Zero energy '79 Power Wagon
#2940152
07/05/21 01:43 PM
07/05/21 01:43 PM
Posts: 15,871 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
it's like there's no battery in truck. No power whatsoever; no headlights nothing; dead; First thing I checked was battery. Full charge. Checked battery connections and cleaned them to be sure. Not even sure if this could be problem but I removed all bulkhead connections and cleaned thoroughly (they didn't look bad...did this a short time ago). Seeing that the pos battery cable goes directly to starter relay, I replaced that with new one after cleaning all contacts. I inspected all the wires running along the inner fender along battery side and all look fine. Neg battery cable looks fine and grounded tightly. Only thing I did recently was pull dash out a little to remove speedo cable as I am replacing that. My amp gauge is already bypassed with a brass bolt through both connections from gauge and taped off with electrical tape (did that about a year ago) and it's still very tight and unmolested. I looked at fuse box and don't see a fuse that would have caused this and didn't see any that appear blown. Lastly, I got under truck and followed speedo cable routing to see if it's path is same as something else that I might have disturbed. Looks like maybe it shares a crossing with the Neutral Safety Switch wire but that appeared fine and this wouldn't cause a zero energy situation anyway. I'm lost as to what's my next step. Is there a fuse relay somewhere? I had the same situation on my Diplomat and it was a fuse relay on inner fender but I don't see one on this truck. Thanks! Larry
Facts are stubborn things.
Re: Zero energy '79 Power Wagon
[Re: larrymopar360]
#2940158
07/05/21 02:00 PM
07/05/21 02:00 PM
moparpollack
Lil Herman
Lil Herman
85086
Check the fuseable link usually attached to the starter relay.
[Re: moparpollack]
#2940161
07/05/21 02:05 PM
07/05/21 02:05 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Check the fuseable link usually attached to the starter relay. How do you test or tell if that is bad? I don't see anything from the relay to battery with actual fuse inside. I'll get a pic. Thanks.
[Re: larrymopar360]
#2940166
07/05/21 02:24 PM
07/05/21 02:24 PM
moparpollack
Lil Herman
Lil Herman
85086
Looks like the blue wire that feeds the red wires. I was trying to find a replacement picture for reference.
[Re: moparpollack]
#2940167
07/05/21 02:31 PM
07/05/21 02:31 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
The wire I circled in purple? That's the closest I see to blue one.
[Re: larrymopar360]
#2940170
07/05/21 02:38 PM
07/05/21 02:38 PM
moparpollack
Lil Herman
Lil Herman
85086
yes, the orange circled wire, trace it to see if it is connected.
[Re: larrymopar360]
#2940173
07/05/21 02:53 PM
07/05/21 02:53 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Black wire from relay splits to to reds. One red to bulkhead other to the white connector I already posted so I think you're onto something even though It all seems to be connected.
[Re: larrymopar360]
#2940174
07/05/21 02:56 PM
07/05/21 02:56 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Hoping you can see. Starter relay is new and I cleaned the black wire well. Cleaned bulkhead connections too.
[Re: larrymopar360]
#2940177
07/05/21 03:03 PM
07/05/21 03:03 PM
moparpollack
Lil Herman
Lil Herman
85086
The one that goes into the bulkhead usually feeds the starter switch to powers the truck. Take a test light and see if you have power to the black feeder wire to check for power. See if the bulkhead wire has signs of heat damage.
[Re: larrymopar360]
#2940184
07/05/21 03:15 PM
07/05/21 03:15 PM
Posts: 8,668 Buford, GA
I_bleed_MOPAR
Buford, GA
Grab the red wires and pull. If the link is burned out, the black wire will stretch.
Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
[Re: I_bleed_MOPAR]
#2940185
07/05/21 03:22 PM
07/05/21 03:22 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Tim ok I'll try that
[Re: I_bleed_MOPAR]
#2940186
07/05/21 03:22 PM
07/05/21 03:22 PM
moparpollack
Lil Herman
Lil Herman
85086
Tim
[Re: stumpy]
#2940220
07/05/21 05:28 PM
07/05/21 05:28 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Thanks guys. You had me following the wires from the fusible link so being that the one red ones goes into bulkhead I decided to pull the gauge pod out entirely instead of just the ittle bit I did to check where I had bypassed the amp gauge. Once I did that I could see the red wire to the amp gauge had melted some prior to the amp gauge connector. There was an existing connection there but I have no idea whether it was factory or someone else had done but I remember giving it some electrical tape while I was there anyway doing the amp gauge bypass. When I wiggled it the key on buzzer started when I let go buzzer off. So that’s where the problem is there is some bare wire showing and it obviously had done a little bit of melting. Again I don’t know what this is and what would cause us to melt. I did add a 150 power master alternator about a year or so ago. This would not have caused that to happen with it? Here’s the problem junction in red wire. Just after is my wrapped amp gauge bypass and it looks fine still. I circled burn spot in orange. There's bare wire poking out top. Almost looks like there might have been some kind of factory inline fuse or something.
