Re: FHO and Ray Barton who do you like
[Re: Cab_Burge]
#2914229
04/24/21 09:29 AM
04/24/21 09:29 AM
Posts: 154 Canada
cuda499
Canada
My Hemi parts purchase has come down to 2 gentleman. Tim Banning and Ray Barton. Who do you like and why? How many ET or MPH records has Tim Banning set? How many have you set, How many for Crower, Stage V, Dart and so on Both are excellent parts providers, machined or not The guy asked, i gave my opinion. You guys can get butt hurt all you want, Fact is ray has been messing with these hemi's and setting records for a long time and its who a trust to do my stuff.. He has nice stuff that he has developed, like intakes, rocker systems, and was involved in the millennium cylinder head. Im sure Tim's a great guy, but as long as ray is around i can choose to spend my money where i want too.
[Re: cuda499]
#2914240
04/24/21 10:14 AM
04/24/21 10:14 AM
Posts: 2,118 Byron, NY
W.I.N. Racing
Byron, NY
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: W.I.N. Racing]
#2914254
04/24/21 11:01 AM
04/24/21 11:01 AM
Posts: 5,122 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
Known and had both Tim and Ray do work since the mid 70s. Both are good at what they do. Super Stock Hemi I would go to Ray but there are others also that go plenty fast building the smaller Hemi motors. Big Cube Hemi there are a few I like. Best Machine does do good work. Investigate everything on your build before you go ahead. What is the time line you would like to have this Hemi Built done and if see you can do that. I have not been to Rays shop in Penn State, use to see him in Toronto and Montreal. Banning shop is real close to me and that makes it quite easy for me to get work done and buy parts. I like the bar oiling system that Ray sells but you have to do cleaning on it but on a race motor that is around twice a season. Now there are other ways that oiling is done. We always put return lines on the back of the heads but most of the cars we all have are drag cars. Lots and lots of other things. Not sure what Crank and Rods Tim or Ray have suggested. I sure like the Callies Crank a lot of money but it comes to your shop looking like Chrome. Others on here have their own ideas dont be afraid to talk to all on Moparts you will learn something every day from someone.
1971 HEMI E BODY REGISTRY
[Re: mopar dave]
#2914522
04/24/21 10:00 PM
04/24/21 10:00 PM
hemicar1971
Chicago Blackhawks
I have not been to FHO for a while since this Covid thing has screwed everything up. I believe Tim has a wall of Stage V heads last time I was there he did and about 5 to 10 blocks after picking up one last year but some blocks might of been spoken for and one guy I knew had bought 5 himself but he likely has them already since he asked me if I wanted to buy his old motor, world aluminum block stage V heads and all kinds of good stuff that made his car run into the 830s. I do like the Callies Crank.LIke my friend and it talked about this week, so much new stuff is being figured out and new parts real good rods and cranks and pistons now even from 5 years ago things have changed quite a bit.
[Re: mopar dave]
#2915036
04/26/21 08:31 AM
04/26/21 08:31 AM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
Dave, If you decide to get a KB block, make sure Tim has one in stock for you. From what I understand, they are NOT free flowing out the door like they told everyone they would be by now. I'd also suggest giving Todd Marsh at Marsh Performance a call. Ask him about a KB block. 336-283-0800 Todd is also a great option for anything you need for this build. I've only dealt w/ Ray Barton once when buying an intake manifold. He was great to deal with. They didn't have any of the single 4500 manifolds in stock, except for some "blems" that got drilled incorrectly for the 4150 pattern. He plugged the holes, installed solid threadserts in the correct 4500 pattern, and made me a hell of a deal on a manifold. Like Ray Barton, I'm sure Tim Banning builds a good hemi and definitely knows his way around them.
[Re: sasquatch]
#2915631
04/27/21 11:42 AM
04/27/21 11:42 AM
Posts: 2,677 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I have nothing against FHO but I call Ray. He has built 100's of the engines you are describing. The amount of experience he has is ridiculous.
2011 Drag Pak Challenger
[Re: rickseeman]
#2915907
04/27/21 09:51 PM
04/27/21 09:51 PM
hemicar1971
Chicago Blackhawks
Both Ray and Tim Honed their Hemi Craft in Toronto. Ray use to be in the back of Knob Hill Speed and Custom on Eglinton Ave in Toronto and Tim was in the head department in Entec in Toronto. Really back in those days 70s you went to othesr in Toronto to have your Hemi build by Beatty and Woods. Donny Cloake, Frank Elliotte Garry Van Stone, Bob Braby on and on there were a lot of good builders back then. Ray fine tuned his Super Stock build starting with Donny MacCallum, Donny was first in the 8s, Tim had two professions before he started FHO full time. Tim and others revamped KB because there was no Hemi Block of any kind available back a few years. Tim years back started building mostly bigger cubic inch Hemi motors. At one time Tim had a 500 CI 14 71 Blown Hemi in a Cuda making stupid HP. Ray raced a 1965 B Body for a while I believe. Ray and Tim both know each other very well both sell each others equipment that they have designed for the Hemis. Both have built plenty of Hemi motors since both have been doing this since the 70s. There are other like Todd that build a good product. Make an educated choice on who you pick. All these guys build good Hemis and all are busy doing that.
