Re: Removing (DODGE BALLS) spray paint from my truck [Re: SattyNoCar] #2958219
08/28/21 08:43 AM
08/28/21 08:43 AM
RWG75
RWG75
Originally Posted by Satilite73
My recommendation? Go find some mud and have fun. This method also works great to hide rust and mismatched paint. biggrin
When the OP said bought it as a winter beater was kinda thinking the same thing - a thick layer of road salt should cover it. whistling
Re: Removing (DODGE BALLS) spray paint from my truck [Re: poorboy] #2958303
08/28/21 12:14 PM
08/28/21 12:14 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Originally Posted by poorboy
Originally Posted by TJP
Originally Posted by ink
ez off x4
Wow, I would've thought that would eat the paint underneath as well. EZ-Off was pretty nasty stuff years back.
So how do you guys use it as a paint remover ?
Spray it on, wipe off the offending layers and rinse with water ?
I'm assuming you're all referring to spray bomb paint ?
shruggy
I removed old hand painted lettering from an old truck with EZ Off. Spray the E Z Off onto the door lettering, wait a few seconds for the lettering paint to bubble, and wipe it off. Repeat until the lettering is gone, hose off the truck body.
If the lettering was there for a long time, sometimes the paint around the lettering was faded, and after the lettering was removed, you could still see where it was because the surrounding paint was faded. Often a bit of buffing would match up the colors better, but then the entire door (or where the buffing was done) looked better then other parts of the faded paint. Some colors faded worse then other colors. Gene
thanks Gene wink
Re: Removing (DODGE BALLS) spray paint from my truck [Re: hp383] #2958588
08/29/21 09:12 AM
08/29/21 09:12 AM
IMGTX Offline
IMGTX  Offline
I haven't tried EZoff but I will.
When painting cars with factory vinyl tops i Use Goof Off to remove the glue residue and I was very surprised to find it will also remove the 30 year old pain if left on too long.
If easy off doesn't work try goof off.
OR
Maybe add a few words and a couple cherry stems to make the slogan so much more interesting LOL
Re: Removing (DODGE BALLS) spray paint from my truck [Re: IMGTX] #2958964
08/30/21 10:44 AM
08/30/21 10:44 AM
moparx Offline
moparx  Offline
go around and scavenge up all the left over paint you can find from your neighbors and local body shops. then stop into the dollar store and load up on cheapo brushes of all sizes.
call up your local high school art class and invite them over.
you will have a truck that nobody else will ever have after the art class is done. biggrin
beer
Re: Removing (DODGE BALLS) spray paint from my truck [Re: moparx] #2959198
08/30/21 09:22 PM
08/30/21 09:22 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
beer
great Idea wink BTW I have a lot of paint, Mainly spray can but some spray gun type with hardeners etc.
Re: Removing (DODGE BALLS) spray paint from my truck [Re: moparx] #2959233
08/30/21 10:17 PM
08/30/21 10:17 PM
East Bay, N. Cal.
calmopar Offline
calmopar  Offline
East Bay, N. Cal.
beer
You might want to OK the design first...
Trying to enjoy life!
Re: Removing (DODGE BALLS) spray paint from my truck [Re: calmopar] #2959285
08/31/21 02:06 AM
08/31/21 02:06 AM
State of Confusion
hp383 Offline OP
Just a normal tag again
hp383  Offline OP
State of Confusion
I am planning to go with an olive drab paint.
But I had given thought to finding someone that does the tagging on railcars. Some of those paint jobs are very artistic.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: Removing (DODGE BALLS) spray paint from my truck [Re: calmopar] #2959383
08/31/21 10:43 AM
08/31/21 10:43 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
beer
haha
Re: Removing (DODGE BALLS) spray paint from my truck [Re: 6PakBee] #2959684
08/31/21 08:39 PM
08/31/21 08:39 PM
Southern Maryland
klunick Offline
klunick  Offline
Southern Maryland
Originally Posted by 6PakBee
One of my bud's truck was vandalized with black spray bomb. Took it off with aerosol brake cleaner. Finish was BC/CC and the cleaner didn't touch it.
That is what I was thinking also. Heck, it takes paint off when you don't want it to.
67 Barracuda FB 69 Superbee "Southern Maryland: If you want a good looking woman, you had better bring her with you"
Re: Removing (DODGE BALLS) spray paint from my truck [Re: poorboy] #2959751
09/01/21 12:00 AM
09/01/21 12:00 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
This! EZ Off,it works on hand pinstriping also like done at car/motorcycle events.New stuff is not like the old as stated but might be easier on your base paint. EZ off is also good for degreasing the innards of an old engine block with caked on oil. ~RT
shruggy [/quote]
If the lettering was there for a long time, sometimes the paint around the lettering was faded, and after the lettering was removed, you could still see where it was because the surrounding paint was faded. Often a bit of buffing would match up the colors better, but then the entire door (or where the buffing was done) looked better then other parts of the faded paint. Some colors faded worse then other colors. Gene [/quote]
Re: Removing (DODGE BALLS) spray paint from my truck [Re: RTSrunner] #2964408
09/15/21 02:21 PM
09/15/21 02:21 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I'd get some reducer
