Holley 650 DP spread bore, who knows about these carbs?
#291858
04/18/09 02:03 PM
04/18/09 02:03 PM
DaytonaTurbo
Manitoba, Canada
I've had this carb sitting on my shelf for quite some time now, it came with an old edelbrock intake I bought many moons ago. The carb is a Holley 650cfm double pumper in a spread bore setup. It's complete with manual choke, etc. Anyone know how long ago holley stopped making these?
I've never heard much about these carbs, do they work as well as the regular square bore holley double pumpers? I've read this carb is considered a 4165 series, will it take all the usual standard issue holley double pumper parts like jets, power valves and accelerator pump nozzles?
Re: Holley 650 DP spread bore, who knows about these carbs?
[Re: DaytonaTurbo]
#291859
04/18/09 02:25 PM
04/18/09 02:25 PM
Posts: 7,506 Az
Crizila
Az
Just rebuilt one a few months ago. They were a direct replacement for the Q-J on many GM cars. #6528 fit 68-70 350". 68-71 400,430,455". #6774 fit 1972 350 &455". They take all the standard Holley parts. Not sure on how long they were produced, but I would guess in to the late 70's. They were advertised as the "emission design/street performance" carb. I guess that would cover most the bases. Only draw back is they just didn't have the cfm of the QJ or TQ of that era. On the plus, lots of parts available for tuning.
Fastest 300
[Re: DaytonaTurbo]
#291863
04/18/09 05:17 PM
04/18/09 05:17 PM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
Well good to hear they use the standard parts. I know they use their own gasket kit but at least the other stuff is the same. I'll give the carb a try. Anyone ever run one of these on their ride? If so, how well did they perform and how good was normal driving operation with these?
I think the idle screws are reverse on these (turn them it, it gets richer). They also usually have anti pull over squirters (no check valve under the shooter)
[Re: torkrules]
#291864
04/18/09 08:56 PM
04/18/09 08:56 PM
Posts: 7,506 Az
Crizila
Az
Yes, the idle screws controlled air rather than fuel. They were usually marked on the side of the metering block with an arrow ( pointing counter clock-wise ) with the word LEAN just below the arrow. Also yes, the discharge nozzles were the anti-syphon type ( common on many other Holley carbs )and the metering block housed the accelerator pump discharge check ball - rather than it being below the nozzle. It also took a strange 2 piece base gasket. A thick asbostos gasket went on first, than a stainless plate gasket, then the carb sat right on the plate gasket. This 2 piece gasket was for use with OEM spread bore manifolds that had the exhaust cross-over on the surface of the carb pad.
Fastest 300
[Re: fox]
#291866
04/18/09 10:47 PM
04/18/09 10:47 PM
Posts: 1,090 Saskatchewan, Canada
barracudabob
They were considered a Quadrajet replacement back in the 70's and 80's. You could unbolt the Q-jet, chuck it in a garbage can, and bolt on the 6210. Even the fuel line lined up, as compared to a regular Holley which has the line to the float bowl. I've got one on a Brand X, works well, even has a divorced choke. As previously stated, they use a different gasket set than a regular holley.
[Re: DaytonaTurbo]
#291869
04/19/09 03:30 PM
04/19/09 03:30 PM
In general I didn't like these carbs. In the mid '70's I swapped a 340 into my '70 RR sixpack body, it was a 71 junkyard engine with a Thermoquad.
I ran two of these Holley's over the years swapped back and forth and finally mostly ran a QJ. That's right, a GM QJ.
After a while with a little dirt, sometimes the back barrels would stick "cracked" open--the mechanical linkage does not close them all the way. This can be VERY upsetting when you lift, and expect the thing to slow down.
These have the traditional power valve problems and between myself and my friends --back then--I've replaced a lot of Holley power valves.
Of the three available, "back then", Thermoquad, Holley SB or Quadrajunk, I'll take the QJ, thank you very much
[Re: DaytonaTurbo]
#291871
04/19/09 08:50 PM
04/19/09 08:50 PM
I would have to dig out the actual part number, but I ran one on the TT340 for 4 years. Spread bore 650, double pumper, center hung bowls, full metering and power valves on both ends, manual choke. I found it to be an extremely good carb that even worked pretty well (for a carb) after being extremely modified to run blow through boost. Very tuneable with standard parts. Obviously, you need to know how to drive mechanical secondary carb, or you will be severely disappointed.
