Re: 2007 Diesel Fuel [Re: finn] #29451
09/03/06 09:28 AM
09/03/06 09:28 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
YYou would think a chicken fat refinery would be in "Tysonsaw" I mean Arkansas!!
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: 2007 Diesel Fuel [Re: WayneM] #29452
09/03/06 02:41 PM
09/03/06 02:41 PM
Hey Warlock, do you know the exact level of sulphur thats going into ULSD? I know the end result is to be 15PPM, but I read in a trade magazine that, because of the residue in the pipeline, the refined product has more like 5PPM at the refinery-it is true?
Wayne I do not know for sure since I do not work in ourcude unit but have heard 8ppm.. I will ask tonight when I get to work and hopefully have you an answer in the AM..
Re: 2007 Diesel Fuel [Re: hemi70] #29453
09/03/06 08:54 PM
09/03/06 08:54 PM
Wooster, Ohio
K
kpzbee Offline
kpzbee  Offline
K
Wooster, Ohio
I was recently told that the primary reason that the ULSD fuel is required for most of the '07 vehicals is that their exhaust system is equipped with a "particulate" trap to limit the amount of soot and any other debris they emit.
The LSD fuel has more sulfur than the trap can handle over extended use.
Trap can clog and cause restriction.
The '07 5.9 CTD is one exception to the rule (no trap) so LSD is O.K.
The 6.7 cummins and the 3.0 engine that will be in the Grand Cherokee (early '07) have the trap.
Gary.
That's true but starting in Jan '07, you'll see the 6.7 in the Rams. These engines have a very elaborite regeneration system in the exhaust system, that runs every 10 hrs of engine operation. When it runs, it cleans the trap out & reburns the soot. It sounds weird when it running in the regen mode but still drives fine.
"It's funny how one project eventually leads (or forces) you into another one.
It's really just one endless project designed to induce insanity and bankruptcy."
Re: 2007 Diesel Fuel [Re: WayneM] #29454
09/04/06 07:05 AM
09/04/06 07:05 AM
Wayne It leaves out plant 7.4ppm maximum but most of it is around 4
Re: 2007 Diesel Fuel #29455
09/04/06 08:43 PM
09/04/06 08:43 PM
Alexandria, NJ
WayneM Offline
WayneM  Offline
Alexandria, NJ
Very interesting, Warlock. Thanks. I wonder if they'll raise it as the pipeline settles?
I did a fuel sample/ drain yesterday, checking for water and the fuel still has that yellow/blueish sheen in daylight. Didn't see any water.
2014 Durango R/T
2004 Dodge Ram 3500 SRW SLT short quad Cummins 6 speed
1998 Dodge Durango SLT 5.2
1971 Plymouth Duster-
<<<<<MOPAR SPOKEN HERE>>>>>
