1969 Charger 383 4BBL, 4-Speed 22" or 26" Radiator? #2925277
05/21/21 05:15 PM
05/21/21 05:15 PM
NW New Jersey
RSI700VIPER Offline OP
NW New Jersey
I recently attended a car show and saw a '69 Charger that appeared to be a factor 383 4BBL 4-speed. I didn't measure but it looked like it had a 22 inch radiator. A quick glance at the fender tag and it had E63 (383HP), D21 (4-Speed) but no "26"? The car was built in Hamtramck with a March something SPD. (Sorry no picture). I thought all 383 HP cars w/ 4-speeds came with a 26 inch radiator, no?
1970 Superbird 440 Six BBL, 4-Speed, Dana, FJ5
1969 Daytona Charger 440 4-Speed, Dana, EV2
1971 340 Challenger Conv. Flemington Speedway Pace Car, FC7
1970 340 Six Pack Callenger T/A 4-speed T8 Tan
1971 340 Challenger RT Formal Roof, EV2 w/ V2 Stripe & Orange Houndstooth
1969 Talladega Torino, 428CJ
1969 Gurney Special Cyclone Spoiler II, 351 Cleveland
"Id rather have a bottle in front of me than a frontal lobotomy" Ben Franklin 1755
Re: 1969 Charger 383 4BBL, 4-Speed 22" or 26" Radiator? [Re: RSI700VIPER] #2925278
05/21/21 05:31 PM
05/21/21 05:31 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
22" is correct..my 70 440-6 C body has one also..and get this,.... NO SHROUD....
Re: 1969 Charger 383 4BBL, 4-Speed 22" or 26" Radiator? [Re: ph23vo] #2925284
05/21/21 05:49 PM
05/21/21 05:49 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Probably no axle package.
Ron
Re: 1969 Charger 383 4BBL, 4-Speed 22" or 26" Radiator? [Re: RJS] #2925290
05/21/21 05:56 PM
05/21/21 05:56 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Rounded upper tank = 22"
Squared-off upper tank = 26"
22" std w/o AC or axle pkg.
Re: 1969 Charger 383 4BBL, 4-Speed 22" or 26" Radiator? [Re: topside] #2925317
05/21/21 08:37 PM
05/21/21 08:37 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Had a 68 R/T with a 22" beer
Re: 1969 Charger 383 4BBL, 4-Speed 22" or 26" Radiator? [Re: TJP] #2925353
05/21/21 10:40 PM
05/21/21 10:40 PM
NW New Jersey
NW New Jersey
So, axle package or AC got you a 26" radiator and 22" was standard? Interesting. Most big block B-Bodys I see have the 26" radiator. Could you order a 26" radiator as a separate option?
Re: 1969 Charger 383 4BBL, 4-Speed 22" or 26" Radiator? [Re: RSI700VIPER] #2925354
05/21/21 11:00 PM
05/21/21 11:00 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
NO - trailer towing packages also included the 26" radiator
Re: 1969 Charger 383 4BBL, 4-Speed 22" or 26" Radiator? [Re: 6bblgt] #2925533
05/22/21 02:02 PM
05/22/21 02:02 PM
moparx Offline
moparx  Offline
my charger also came with a 22" radiator, but with a shroud.
i have owned that car since i bought it totaled [hit very HARD in the rear] in 1970. the original radiator had the "fan bites" repaired by a local shop back then, and that repair lasted all these years keeping different combos cool and not leaking a drop.
i pulled it a couple of years ago when i decided to go to a huge aluminum unit and will be using twin electric fans from a late model chrysler 300 with a hemi.
the core was starting to get green and slightly damp around the edges, although the coolant level was still up there.
the last i saw of that was when it was shipped out west to a member here to use the perfect tanks it had with the correct date code for a road runner he was restoring.
beer
Re: 1969 Charger 383 4BBL, 4-Speed 22" or 26" Radiator? [Re: moparx] #2925654
05/22/21 08:48 PM
05/22/21 08:48 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
beer
What amazes me is back then they made 22" radiators that cooled a big block and lasted 30+ years, heater cores as well. Try that with todays cars twocents beer
Re: 1969 Charger 383 4BBL, 4-Speed 22" or 26" Radiator? [Re: RSI700VIPER] #2926519
05/25/21 03:12 PM
05/25/21 03:12 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I don't see max cooling as a separate option so it appears the only way to get a 26" rad is to get a package that requires it.
Re: 1969 Charger 383 4BBL, 4-Speed 22" or 26" Radiator? [Re: JohnRR] #2926542
05/25/21 04:06 PM
05/25/21 04:06 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I always wonder about the '68-'69 B-bodies with fan shrouds on their 22" radiators.
I'm not aware of a separate option for that, but there must be something that would add them but not the 26" radiator ?
I recall that plenty of cars would overheat back in the day - SoCal's "Grapevine" was legendary for that, and in the '50s, many cars traversing a desert had a water-bag on their grilles.
Nowadays, of course, running temps are 30-40 degrees higher than the '60s, but cooling systems have improved.
Re: 1969 Charger 383 4BBL, 4-Speed 22" or 26" Radiator? [Re: topside] #2927080
05/26/21 09:27 PM
05/26/21 09:27 PM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
Here's an original '68 383 4-speed, with a 22" radiator.
http://www.dodgecharger.com/forum/index.php/topic,131348.0/all.html
