Horn ID #289991
04/16/09 05:50 AM
04/16/09 05:50 AM
Anonymous OP
Anonymous OP
I tried posting this in the Q&A section but got no results.
I'm sure someone has one of these horns on their car(s) and can help me identify what year it's for.
The horn on the right has "239" stamped on it but I can't find a date code for the one on the left.
Does the 239 mean early June 1969? If so is the long bracket correct for this horn?
How bout the horn with short bracket and no date code?
Re: Horn ID #289992
04/16/09 04:54 PM
04/16/09 04:54 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
I have always had the understanding that the 239 date is 23th week of and the 9 is 69. The bracket for that horn is incorrect.
The othet horn has the 71-74 bracket and may be a replaement if no date is found. The late replacement/repos have two welds on the nub. I can't tell if yous has it due to the paint.
Re: Horn ID [Re: rrunner] #289993
04/16/09 05:03 PM
04/16/09 05:03 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
Never seen the bracket on the horn on the right before. I agree the the one on the left is the later 71-74 style.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: Horn ID [Re: rrunner] #289994
04/16/09 07:38 PM
04/16/09 07:38 PM
Anonymous OP
Anonymous OP
Which bracket should it have? What does it look like?
Where would the welds be?
What's the nub?
Is the date code always in the same place or is it randomly stamped on the top side?
Re: Horn ID #289995
04/16/09 08:51 PM
04/16/09 08:51 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
spot wels would be where I marked it. There would be two one on each side. The correct 68-70 bracket looks like the 71-74 but is longer from the 90 bend to the bolt hole and the bolt hole is not threaded as the threaded boss is attached to the radiator support.
Date codes as far as I have seen are always in the same general area.
Re: Horn ID [Re: rrunner] #289996
04/16/09 08:56 PM
04/16/09 08:56 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
here's a 68-70 style bracket.
Re: Horn ID [Re: rrunner] #289997
04/16/09 09:01 PM
04/16/09 09:01 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
and here's a repo with the two spot welds marked with the black line
Re: Horn ID [Re: rrunner] #289998
04/16/09 10:31 PM
04/16/09 10:31 PM
Anonymous OP
Anonymous OP
Okayyy... is this considered a spot weld?
I'm guessin so but wasn't sure, there is one on the other side also, it's got an _ish load of undercoating all over it.
Re: Horn ID #289999
04/16/09 10:32 PM
04/16/09 10:32 PM
Anonymous OP
Anonymous OP
Sorry for the crumby pics, camera battery was going dead and I just wanted to pop a few pics befor having to wait for a recharge.
Re: Horn ID #290000
04/16/09 10:34 PM
04/16/09 10:34 PM
Anonymous OP
Anonymous OP
Here's another look at the funky bracket.
Any idea what it belongs on?
Re: Horn ID #290001
04/17/09 04:22 PM
04/17/09 04:22 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
Never seen anything like that bracket. My guess is it home made.
