1969 Coronet 3 point Emblem #2955678
08/20/21 01:41 PM
08/20/21 01:41 PM
Missouri
3
3_RTs Offline OP
3_RTs  Offline OP
Missouri
Does anyone know what the proper placement is for the 3 point emblem (I can't think of the correct name for this) that is located behind the rear side window of a 69 Coronet?
Here is a picture of what I'm talking about.
Thanks,
Re: 1969 Coronet 3 point Emblem [Re: 3_RTs] #2955692
08/20/21 02:09 PM
08/20/21 02:09 PM
moparx Offline
moparx  Offline
i believe the proper name for that is fratzog.
as to the placement, i'm sorry to say i can't help.
beer
Re: 1969 Coronet 3 point Emblem [Re: moparx] #2955724
08/20/21 03:16 PM
08/20/21 03:16 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
How soon do you need to know? I have a 1969 Coronet with a vinyl top in storage I could take some measurements from next week.
Re: 1969 Coronet 3 point Emblem [Re: 3_RTs] #2955736
08/20/21 03:59 PM
08/20/21 03:59 PM
Midwest
MoparsnMissiles Offline
Midwest
Thanks,
Yes, fratzog is correct. And I do have some measurements for it. A member on a different forum had asked the same thing, so I already had this photo with dimensions set up. This is from my '69 R/T, still has original vinyl top so I don't believe the fratzog has been off the car since the factory. Hope this helps!
Re: 1969 Coronet 3 point Emblem [Re: moparx] #2955762
08/20/21 05:52 PM
08/20/21 05:52 PM
Missouri
3
3_RTs Offline OP
3_RTs  Offline OP
Missouri
Thank you Moparx for the correct name.
Re: 1969 Coronet 3 point Emblem [Re: 6PakBee] #2955763
08/20/21 05:54 PM
08/20/21 05:54 PM
Missouri
3
3_RTs Offline OP
3_RTs  Offline OP
Missouri
Thanks, 6pakbee. If you could do that I would appreciate it.
Re: 1969 Coronet 3 point Emblem [Re: MoparsnMissiles] #2955764
08/20/21 06:02 PM
08/20/21 06:02 PM
Missouri
3
3_RTs Offline OP
3_RTs  Offline OP
Missouri
MoparsnMissiles, I will give your diagram a try tonight, as I am having the top put on tomorrow and I wanted to have the holes already drilled.
Thank You!
Re: 1969 Coronet 3 point Emblem [Re: 3_RTs] #2955765
08/20/21 06:02 PM
08/20/21 06:02 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I can't do any better than MoparsnMissiles photo. I'd say he hit it spot on. shruggy
