Re: Ouch
[Re: justinp61]
#2920123
05/08/21 06:44 PM
05/08/21 06:44 PM
Posts: 20,655 in a cattle trailer down by th...
Guitar Jones
Be a man and grab it with a pair of pliers and rip it off.
Re: Ouch
[Re: justinp61]
#2920150
05/08/21 07:48 PM
05/08/21 07:48 PM
Posts: 70,126 Here
DirectSubjection
Tacohead. The First and Only
Here
You need to get a hole in the nail to relieve the pressure. I have done it using a brand new Xacto knife. Hand on a flat surface, nail up. Place the Xacto point on the center of the nail straight up and down. Slowly rotate the Xacto, do not press it down, let the weight of it do the work. Quickly a micro hole will appear and the blood will escape.
Ride eternal, shiny and chrome
Re: Ouch
[Re: DirectSubjection]
#2920155
05/08/21 07:54 PM
05/08/21 07:54 PM
Posts: 4,789 Star Idaho
67vertman
Star Idaho
it looks like the blood has already dried under the nail, how long ago did you do it? If it still fresh, I have used a small paper clip, bend one end straight and heat it up, then drill it through the nail to release the presure Either way you are going to be living with it for six months or more.
Better a finger nail, than the black eye I had from catching a medicine ball to the face........everyone felt they needed to ask how I got it.
My Monster are real!
Living within your means makes life pretty easy.
Re: Ouch
[Re: moparx]
#2920428
05/09/21 02:27 PM
05/09/21 02:27 PM
Posts: 7,833 east side of Ohio
basketcase
east side of Ohio
Dad would take a small drill bit, and work it on a nail when he did that to make a hole. When I worked at the IH dealer, we were stocking tractor trailer springs on a rack, and I dropped one on one of my big toes (no steel toes shoes there). Hurt like nothing else, but I worked the rest of the day. When I got home, the wife saw me limping,and when I took my shoe and sock off, the front half of my foot was purple. So she said come on,we're going to the ER. Doc wanted to give me a shot in my foot for the pain, but I said I did this this morning, and had been on it all day and didn't need the shot. Came back from x ray, and I had shattered the bone in the toe. Doc said he was going to make a few holes in the nail to relieve the pressure ( I remembered dad's drill bit trick and expected the same kinda thing) Wife asked the Doc if it would hurt...Doc said "small pinch....Next thing I knew I thought he dropped another spring on me. I looked down and he had a soldiering iron. He did it again and another scream outta me. Doc said I need to to do this again....The wife ripped into him. The Hell you are, I thought you said it wouldn't hurt!
1981 Dodge D150 360 auto
Re: Ouch
[Re: SattyNoCar]
#2920429
05/09/21 02:28 PM
05/09/21 02:28 PM
Posts: 4,449 Michigan
MarkZ
Worthy
Worthy
Soak it inside her....I mean in cider. That may be how he got it.......... Good thing he started with a finger first then. Yikes.
Re: Ouch
[Re: bigdad]
#2920784
05/10/21 03:00 PM
05/10/21 03:00 PM
Posts: 9,537 Super Spudsville
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
I got smashed like that one time, my whole arm turned white. Ive a friend who whacked off three finger tips cutting the Easter ham. This past Easter.
STOP POTATO HATE!
Re: Ouch
#2920843
05/10/21 05:22 PM
05/10/21 05:22 PM
Posts: 4,324 St. Louis, Mo
318 Stroker
St. Louis, Mo
You need to get a hole in the nail to relieve the pressure. I have done it using a brand new Xacto knife. Hand on a flat surface, nail up. Place the Xacto point on the center of the nail straight up and down. Slowly rotate the Xacto, do not press it down, let the weight of it do the work. Quickly a micro hole will appear and the blood will escape. Heat up the tip of a needle. It will go thru it like hot butter.
