Re: Fuel With Ethanol Effects - How to Remove Ethanol: [Re: 56_Royal_Lancer] #2907355
04/06/21 03:33 PM
04/06/21 03:33 PM
South Lyon, MI.48178
K
kwhmopar1 Offline
kwhmopar1  Offline
K
Originally Posted by 56_Royal_Lancer
I thought it was Sideshow Bob
You are correct.
Junk is something you throw away just before you need it.
Re: Fuel With Ethanol Effects - How to Remove Ethanol: [Re: kwhmopar1] #2907361
04/06/21 03:49 PM
04/06/21 03:49 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
OOOooops!
Re: Fuel With Ethanol Effects - How to Remove Ethanol: [Re: HotRodDave] #2907366
04/06/21 04:16 PM
04/06/21 04:16 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Originally Posted by HotRodDave
Originally Posted by Sunroofcuda
Why would ANYBODY want to run E-85???
Its much cheaper, supports very high compression (actually enough to offset most if not all efficiency loss VS pump gas), and if your car is NOT a "flex fuel" vehicle the computer will not richen the mix up enough to hurt MPG, Less carbon build up in combustion chambers, smells like pop corn, supports american farmers instead of saudi terrorists, helps engine run cooler, can make more HP because it carries more oxygen into the air fuel mixture... heck the only good reason I see to not to is because al gore likes it.
I put a bunch of fuel system parts (steel lines, t-quad float bowl pieces, aluminum, brass, 68 cuda fuel hose...) in a sealed jar of e-85 and now 15 years later it all looks the same as when I put it in so I don't buy that the ethanol is what is plugging stuff up, ethanol actually leaves zero residue when it evaporates. If you keep the moisture out (don't put it in a boat or something with an atmosphere vented cap that will sit a long time) it will not corrode anything up,.
Ethanol can be corrosive.
https://pubs.acs.org/doi/10.1021/acs.energyfuels.7b01682
Basically, it draws water out of the atmosphere and that is what starts the corrosion issues, in your sealed jar you don't have atmospheric moisture available to be an issue. So it's a moot experiment. Anything with a vented fuel system will have that problem.
Re: Fuel With Ethanol Effects - How to Remove Ethanol: [Re: Kern Dog] #2907379
04/06/21 05:05 PM
04/06/21 05:05 PM
Highland, MI.
Sunroofcuda Offline OP
Highland, MI.
Originally Posted by Frankenduster
Krusty was voiced by Kelsey Grammer. I haven't seen the Simpsons in years!
No no - here's Krusty:
https://youtu.be/Eo0HfbJvPEU
Re: Fuel With Ethanol Effects - How to Remove Ethanol: [Re: Sunroofcuda] #2907401
04/06/21 06:56 PM
04/06/21 06:56 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
wikipedia.org/wiki/Krusty_the_Clown
Re: Fuel With Ethanol Effects - How to Remove Ethanol: [Re: Sunroofcuda] #2907408
04/06/21 07:08 PM
04/06/21 07:08 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
Easier to maintain temp when hot lapping at the track, significantly cheaper than mixing race and pump fuel(my fuel usage was 1/2 gal more for the day) my car actually picked up some ET
Ok
Re: Fuel With Ethanol Effects - How to Remove Ethanol: [Re: cudatom] #2907499
04/06/21 09:56 PM
04/06/21 09:56 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
If we are talking old cars or lawnmowers, just run Stabil 360 and be done with the issues. Remember the stuff is only good in the bottle for two years and you are good to go.
I want my fair share
