Re: Hemi running problems
[Re: DoubleD]
#2936403
06/24/21 01:15 PM
06/24/21 01:15 PM
Posts: 18,424 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
By chance did you re-curve your distributer - sounds like you may need some more initial timing on it - that ready to run dizzy has a big curve that usually needs tightened up a little I have it all in by 2,500 rpms. 32 degrees. Not running a vacuum advance. So base and mechanical all in around 2,500.
[Re: moparx]
#2936425
06/24/21 02:09 PM
06/24/21 02:09 PM
NITROUSN
have you checked your distributor for sticking weights or advance plate ? some of the ready to run units i have seen have little to no lube [they don't need much, but a "little dab 'll do ya"] and will sometimes start to rust a tiny bit, causing stickyness. To easy. All good there working as it should.
[Re: NITROUSN]
#2936431
06/24/21 02:38 PM
06/24/21 02:38 PM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
Thanks for all the replies. I have used and like NGK plugs. No nitrous so should I run a projected or non projected tip. A stock motor in the day ran a heat range 4. This is all street with an occasional romp on the throttle. Is heat range 4 to hot? I've always run NGK R5671A-8 (4554) plugs in my pump gas hemi when running it naturally aspirated. I would think an R5671A-7 (4091) would be fine for yours.
[Re: B1MAXX]
#2936490
06/24/21 06:08 PM
06/24/21 06:08 PM
NITROUSN
If its pump gas I have seen certain blends try and vapor/boil when driving causing almost flooding type conditions. Seems to happen with winter blend pump gas. You could be on to something there. I was charging the a/c and going over the basic adjustments when I noticed steam like smoke coming out of the bowl vent. I thought that was very odd. It also seems the hotter it gets or the longer I run it the worse it seems. I filled this tank when I calibrated the fuel gauge end of March first week of April. I have run about half of it out. I may just drain the rest for the mower and fill with new premium. Exactly what first caught my eye on the one time I came across this also. I forget what we put in it, it was either 100 unleaded race gas or bp premium...been a while but it fixed it. It was actually causing the carb to flood, was like the needle and seat couldn't deal with the vapor. I drained the tank and kept samples. Old fuel like a light whisky color. New fuel clear like moonshine. Raining so no test drive. I did start it and maybe it is in my head but it seems to feel and sound better. I do not think it will cure everything but I wont know till I drive it. After that it will be plugs.
[Re: NITROUSN]
#2936614
06/25/21 07:50 AM
06/25/21 07:50 AM
Posts: 1,995 Apollo, PA.
B1MAXX
Apollo, PA.
If its pump gas I have seen certain blends try and vapor/boil when driving causing almost flooding type conditions. Seems to happen with winter blend pump gas. You could be on to something there. I was charging the a/c and going over the basic adjustments when I noticed steam like smoke coming out of the bowl vent. I thought that was very odd. It also seems the hotter it gets or the longer I run it the worse it seems. I filled this tank when I calibrated the fuel gauge end of March first week of April. I have run about half of it out. I may just drain the rest for the mower and fill with new premium. Exactly what first caught my eye on the one time I came across this also. I forget what we put in it, it was either 100 unleaded race gas or bp premium...been a while but it fixed it. It was actually causing the carb to flood, was like the needle and seat couldn't deal with the vapor. I drained the tank and kept samples. Old fuel like a light whisky color. New fuel clear like moonshine. Raining so no test drive. I did start it and maybe it is in my head but it seems to feel and sound better. I do not think it will cure everything but I wont know till I drive it. After that it will be plugs. What did you replace it with, same stuff just fresh/summer blend? Or did you change brands/types?
[Re: B1MAXX]
#2936754
06/25/21 05:43 PM
06/25/21 05:43 PM
NITROUSN
100 octane I would assume that a seasonal thing? Around here we get 100 but it's only available in the summer. My bad in a hurry. 100 percent ethanol free 91 octane is what I ment to say. Drove car today and it is running a lot better. That gas was junk. At least now I can work on fine tuning it. I think that I need some adjustment. Driving a cammed big inch Hemi with a carb is a lost art. Diesels and EFI behind a stick have better manners. So some will be me adjusting and the small changes I make should be noticeable. The way it was running there was to much wrong at once. Hard to believe that I put 19 gallons of premium junk in it.
[Re: B1MAXX]
#2936891
06/26/21 10:04 AM
06/26/21 10:04 AM
NITROUSN
A long time ago I used to drive my charger to the track and race it, I would always stop at a local station that sold Turbo Blue. It was the same tank as they sold kerosene in the winter. Well I was there early in the year and they must not have cleaned the tank out and I got a lot of ribs in the staging lanes because of the smell from my car, smelled like I was racing an oil furnace. That was my thought also that the color could of been a winter blend like you said or a truck load accidentally mis-blended fuel. I have a friend that drives tanker for Klem and he said it is all pre-determined when he loads. So who knows. This was a first of this for me. We will see if the lawn mowers will run on it. If not to the burn pit in the fall at camp.
[Re: B1MAXX]
#2936962
06/26/21 12:16 PM
06/26/21 12:16 PM
NITROUSN
wonder if because it's kind of a specialty gas that it was old at the time of buying...they probably don't sell much ethanol free over the winter and you got some of last summers batch. This place moves a lot of fuel. Re-looking at my parts receipts I got my fuel sender calibration box around April 10th. So my first buy would of been around then for the low side calibration. And the rest within a day or so for the high end calibration. So who knows. For now I am happy with how it changed the running. As soon as you said like fuel boiling the steam out of the vent became a vivid picture. I have samples in clear glass bottles I will try to get a picture of.
