I have a 10.5" clutch/flywheel in the small block '70 Cuda.
I have what I think must be a 11" clutch flywheel in the '70 383 Super Bee.
If I went with an 18 spline OD gearset from Passon's, I would need at least a new clutch disk (18 v. 23 spline), maybe even a whole new assembly. Would I need a bigger flywheel?
I am assuming the clutch from my Bee will not work in my Cuda as it stands because it is an 11". Am I right?
In the Super Bee, if I decided to go with a Passon's OD unit, could I just swap the Centerforce disk for an 18 spline disk and not have to worry about the rest of the assembly (new)?
It may seem like I am all over the place, but my wheels are turning.
