Re: Encroachment issue/property line
[Re: varunner]
#2899531
03/15/21 10:31 PM
03/15/21 10:31 PM
Posts: 10,206 Someplace you aren't
SomeCarGuy
No way in a subdivision like that that he doesn’t have his own access to the street. You wouldn’t have a neighbor easement issue in a place like that.
I want my fair share
[Re: varunner]
#2899548
03/16/21 12:15 AM
03/16/21 12:15 AM
Posts: 31,023 Oregon
AndyF
Moving a marker pin isn't normal so I'd focus on that. That map you have seems pretty clear so double check to make sure that it is the "official" map that was filed with the city or county when the subdivision was approved. There should be a surveyor name on the map and the developer who laid out the subdivision should know where everything is supposed to be. Subdivisions are laid out by engineering firms who keep records and everything is filed with the city or state. Everything is permitted and filed and checked off when a subdivision is put in so there will be plenty of records. All you are going to need to do is follow the paper trail on where the pins should be and where the driveways should be.
A lawyer could be useless unless he knows something about subdivisions. If it was me I'd start with the developer who laid out all of the lots and see how they wanted things done. That is the plan that everyone should be following. Moving pins and changing land boundaries isn't allowed unless the proper paperwork is filled out.
And in a case like this it is always best to assume that it was an honest mistake. Give the guy plenty of room to fix his mistake, especially if the map is clear. I wouldn't get a lawyer involved up front, just get the pin moved back to where it should be and go from there.
[Re: varunner]
#2899580
03/16/21 07:57 AM
03/16/21 07:57 AM
Posts: 2,332 Addison Twp, Mi.
RobG
Addison Twp, Mi.
First, call and report this to the building department and ask them to investigate/pull his permit.
Measure the length of the property bounty from the other corner and paint a line where the marker should be located.
The building officials will have a lot to say....
I am not rich...but I get off my ass everyday to make sure I am not broke!
Can we get the Mexican cartels to help us with our supply chain issues? They don't seem to have any trouble getting stuff from one place to another.
[Re: AndyF]
#2899766
03/16/21 04:33 PM
03/16/21 04:33 PM
Posts: 1,899 MYRTLE BEACH SOUTH CAROLINA
ek3
And in a case like this it is always best to assume that it was an honest mistake. Give the guy plenty of room to fix his mistake, especially if the map is clear. I wouldn't get a lawyer involved up front, just get the pin moved back to where it should be and go from there. ------ this is easy. have it checked/ surveyed and then whats yours is yours. you can legally notice them to keep out and the police can enforce it. this is not hard to do. its private property and they dont own it..........
[Re: roadrunninMark]
#2899849
03/16/21 08:14 PM
03/16/21 08:14 PM
Posts: 10,713 North Dakota
6PakBee
North Dakota
If the guy is being a PITA, let him build it then have zoning show up and make him remove it. Nothing hurts more like hitting him where it counts. I'd be hesitant to go this route. All the building official has to ask is how you became aware of the problem and when the answer is "we knew before he started but we didn't stop him until now", that isn't going to go well.
[Re: 6PakBee]
#2899872
03/16/21 09:17 PM
03/16/21 09:17 PM
Posts: 2,110 Byron, NY
W.I.N. Racing
Byron, NY
What he is doing is theft... plain and simple. take your survey map/Deed to the local Zoning clerk and make a formal complaint.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: 6PakBee]
#2899926
03/16/21 11:56 PM
03/16/21 11:56 PM
Posts: 22,696 Bitopia
jcc
Bitopia
If the guy is being a PITA, let him build it then have zoning show up and make him remove it. Nothing hurts more like hitting him where it counts. I'd be hesitant to go this route. All the building official has to ask is how you became aware of the problem and when the answer is "we knew before he started but we didn't stop him until now", that isn't going to go well. Which really drives home the seldom mentioned point here. "time is of the essence", and its not on the OP's side.
[Re: A39Coronet]
#2900152
03/17/21 05:37 PM
03/17/21 05:37 PM
Posts: 661 Virginia
varunner
Virginia
Good one. it would many years to erase that line. The neighbor is a modular home installer and has put many homes in our county. The home in question is a couple weeks from completion and I'm sure it's already sold. So they are 100% off our property, But the newly installed culvert is in front of our lot by about 10 ft. No ones lot includes the ditch that the culvert is in. I'm in process figuring out who owns the ground the culvert is installed. It will removed one way or another, but I need to do it before they close on the sale so this issue doesn't fall onto the new homeowner. We had our 2 acre lot surveyed and they found every pin and marked them with a wooden stake. Next day three of the stakes were throw in the street from a neighbor who wasn't thrilled about where they were. I paid to have the three pins relocated, then cut down every single tree along that 300" stretch. Told him to try and move that.
Hope it works out, neighbor sounds like a real peach.
[Re: ro23_j]
#2900168
03/17/21 06:30 PM
03/17/21 06:30 PM
Posts: 1,229 In The Hills
jughed
In The Hills
Go to your county's website and find the GIS (geographic information system) link. Many counties have your property lines mapped and you can see them overlaid on maps.You may be able to see your property and the state/county right of ways. There is a lot of information that is public record that you can find by doing some research. Great idea. Check the county website I had a 48x36 pole barn/garage built...a neighbor who (lives across street) didn't want it to be built because it would block the scenic view of nearby woods would surely have waited for me to build and then raise hell (another great idea IF you are right about lot lines). I used the County GIS 'parcel viewer' to verify the property lines. A county employee told the builder that the lines shown on the viewer are accurate to within 2 feet. Didn't hurt that the next door neighbor was the local property tax collector. She knew the property lines very well.
