Re: 426 wedge
[Re: mopar muscle7271]
#2924183
05/18/21 11:50 PM
05/18/21 11:50 PM
Posts: 3,504 DFW
mr_340
DFW
Congrats on landing some pistons for your build. Thanks for the photo as well. Is the 809 on the one piston the weight in grams?
Floyd Lippencott IV
Re: 426 wedge
#2925068
05/21/21 03:16 AM
05/21/21 03:16 AM
Posts: 43,190 Bend,OR USA
Cab_Burge
They vary depending on which year and type, M.W. or street 426 I've never sonic tested the outside but I do know of some old time SO CA class racers that had the outsides machine thinner to be able to put more weight in the trunk and in the gas tanks I'm pretty sure that they are not real thick, maybe between .160 to .220 depending again on where on the block your measuring and the how many times that sand casting mold had been used before that block was cast
Re: 426 wedge
#2925156
05/21/21 11:58 AM
05/21/21 11:58 AM
Cab_Burge
You have two choices on fixing that, take it to a cast iron welding shop or have it "drilled and stitched pinned " I had a 1965 street wedge block that had two freeze cracks and a casting flaw in the crankshaft area at the bottom of cylinder #4 that leaked coolant that I had fixed at a cast iron welding shop in SO CA. The owner wanted that block fixed instead of using a 440 block he had due to it was the proper casting number and casting date for a 1965 Plymouth Satellite he had I've heard that there are some new cast iron welding rod that any good welder can use now to fix cast iron cracks like your deal, but be careful on who you have try that I've had several freeze cracked 906 heads fix the other way also, all things are fixable, not cheaply though Good luck on your deal
Re: 426 wedge
[Re: Cab_Burge]
#2925335
05/21/21 09:41 PM
05/21/21 09:41 PM
Posts: 459 las vegas,nv
mopar muscle7271
las vegas,nv
Well im goin to try and get the cast iron welding rod to fix it through muggy weld and stick weld it with rod.or get that lock n stitch kit.they need know to the thickness of block cast iron on block.so they can send me the right kit.would you know the thickness anyone?
Re: 426 wedge
#2925358
05/21/21 11:23 PM
05/21/21 11:23 PM
Posts: 3,076 Michigan
A727Tflite
Well im goin to try and get the cast iron welding rod to fix it through muggy weld and stick weld it with rod.or get that lock n stitch kit.they need know to the thickness of block cast iron on block.so they can send me the right kit.would you know the thickness anyone? Try using a one inch mic through the core plug opening.
Re: 426 wedge
#2925376
05/22/21 02:22 AM
05/22/21 02:22 AM
Cab_Burge
I have a Dakota 1000 sonic tester that I use to test cast iron and aluminum as well as other metals. I've seen a cylinder wall vary .050 about in a area about 1.0 inch circle on the same side of that cylinder My message is each block will be different in different areas, they are not precise castings
