Re: 426 wedge
[Re: mr_340]
#2904453
03/31/21 03:21 AM
03/31/21 03:21 AM
Posts: 459 las vegas,nv
mopar muscle7271
las vegas,nv
The engine would have no hp with a 8:1 compression if l did that.l could bore it to a 440 and use standard 440 pistons which be The same price as those low compression 383 pistons are. Mise well bore to a 440 then get another crank it be about the same price.
Re: 426 wedge
[Re: AndyF]
#2904545
03/31/21 10:49 AM
03/31/21 10:49 AM
mopar muscle7271
las vegas,nv
That's sick what was the cost of them? Do you still have your 426 wedge specs when you had them made custom?
Re: 426 wedge
[Re: mopar muscle7271]
#2904601
03/31/21 01:04 PM
03/31/21 01:04 PM
Posts: 4,723 Moved to N.E. Tennessee
GomangoCuda
That's sick what was the cost of them? Do you still have your 426 wedge specs when you had them made custom? Probably less $$ than 383 pistons and a stroker crank and then you also get lighter pistons with decent compression, better rings and valve notches.
Re: 426 wedge
#2904632
03/31/21 02:23 PM
03/31/21 02:23 PM
Posts: 43,190 Bend,OR USA
Cab_Burge
I've had to bore several 426 blocks, both street and M.W. blocks to 4.320 and used 440 pistons in them due to to much taper in the 4.310 bores, no problems on any of them I did have them all sonic tested first though boring them larger As far as strokers and lighters pistons compare to the stock stroke RB pistons weight the longer the stroke and the longer the rod the lighter the pistons get Can you say 526 grams with the pins
Re: 426 wedge
#2904658
03/31/21 03:57 PM
03/31/21 03:57 PM
Posts: 31,037 Oregon
AndyF
That's sick what was the cost of them? Do you still have your 426 wedge specs when you had them made custom? I don't recall, I'd have to look it up. The billet valve covers probably cost more than the pistons. It wasn't a cheap build.
Re: 426 wedge
[Re: AndyF]
#2904659
03/31/21 04:02 PM
03/31/21 04:02 PM
mopar muscle7271
las vegas,nv
Oh ok lmk if you find your specs at least,badass 426 wedge you built
Re: 426 wedge
[Re: Cab_Burge]
#2904660
03/31/21 04:03 PM
03/31/21 04:03 PM
mopar muscle7271
las vegas,nv
Good to know thanks for more info on boring to a 440 if l do that.
Re: 426 wedge
[Re: Alchemi]
#2905193
04/02/21 06:55 AM
04/02/21 06:55 AM
Posts: 348 Isle of Sheeps
Gtxxjon
Isle of Sheeps
Hi All,
A true 426ci engine is a 4.252 bore.
If you go 0.062 over, it will be a 438ci engine...
Doesn't quite have the same ring to it?
Carpe diem, quam minimum credula postero, thanx Horace!
There’s no point trying to fix stuff that ain’t broke,,, 'but if ain’t broke',,, you is not trying hard enough...
Re: 426 wedge
#2905420
04/02/21 03:16 PM
04/02/21 03:16 PM
Posts: 3,504 DFW
mr_340
DFW
DWTFYW.
Floyd Lippencott IV
Re: 426 wedge
#2905776
04/03/21 12:38 PM
04/03/21 12:38 PM
Cab_Burge
I rather you use the 426 stock crank then get another one.ld rather not use 383 pistons either I faintly remember someone, years ago, who tried using oversize 383 pistons in a 426 wedge and they were either way to low or high in relation to the deck to be used The compression heights, deck heights, stroke and rod lengths are different on them
