Break away suspension?
#2923601
05/17/21 06:10 PM
05/17/21 06:10 PM
Posts: 5,821 ohio
ruderunner
ohio
So I've gotten on a kick of watching dashcam videos on YouTube. One thing I've noticed is that it seems really easy to knock the wheels off a newer vehicle. I don't mean cracked rims, but completely separated knuckles, spindles control arms etc.
Are they intentially designed to do this nowadays? Or just a consequence of weight loss and efficiency?
Surprisingly, I even see this on trucks too.
I don't recall ever seeing stuff like that on older vehicles, at least ones that weren't completely clapped out or rolling tetanus mills.
Angry white pureblood male
Re: Break away suspension?
[Re: ruderunner]
#2923606
05/17/21 06:24 PM
05/17/21 06:24 PM
Posts: 4,877 Virginia
BSharp
Virginia
My guess is some of both. Lighter, but also part of the "crumple zone". The energy of a crash has to go someplace; break the car before breaking the occupants.
[Re: ruderunner]
#2923610
05/17/21 06:31 PM
05/17/21 06:31 PM
Posts: 1,407 Central Pa
moparjim79
Central Pa
I don't recall ever seeing stuff like that on older vehicles, at least ones that weren't completely clapped out or rolling tetanus mills. Not 100% on the reasoning, but the suspension on newer vehicles is so easy to replace, my bet is yes, let the force destroy the consumables/sacrificial
[Re: ruderunner]
#2923673
05/17/21 08:37 PM
05/17/21 08:37 PM
Posts: 12,085 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Everything is as light (both in weight and duty) as is possible. Lots of aluminum, too. I doubt that the designers are thinking of repairability. They certainly don't think of repairability in any other areas that I can think of.
Master, again and still
[Re: BSharp]
#2923705
05/17/21 10:35 PM
05/17/21 10:35 PM
Posts: 16,820 Between Houston & Galveston TX
SattyNoCar
My guess is some of both. Lighter, but also part of the "crumple zone". The energy of a crash has to go someplace; break the car before breaking the occupants. May seem like a silly example, but I remember w-a-y back when that show 'COPS' started, they'd show cars with tires blown off, rims shredded , but the suspension wouldn't just 'break away' as it was being drug down the road at high speed. It would usually ground down, until the car was stopped by something (or someone) else. I remember one episode where a full size GM had ground thru the rotor all the way down to the control arm. Bent? Pretzeled? No doubt, but it didn't come apart.
John
[Re: SattyNoCar]
#2923748
05/18/21 03:55 AM
05/18/21 03:55 AM
Posts: 22,696 Bitopia
jcc
Bitopia
My thinking, from a technical standpoint, I could see the advantage on having a " breakaway" front wheel assembly, and then completely negating the difficulty of preventing it being rammed into the passenger compartment in a crash, as a wheel is a relatively large robust object, so separating has upsides as I see it. Loose objects post crash in public don't seem to have the same liabilities/concerns that they do for spectators at the race track.
[Re: BSharp]
#2923811
05/18/21 07:59 AM
05/18/21 07:59 AM
Posts: 19,915 Puttin' on the foil in Charles...
not_a_charger
Mr. Big Shot Moparts Moderator
My guess is some of both. Lighter, but also part of the "crumple zone". The energy of a crash has to go someplace; break the car before breaking the occupants. There are no crush zones in suspension parts, and wheels/suspensions are not designed to break away from the vehicle. I've been involved in vehicle damage claims since 1994, and vehicles now are no more or less likely to get their wheels torn off in a collision than they were in 1995. They've used aluminum in spindles, etc, for a long time now. The use of aluminum is more common than it was 25 years ago, but it wasn't as though everything was cast iron 25 years ago. Also, no manufacturer would purposely design a car to have a 100lb (or more) object intentionally separate from the vehicle and go flying into another vehicle, or a crowd of people, etc. The liability would be extraordinary.
Earning every penny of that moderator paycheck.
DBAP
[Re: not_a_charger]
#2923878
05/18/21 10:30 AM
05/18/21 10:30 AM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Front wheel drive and the MacPherson Strut front suspension are the culprits. No (or a very small) upper control arm makes for a very light, efficient, and compact front suspension. But it's not nearly as robust as twin A arm front suspensions because the lower control arm must do it all.
While I would agree with the above statement that current front suspensions are not much if any more fragile than those from 1995, the MacPherson strut front suspension has been wide spread since before that time. If you go back into the 60s and 70s before MacPherson became wide spread, you don't see the type of suspension separation that you see now. At least not nearly as often.
And you don't see suspension separation on larger rear wheel drive vehicles like full sized trucks and vans even today. Those vehicles aren't suitable for MacPherson Strut front suspensions due to the heavier loads that the front suspensions must deal with. On those vehicles, the front suspensions are basically as robust and resistant to separation as their counterparts were 40 or 50 years ago.
Front wheel bearings are another casualty of lighter, cheaper, more efficient....and more fragile modern front suspension designs. The ball bearings used in most MacPherson Strut front suspensions won't tolerate much in the way of side impact. Curb one once and it will be noisy thereafter. That wasn't true of the tapered roller bearings that we have in our muscle cars. The tapered roller can withstand much more side impact with little or no problem. That was the reason Mopar used tapered rollers in our rear axle bearings rather than the ball bearings used in the 'Green' bearings that many people like to use so that they don't have to adjust preload. Ball bearings on the rear of our cars do survive better than they could in other applications because they are better supported by the axle shaft.
[Re: not_a_charger]
#2923884
05/18/21 10:34 AM
05/18/21 10:34 AM
jcc
Bitopia
My guess is some of both. Lighter, but also part of the "crumple zone". The energy of a crash has to go someplace; break the car before breaking the occupants. There are no crush zones in suspension parts, and wheels/suspensions are not designed to break away from the vehicle. I've been involved in vehicle damage claims since 1994, and vehicles now are no more or less likely to get their wheels torn off in a collision than they were in 1995. They've used aluminum in spindles, etc, for a long time now. The use of aluminum is more common than it was 25 years ago, but it wasn't as though everything was cast iron 25 years ago. Also, no manufacturer would purposely design a car to have a 100lb (or more) object intentionally separate from the vehicle and go flying into another vehicle, or a crowd of people, etc. The liability would be extraordinary. I guess a lot would depend on the specifics of "purposely". Any past case history on the pursued liability to the manufacturer for separated parts caused by another's negligence in an accident? I have never heard of this concern, not saying it does not exist, yet.
[Re: DaveRS23]
#2923887
05/18/21 10:37 AM
05/18/21 10:37 AM
not_a_charger
And you don't see suspension separation on larger rear wheel drive vehicles like full sized trucks and vans even today. I've seen plenty of trucks/vans over the years with the wheels torn off. Hit the rear wheel on a solid axle-equipped vehicle hard enough, and you'll snap the end of the shaft and the wheel will come right off.
DBAP
[Re: jcc]
#2923889
05/18/21 10:41 AM
05/18/21 10:41 AM
not_a_charger
I have never heard of this concern, not saying it does not exist, yet. It doesn't happen often, thankfully. Anyone wondering why a manufacturer wouldn't design a wheel/suspension to purposely come off, or even design it with the intent that it might come off, can refer back to Senna's death in F1.
DBAP
[Re: not_a_charger]
#2923902
05/18/21 11:04 AM
05/18/21 11:04 AM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
And you don't see suspension separation on larger rear wheel drive vehicles like full sized trucks and vans even today. I've seen plenty of trucks/vans over the years with the wheels torn off. Hit the rear wheel on a solid axle-equipped vehicle hard enough, and you'll snap the end of the shaft and the wheel will come right off. That is a clumsy sentence on my part and does not reflect what I meant to say. I have a Ram here now that we replaced the rear diff in due to one side sheered off. But the point of this discussion is about today's vehicles being more prone to that than their predecessors. Not whether it happens at all. And I guess that I could have been clearer and have said that in my experience, today's full sized truck suspensions are no more prone to separation than yesteryears. And certainly not nearly as frequently as front wheel drive cars. Which is in keeping with the original subject of this thread and more in keeping with what I meant to say.
[Re: DaveRS23]
#2923918
05/18/21 11:24 AM
05/18/21 11:24 AM
not_a_charger
Gotcha. Rough estimate, I probably inspected 18-20k vehicles before I moved into my cushy corporate gig ( ) and stopped getting my hands dirty, but I can honestly say I never noticed an increasing propensity for suspension separation as time went on.
DBAP
[Re: not_a_charger]
#2923953
05/18/21 12:35 PM
05/18/21 12:35 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Completely depends on the time frame and designs used for reference. Let's use a very popular car, say chebby Impala as an example. It is my position that a 1995 Impala with twin A arms resists separation far better than a 2005 Impala with MacPherson Struts. But the 2005 is probably about as prone to separation as a 2015. Because of the change in designs and different approaches between the '85 and the '05/'15, the suspension separation became more frequent. Just looking at the difference in suspension components clearly shows why.
And I often look at 'cripples' at the salvage auctions to rebuild. Meaning late model cars with one of the suspension corners displaced or missing. They are often a little better bargain than usual and a front 'knee assembly' usually costs $150 or so and can be changed in a few hours when the inner structure is still in it's original location. On the more substantial double wishbone front suspensions like the rear wheel drive Impala I referenced above or on any full sized truck or van, the inner mounting structure is much more likely to have also sustained damage due to the ruggedness of the suspension on those vehicles. So, on late model full sized trucks, I will consider one with a rear wheel knocked off because there is a good chance that a replacement will simply bolt in. While a front wheel knocked off more often means body and frame mounts have been disturbed. Of course, a thorough in-person inspection is absolutely necessary to determine the particular extent of the damage.
How about one last example: break an axle at the drag strip on one of our Mopars and what happens to the wheel and tire? They usually stay in place due to the way that the axle is retained by the flange at the hub. Now, break an axle on a chebby at the strip. The poor chebby guy is probably looking at a quarter panel problem, too.
Again, different designs, different outcomes in the same application.
I'll say again that I believe that the MacPheason Strut form of suspension is much more prone to separation than the older suspensions that had substantial upper and lower control arms. And as the MacPherson Strut front suspension has became more predominant in production cars, so has the suspension separation frequency.
[Re: DaveRS23]
#2924086
05/18/21 06:57 PM
05/18/21 06:57 PM
Posts: 5,821 ohio
ruderunner
ohio
I can understand the breakaway as a crumple zone feature but question the benefits. Often in the videos the 3 wheeler carreens out of control. Not surprising when when 25 to 50 percent of your stability disappears along with 50 to 75 percent of your braking.?
Older stuff that retains it's integrity better might have a better chance of control.
Mind you, I fully understand that driver skill is a huge variable. GM ignition switch ring any bells?
Repairability is a whole other thing, odds are the vehicle will be a total either way. There's a reason derby cars tend to be more traditional in construction, they bend but don't break.
[Re: ruderunner]
#2924117
05/18/21 08:13 PM
05/18/21 08:13 PM
not_a_charger
There are no breakaway, crush zones, etc...in suspension parts. There are no parts designed to separate from the vehicle in a collision. There are no benefits to having such things. Manufacturers don't want a chunk of metal, a wheel/tire, a window, etc. flying through the air addressed "to whom it may concern."
You're right about the loss of stability and braking should the car keep moving/stay on the roadway. That does happen, but in my experience, it's the exception and not the rule.
DBAP
[Re: Stanton]
#2924141
05/18/21 09:15 PM
05/18/21 09:15 PM
not_a_charger
You did that because you cared about having to fix your kart, paying out of your pocket, and wanted to keep repair costs down. It makes sense in your case. However, the OEM's don't give a rat's a$$ about that. It's not their car, and they aren't paying the bill to fix it.
DBAP
[Re: not_a_charger]
#2924274
05/19/21 10:20 AM
05/19/21 10:20 AM
jcc
Bitopia
I have never heard of this concern, not saying it does not exist, yet. It doesn't happen often, thankfully. Anyone wondering why a manufacturer wouldn't design a wheel/suspension to purposely come off, or even design it with the intent that it might come off, can refer back to Senna's death in F1. Only because of his notoriety and skill is that an example most will not, it was a freak accident in many ways. The F1 Halo and Indy windshields are solutions in the right direction, but over a decade later. Wheels/parts still separate, but the question remains as to whether "purposefully" or not. Mark Donohue died from effectively an off the track 2x4 fence post entering the eye port of his full face helmet, causing delayed hours later, unknown brain bleeding.
[Re: not_a_charger]
#2924277
05/19/21 10:33 AM
05/19/21 10:33 AM
jcc
Bitopia
You're right about the loss of stability and braking should the car keep moving/stay on the roadway. That does happen, but in my experience, it's the exception and not the rule. You have seen pics/videos of controlled testing front on corner crash/collisions, that shoves the attached wheel into the the drivers footwell? What has changed dramatically over decades, IMO, is the crash testing, the more robust safety crash ratings, and insurance companies paying attention to those ratings. Correct me if I am wrong. A wheel separation is not entering the wheel well, and currently has as I know, no downside in the final crash score the vehicle receives. If the shanninhagn's VW played years n eeking out extra mileage numbers with their diesels is not enough of an indicator what companies will stump to, for billions of dollars, I don't think they would hesitate one bit if they know there was a rating benefit to increase a crash score, intentionally or not.
[Re: jcc]
#2924459
05/19/21 03:07 PM
05/19/21 03:07 PM
Guitar Jones
You're right about the loss of stability and braking should the car keep moving/stay on the roadway. That does happen, but in my experience, it's the exception and not the rule. You have seen pics/videos of controlled testing front on corner crash/collisions, that shoves the attached wheel into the the drivers footwell? What has changed dramatically over decades, IMO, is the crash testing, the more robust safety crash ratings, and insurance companies paying attention to those ratings. Correct me if I am wrong. A wheel separation is not entering the wheel well, and currently has as I know, no downside in the final crash score the vehicle receives. If the shanninhagn's VW played years n eeking out extra mileage numbers with their diesels is not enough of an indicator what companies will stump to, for billions of dollars, I don't think they would hesitate one bit if they know there was a rating benefit to increase a crash score, intentionally or not. I had a girlfriend years ago (tried to get rid of her here as some might remember) that thought everything I did or said had some kind of ulterior motive. Didn't matter that I was only trying to be nice, helpful or whatever. Everything vehicle manufacturers do is related to money. Light weight suspension components, many made of aluminum these days, are an example of that. Lighter weight, better fuel mileage, less emmisions, it's a win/win for them.
