Re: need to replace my garage door opener
[Re: Pacnorthcuda]
#2926009
05/23/21 10:34 PM
05/23/21 10:34 PM
Posts: 8,396 Highland, MI.
Sunroofcuda
Highland, MI.
X2. Liftmaster belt drive. If Stu was still with us, he'd say the same. Check Sears - the old 1/2 HP belt drive of theirs used to be made by Liftmaster - said it on the box - that's what I bought. I've had NO issues with mine for 16 years.
[Re: Sunroofcuda]
#2926026
05/24/21 12:37 AM
05/24/21 12:37 AM
Posts: 10,211 Someplace you aren't
SomeCarGuy
Yep those are the winner. Get the nice one with the WiFi. You’ll use that more than you’d think. I miss it after moving to a house without it. New place has an old lift master that’s good, and has a genie that is louder and sounds clunkier than the lift master.
I want my fair share
[Re: mopars4ever]
#2926071
05/24/21 09:13 AM
05/24/21 09:13 AM
Posts: 1,099 Massillon, Ohio
cudatom
Massillon, Ohio
My Genie is 20 plus yrs old. The only thing I've replaced is the travel limiter. Is it noisy yes I don't care. It works flawlessly. Hell when my kids were little the would hang on to the door and use as a lift. Though my head was going to explode the first time I saw it. Learned they had been doing it for yrs after school.
Ok
[Re: cudatom]
#2926099
05/24/21 11:08 AM
05/24/21 11:08 AM
Posts: 1,707 central il.
second 70
central il.
If it's a torsion spring door get a liftmaster 8500. Mounts on end of torsion shaft and gets rid of everything else leaving ceiling clean. Stu loved em. Hard to see but it's the small black box on left on wall behind bike. I have one on the 16ft front garage door too. Comes with a bluetooth light that plugs in where old opener was installed. I have both on same signal so when either door opens or you trip motion detector on wall panel the both come on together. Bright enough to go in and out of garage without turning on any lights. You can see it between the led fixtures.
[Re: cudatom]
#2926103
05/24/21 11:10 AM
05/24/21 11:10 AM
Posts: 667 Los Osos, Ca
CKessel
Los Osos, Ca
I'm using the Liftmaster direct drive/jackshaft, 8500, units with the wifi capability. Nice units that mount on the wall to the side of the door. This free's up the space lost by the usual lift units.
Carl Kessel
[Re: CKessel]
#2926706
05/25/21 11:22 PM
05/25/21 11:22 PM
Posts: 4,148 Canada -- Posts: 4034 -Registe...
5thAve
Im guess you last two guys were writing your replies at the same time. With the same suggestion and reason. Our trusty old Stanley has been doing it's thing on our door since the 80s
[Re: Kern Dog]
#2926787
05/26/21 10:27 AM
05/26/21 10:27 AM
CKessel
Los Osos, Ca
And their tech/help department blows. We tried putting the camera's in but could not get them to synch up. Got the run around from tech plus crickets. Its an ongoing problem with Chamberlin from what I've read online. Sell the product but play dumb after.
Carl Kessel
[Re: SomeCarGuy]
#2926827
05/26/21 11:06 AM
05/26/21 11:06 AM
Posts: 12,800 East Bay, N. Cal.
calmopar
East Bay, N. Cal.
Yep those are the winner. Get the nice one with the WiFi. You’ll use that more than you’d think. I miss it after moving to a house without it. New place has an old lift master that’s good, and has a genie that is louder and sounds clunkier than the lift master. There are 3rd party wifi retrofit kits you can get for $20-30, check Amazon.
Trying to enjoy life!
[Re: second 70]
#2926849
05/26/21 11:33 AM
05/26/21 11:33 AM
Posts: 22,696 Bitopia
jcc
Bitopia
My daughter installed the shaft mounted opener, not sure of the brand. They love it, it's a much cleaner look/installation, she has battery BU since in a hurricane zone, and a number of other features, with a nice robust separate solenoid dead bolt lock. She lives in a rather upscale neighborhood, and the permit inspector had oddly never seen one, but was impressed.
I will use the same on my door upgrade soon.
[Re: CKessel]
#2927772
05/28/21 04:15 PM
05/28/21 04:15 PM
Posts: 75,012 U.S.S.A.
JohnRR
U.S.S.A.
I'm using the Liftmaster direct drive/jackshaft, 8500, units with the wifi capability. Nice units that mount on the wall to the side of the door. This free's up the space lost by the usual lift units. I'm going to switch to an 8500 but have no desire to connect anything that someone could possibly hack into to gain access in to my house.
[Re: mopars4ever]
#3043555
05/19/22 11:51 AM
05/19/22 11:51 AM
Posts: 6 United Kingdom
drenatyn
United Kingdom
Swinging gates must not have a skewed post. The sashes must be level and open easily, without unnecessary effort. It is better if they hang on hinges with bearings. The instructions for the drive usually have a graph of the ratio of the length of the sash to its height. That's why the weight of the leaf is a relative indicator. In addition to the weight of the gate leaf, there is another important parameter: the sail and wind resistance. The higher this parameter, the harder it is for the drive to push the gate leaf, including strong winds. It's important which Garage Doors you choose. Very good if they are wood.
[Re: MI_Custumz]
#3043796
05/20/22 06:28 AM
05/20/22 06:28 AM
Posts: 10,228 Colleyville
3hundred
Colleyville
I have a Liftmaster and added the MyQ to it. We sometimes forget to shut the garage door and closing it from anywhere is a nice option. We've got ours set to auto close at 9:00 PM in case we forget to close it. It's happened a handful of times.
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: mopars4ever]
#3043871
05/20/22 11:48 AM
05/20/22 11:48 AM
Posts: 16,481 On the run…
BloFish
On the run…
I put in a LiftMaster last year and love it.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: Dcuda69]
#3045534
05/27/22 06:17 AM
05/27/22 06:17 AM
drenatyn
United Kingdom
[Re: Dcuda69]
#3045580
05/27/22 10:23 AM
05/27/22 10:23 AM
SomeCarGuy
I put a 2 car garage addition on 20+ years ago. At that time I grabbed a Genie from HD and put it up. Worked fine until this year, then it died. I had the door company that installed the door come out and install a belt drive Liftmaster. Works great and quiet...uses the same MyQ app so wireless, remote function. I don't need battery backup...if I lose power,pull the cord and roll the door up. Think it was $400 completely installed with haul away of the Genie. I got one at my old house and can’t wait to install at this one. These are great. Big power too. Had to get it because I did a complete reworking and changed out two wasted single bay width doors and went to a huge single door that weighed too much for the old openers. The ability to have somebody put packages that arrive into your garage while on vacation is great. Even more so these days to when things ship on huge delays.
[Re: SomeCarGuy]
#3045584
05/27/22 10:38 AM
05/27/22 10:38 AM
second 70
central il.
No need to change out working openers . You can upgrade your opener these are only $30 and fit most openers. Same IQ tech. Open and close door from anywhere. Young neighbors wanted to replace broken touch pad but I got them this instead. Works great and you can always check door anytime with your phone to see it it's open or closed. Simple wifi install. https://www.lowes.com/pd/Chamberlain-MYQ-SMART-GARAGE-CONTROL/5001920965
[Re: second 70]
#3045769
05/28/22 05:46 AM
05/28/22 05:46 AM
Posts: 5,651 Port Huron, Michigan
MI_Custumz
No need to change out working openers . You can upgrade your opener these are only $30 and fit most openers. Same IQ tech. Open and close door from anywhere. Young neighbors wanted to replace broken touch pad but I got them this instead. Works great and you can always check door anytime with your phone to see it it's open or closed. Simple wifi install. https://www.lowes.com/pd/Chamberlain-MYQ-SMART-GARAGE-CONTROL/5001920965 Mine keeps saying offline at least once a week. I have to unplug it and plug it back in. Sucks if you are not home. I have a smart plug I can control from anywhere and plugged the MyQ into that. We will see if that works. Everyone said it's the wifi, but the wifi cameras are all fine.
[Re: second 70]
#3045779
05/28/22 07:13 AM
05/28/22 07:13 AM
Posts: 4,566 Motor City
6PKRTSE
Motor City
If it's a torsion spring door get a liftmaster 8500. Mounts on end of torsion shaft and gets rid of everything else leaving ceiling clean. Stu loved em. Hard to see but it's the small black box on left on wall behind bike. I have one on the 16ft front garage door too. Comes with a bluetooth light that plugs in where old opener was installed. I have both on same signal so when either door opens or you trip motion detector on wall panel the both come on together. Bright enough to go in and out of garage without turning on any lights. You can see it between the led fixtures. I wish I would have done this wall mount style. I still may add eventually. As you can see, I use every square inch of my garage.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#3045815
05/28/22 10:23 AM
05/28/22 10:23 AM
Posts: 544 boston mass-moving to long isl...
massdaytona
If it's a torsion spring door get a liftmaster 8500. Mounts on end of torsion shaft and gets rid of everything else leaving ceiling clean. Stu loved em. Hard to see but it's the small black box on left on wall behind bike. I have one on the 16ft front garage door too. Comes with a bluetooth light that plugs in where old opener was installed. I have both on same signal so when either door opens or you trip motion detector on wall panel the both come on together. Bright enough to go in and out of garage without turning on any lights. You can see it between the led fixtures. I wish I would have done this wall mount style. I still may add eventually. As you can see, I use every square inch of my garage. that is one LARGE shaker....
[Re: MI_Custumz]
#3045849
05/28/22 11:42 AM
05/28/22 11:42 AM
second 70
central il.
No need to change out working openers . You can upgrade your opener these are only $30 and fit most openers. Same IQ tech. Open and close door from anywhere. Young neighbors wanted to replace broken touch pad but I got them this instead. Works great and you can always check door anytime with your phone to see it it's open or closed. Simple wifi install. https://www.lowes.com/pd/Chamberlain-MYQ-SMART-GARAGE-CONTROL/5001920965 Mine keeps saying offline at least once a week. I have to unplug it and plug it back in. Sucks if you are not home. I have a smart plug I can control from anywhere and plugged the MyQ into that. We will see if that works. Everyone said it's the wifi, but the wifi cameras are all fine. WiFi signals can suck in some areas in the same room or have some interference messing them up and just moving your control to another outlet or location might fix your problem. It can drive you nuts when the signal is better outside than inside.
[Re: second 70]
#3045875
05/28/22 12:49 PM
05/28/22 12:49 PM
Posts: 4,727 Florida
BDW
After reading this thread, bought this on Amazon and its been working great, only $22. Hated the feeling when I might have left the garage open, now I can check and open or close from my phone. https://youtu.be/0gcyJC_WkRk
[Re: BDW]
#3046040
05/29/22 12:37 AM
05/29/22 12:37 AM
SomeCarGuy
My wifi opener had a sticker on it saying not to use led bulbs. That might be messing with your signal.
