279
08/01/21 12:04 AM
08/01/21 12:04 AM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
The decklid lip had some rust bubbles so a patch was made...
Trunk floor braces were welded in
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: 70B5Cuda] #2949805
08/02/21 08:26 PM
08/02/21 08:26 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
I bought a new AMD rear bumper for this car....I've been a bit disappointed in it. The yellow tape to show you the profile of the edge, which wanders. It will be powdercoated satin black anyway, so the edge was shaved so it would be straight/parallel with the taillight panel. Compare the gaps between the bumper and taillight panel and you will see the difference
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: 70B5Cuda] #2950034
08/03/21 02:45 PM
08/03/21 02:45 PM
mopar4don Offline
mopar4don  Offline
Do you have any more pics showing how you got the end caps to fit?
Did you slice the quarters?
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: mopar4don] #2950756
08/05/21 04:17 PM
08/05/21 04:17 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
No slicing. Slowly heated up the metal and manipulated/tapped from the backside. Be sure to frequently check the cap fitment as you go
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: 70B5Cuda] #2951650
08/08/21 12:39 PM
08/08/21 12:39 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Since the wheel tubs were widened and the trunk lid supports were moved, it took a bit of work to align the decklid.
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: 70B5Cuda] #2953025
08/11/21 11:09 PM
08/11/21 11:09 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
This one is a little out of sequence....The dutchman's panel took some real work to make it fit right...
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: 70B5Cuda] #2953580
08/13/21 09:34 PM
08/13/21 09:34 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Cowl vent....deleted.
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: 70B5Cuda] #2954022
08/15/21 02:25 PM
08/15/21 02:25 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
There are always surprise rust areas on any old mopar and this one is no different. The cowl looked rock solid until paint was stripped and some lead was melted out of the cowl to pillar joint. so do yourself a favor and always melt the old lead out of a project. Here is the repair.
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: 70B5Cuda] #2954825
08/17/21 07:22 PM
08/17/21 07:22 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Driver's side fender is aligned and pinned (on top and bottom) so it will be super easy to align if removed and reinstalled.
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: 70B5Cuda] #2956446
08/22/21 11:39 PM
08/22/21 11:39 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Right fender has been fitted/gapped. It's also pinned for consistency/minimal effort when removing and reinstalling.
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: 70B5Cuda] #2960787
09/03/21 09:15 PM
09/03/21 09:15 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
My straightest front bumper had been painted flat black at some point...and it has some rash on one end.
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: 70B5Cuda] #2960789
09/03/21 09:25 PM
09/03/21 09:25 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: 70B5Cuda] #2963227
09/12/21 12:54 PM
09/12/21 12:54 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
The bumper took some tweaking but now the bumper fits well
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: 70B5Cuda] #2963230
09/12/21 12:59 PM
09/12/21 12:59 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Since the lower radiator support was boxed in, the lower valance needed some attachment brackets fabbed up
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: 70B5Cuda] #2965378
09/18/21 09:55 PM
09/18/21 09:55 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
The hood had several layers of paint to remove. There were some dents under the layers. The hood must have been slammed hard against the adjusters several times because the hood was dented in several areas.
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: 70B5Cuda] #2965379
09/18/21 10:01 PM
09/18/21 10:01 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
In primer, stripped, media blasted, epoxied
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: 70B5Cuda] #2965380
09/18/21 10:03 PM
09/18/21 10:03 PM
USA
hudsonhornet7x Offline
USA
Looks good! I may have missed it, but what brand of epoxy do you use?
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: hudsonhornet7x] #2965490
09/19/21 02:18 PM
09/19/21 02:18 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
The hood was just epoxied with Nason...nothing fancy
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: 70B5Cuda] #2965858
09/20/21 08:59 PM
09/20/21 08:59 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
1. Original condition
2. Undercoat taken off with needle scaler
3. media blasted
4. trimmed, epoxied, and installed
