power window problems (74 sattelite)
#29036
07/31/06 06:31 AM
07/31/06 06:31 AM
Posts: 8,852 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
was messing with the power windows none of them work had a fuse that was blown changed it well the driver door window now works but none of the others do from any of the switches do thay run in a series as to if bad connection in the master switch then also wont work from the other switches? also wound the switch for the driver door be the would it be toward the back of the car or toward the front mine is toward the back and i just felt its in the wrong place??? ralph
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
Re: power window problems (74 sattelite)
[Re: toplescuda]
#29039
07/31/06 11:01 PM
07/31/06 11:01 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
ok took panel off seen where thay had some wire holding the glass up so un did it let glass slide down took a battery ran jumper wires to the motor it sounds like its working but its not spin/rotating the arm for moving up/down so now what??
[Re: toplescuda]
#29040
07/31/06 11:14 PM
07/31/06 11:14 PM
Posts: 3,535 Canuckville
68Cbarge
Canuckville
The nylon gears are torn up.Replace the motor.Or if you feel adventurous,just replace the top of the motor containing the gears. It is easier to remove the whole regulator out of the door to do it all. CAUTION!!! the spring is under extreme pressure !! When you take it out of the door,put the regulator in a bench vise TIGHT so not to undo the spring and not to lose an eye or an arm.This will make the removal and replacement of the motor easier. Remove the motor from the regulator and make the necessary repairs. Any power window from '66 all the way up to '89 RWD car will work.Even motors from C bodies. If you think the motor is running but the gears are stripped,undo the two long skinny bolts holding the motor together.From a donor p.window motor swap the head.Make sure the head is for the same side window.(thay are interchangeable-been there done that with 3 p.w. cars for 6 years) I hope this helps,good luck!! Sincerely,Leaburn
'68 Newport Custom Barge on a Budget!! BOAB 1973 Satellite WAGON! 318- 3 on the tree!! 2008 Chrysler 300c HEMI!
[Re: 68Cbarge]
#29041
07/31/06 11:39 PM
07/31/06 11:39 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
if i just unbolt the motor is stuff gonna fly apart? any one got a pic of apowerwindoe motor showing the gear before i tear the car apart and possbly die?lol
[Re: 5thAve]
#29043
08/01/06 01:11 AM
08/01/06 01:11 AM
toplescuda
I Whine
I Whine
poplar bluff mo.
can you buy the gear plastic thing new??
[Re: toplescuda]
#29044
08/01/06 06:41 PM
08/01/06 06:41 PM
68Cbarge
Canuckville
I never really tried to look for new parts.Used parts were still plentiful,so I used them up. To clear up any misunderstandings,or maybe I word it incorrectly. I suggested my method 'cause it works.It may be the "longer" way of doing it,but it was easier to handle the power window motor with the whole regulator out of the car,when you unbolt the three bolts holding the motor onto the regulator.I clamp the regulator in my bench vice against the spring so I can re & re the motor with ease--no parts flying off.It is also a good time to grease up all the moving points of the window mechanism/tracks-and door latch. I tried removing just the motor from the doors before and using vise grips to hold the spring.But some doors have next to no room to work leaving your hands bloodied,and tempers flared. You can learn something new everyday--including myself. If somebody can think of a better way,by all means chime in.
[Re: 68Cbarge]
#29045
08/01/06 06:50 PM
08/01/06 06:50 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
i looked down the door and you really can see anything but end of the motor i may just take it to someone who knows what the heck there doing lol
[Re: toplescuda]
#29046
08/01/06 07:11 PM
08/01/06 07:11 PM
68Cbarge
Canuckville
Do you have a shop manual?? Reading that and looking at the pics can help. I wish I was there to show you,or do it myself. Even better I can E-mail you pics of how I did itor expalin it over the phone.PM or call me if interested.I am just trying to help. If you are at a loss,maybe you should take it to somebody.
[Re: toplescuda]
#29049
08/02/06 08:26 PM
08/02/06 08:26 PM
Posts: 1,913 Brunswick, Jawgia
Snailpower
Infinitely Fast Snail
Brunswick, Jawgia
On a car that has never had a window motor repair, it is unlikely that you can get to the window motor bolts anyway. In order to get to them, you have to drill into the door to see the bolts. That is why Leaburn said in most cases it is easier to remove the entire regulator assembly. If your car has the bolt heads exposed, then you can just remove those three bolts and the window motor will come right out (meaning it will fall, so hold it from the rear). Here is a pic of the window motor. The one phillips head screw shown is what you would need to remove to fix the gear inside. It is pretty straight forward once your inside of it, as seen in the next couple of pics. The motor in the pictures is the older style, but newer style motors have a different gear with small plastic cylinders within the gear for cushion as the window reaches full up or full down. I have made my own replacement cylinders with a wooden dowel and 1/4" vacuum line. Easy. Remember, if you pull out some junkyard motors, use the ones on the same side of your car that you removed them from, or the polarity of the motor will be different and the switch will operate the window opposite of the switch position.
70 Coronet- turbocharged 360/518/3.73 SG
[Re: Snailpower]
#29050
08/02/06 08:34 PM
08/02/06 08:34 PM
Snailpower
Brunswick, Jawgia
Picture 2, cover removed.
[Re: Snailpower]
#29052
08/02/06 09:43 PM
08/02/06 09:43 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
ok i unbolted the regulator least its sepperat from the window lol well i still cang get the dumb reg out or even get the glass to come out the motor is still attached to the reg. as i fig i would pull the whole reg out and then take the motor off the only thing i haveng got unbolted yet is the bottom of the from slide that bolts to bottom of the door what the heck am i doing wrong???lol
