67 Hemi Engine Bolt Finish Questions #291079
04/17/09 12:11 PM
04/17/09 12:11 PM
western PA
mopar4ya Offline OP
mopar4ya  Offline OP
western PA
Looking for some advice on the following bolts and other items, as to what would be the correct finish or plating.
Fan blade bolts
Bottom crankshaft pulley bolts
Alternator bracket and ajusting arm bolts
Power steering bracket bolts
Distributor hold down and bolt
Coil bracket and bolts
Thanks!
Dan
Re: 67 Hemi Engine Bolt Finish Questions [Re: mopar4ya] #291080
04/17/09 06:29 PM
04/17/09 06:29 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Fan blade bolts
Distributor hold down ( clear zinc and bolt
Coil bracket - Clear zinc
and bolts dark phosphate including all hardware listed above
Thanks!
Dan
