sources for 426 street wedge pistons #1576571
02/09/14 09:54 PM
02/09/14 09:54 PM
USA
SSAAHemiFan Offline OP
USA
Anyone know of a source for reasonable street wedge pistons ?
This is a 100% restoration motor so $$$ custom pistons would be overkill
I have a set of .020 Jahns that I was intent on using but I am second guessing that now because of the poor quality fuel available now
Block will clean up at .020 but is std bore now
Re: sources for 426 street wedge pistons [Re: SSAAHemiFan] #1576572
02/09/14 10:01 PM
02/09/14 10:01 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Sonic check it and see if it'll go .070 over and use std bore 440 pistons. Also, has anyone ever tried getting HEMI pistons and milling the dome off? Actually if your Jahns pistons have to much compression height and you have the crown thickness you could turn them down as well
Re: sources for 426 street wedge pistons [Re: WO23Coronet] #1576573
02/09/14 10:10 PM
02/09/14 10:10 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Hmmmmm.... I may have a set of standard bore in the garage from a standard 426 wedge engine thats sitting out there. I'll check it sometime this week and let you know what I find.
Russ
Re: sources for 426 street wedge pistons [Re: max_maniac] #1576574
02/09/14 11:07 PM
02/09/14 11:07 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
custom thru Race Tech or JE Pistons
MLR426
Re: sources for 426 street wedge pistons [Re: SSAAHemiFan] #1576575
02/10/14 12:13 AM
02/10/14 12:13 AM
AndyF Offline
AndyF  Offline
426W pistons haven't been in stock for over 20 years. Just get 383 pistons with the pin height changed. Diamond usually only charges a small fee to move the pin height.
Re: sources for 426 street wedge pistons [Re: AndyF] #1576576
02/10/14 01:16 AM
02/10/14 01:16 AM
Big Sky Country
MO_PA Offline
MO_PA  Offline
Big Sky Country
EGGE shows pistons for a 426
$500 L2229-8 PISTON SET
Bob Mazollini may have them, I got set from him not too long ago.
Re: sources for 426 street wedge pistons [Re: SSAAHemiFan] #1576577
02/10/14 01:55 AM
02/10/14 01:55 AM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
I put the complete list on moparts maybe back in the summer when someone else was asking.. Not sure if I still have the list but you can always do a search.
I know SpeedPro has them. Campbell Enterprises used to list them on their website at one time
Re: sources for 426 street wedge pistons [Re: AndyF] #1576578
02/10/14 02:13 AM
02/10/14 02:13 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
This, the stock pistons are probably down in the hole and not really at what would be considered an optimum height to today's standards.
Remember Chrysler overstate actual compression ratios
Re: sources for 426 street wedge pistons [Re: JohnRR] #1576579
02/10/14 02:20 PM
02/10/14 02:20 PM
USA
USA
Thanks for all the suggestions guys - I will do some more research with different vendors - I looked at the Egge version years ago but I thought they were cast ?
Russ - I appreciate the offer - this block will have to go at least .020 over to clean up - Don't go digging stay warm
Re: sources for 426 street wedge pistons [Re: SSAAHemiFan] #1576580
02/10/14 03:11 PM
02/10/14 03:11 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
No problem - however if you want to up the compression a bit I do have almost 2 full sets of these at 60 over....
Russ
Re: sources for 426 street wedge pistons [Re: 52savoy] #1576581
02/10/14 05:31 PM
02/10/14 05:31 PM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
Re: sources for 426 street wedge pistons [Re: 52savoy] #1576582
02/11/14 12:11 AM
02/11/14 12:11 AM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
In the Moparts for sale section
Jahns Cast Aluminum Pistons: New in the Box - Set of 8 426 Cubic Inch Part Number 8-1123 RP 030
Stock 426 Wedge Bore = 4.250,
they are .030 over pistons measuring a 4.280 at the skirt.
These are high quality pistons that include tapered wrist pins. $350 or best offer
Thanks / Scott Cell 262-424-7840
Russ
Re: sources for 426 street wedge pistons [Re: max_maniac] #2903335
03/27/21 11:03 AM
03/27/21 11:03 AM
las vegas,nv
mopar muscle7271 Offline
las vegas,nv
Do you still have pistons?
