Front suspension problems and questions #292785
04/19/09 12:54 PM
04/19/09 12:54 PM
SE Washington
Forest Offline OP
Forest  Offline OP
SE Washington
Yesterday was the first time back to the track this year. With the help of others watching; my car wheelies about 3-4'' but doesn’t carry them very long. Then the problem the front end stays up fairly high and both front tires are toe'ed in bad and the bottom of the tires are in bad (-camber?) Both front tires have a fairly bad feather edge on the inside of the tire. So obviously it was doing it last year too, just not as notice able? Only change I made over winter was converted from SS springs to mono leaves and Cal-Tracs.
Is it just and alingment issue?
Re: Front suspension problems and questions [Re: Forest] #292786
04/19/09 01:36 PM
04/19/09 01:36 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
I take mine to a good alignment shop...they are racers and know where it should be..
what needs to be done is the front picked up on the alignment rack to where it would be like going down the track and then the alignment is done..
I forgot what mine was...perhaps someone else will chime in with numbers...
Re: Front suspension problems and questions [Re: Forest] #292787
04/19/09 02:44 PM
04/19/09 02:44 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Sounds like alignment to me.Check the lower control arm bushings as well.
Nautilus Racing-
Re: Front suspension problems and questions [Re: Chris2581] #292788
04/19/09 03:42 PM
04/19/09 03:42 PM
SE Washington
Forest Offline OP
Forest  Offline OP
SE Washington
All the bushings are relatively new.
So it’s safe to say if it’s aligned correctly that the tires shouldn't be toe'ed in so bad going down the track.
I have heard that the Dynamic strut rods CAP sells will help with this problem too? Any opinions?
Re: Front suspension problems and questions [Re: Forest] #292789
04/19/09 11:27 PM
04/19/09 11:27 PM
SE Washington
Forest Offline OP
Forest  Offline OP
SE Washington
Ok so here is a video, can't see much. Any one have any comments?
http://www.youtube.com/watch?v=7VskF4-z_V4
Re: Front suspension problems and questions [Re: Forest] #292790
04/19/09 11:36 PM
04/19/09 11:36 PM
Renton Washington
Triple Threat Offline
Renton Washington
I would have the alignment checked by a good shop that deals with performance/drag cars. on a side note, I went to renegade today with the dart, all was well 'til it blew the tires off at the hit first round, good to hear you had a little better luck than I did.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Front suspension problems and questions [Re: Triple Threat] #292791
04/19/09 11:42 PM
04/19/09 11:42 PM
SE Washington
Forest Offline OP
Forest  Offline OP
SE Washington
Are you going to run points at Renegade, Mopar or Pro?
Re: Front suspension problems and questions [Re: Forest] #292792
04/20/09 12:01 AM
04/20/09 12:01 AM
Renton Washington
Renton Washington
No, I race points over at pacific with the rest of my friends and family. Renegade was one of the only tracks running this weekend and it was relatively convenient so I said why not.
-Dustin
Re: Front suspension problems and questions [Re: Forest] #292793
04/20/09 12:19 AM
04/20/09 12:19 AM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
While you are at the alignment shop and the car is on the rack, have them measure the toe, and then raise the car 1" and measure and record the toe, and keep doing this til the wheels come up off the ground. You are checking for bump steer. If the wheels are toeing in as the chassis rises it sounds like bump steer. The DC manuals explain how to correct it but it's a bit of trial and error, and massaging parts you may not be used to messing with, like heating and bending the lower control arms, shimming the steering box, or moving the idler arm.
BTW, whatever alignment you get, make sure they raise the chassis one inch, and THEN set the alignment. Simulates the chassis rise under acceleration.
