Re: Co-worker loses her 57 due to the snow storm
[Re: maxie]
#2891245
02/20/21 10:38 PM
02/20/21 10:38 PM
Posts: 1,118 Rochester NY
Jer
Rochester NY
seams odd to me that the grooves in the roof panels are not running in a direction that would allow the water/snow to drain down off the roof. Looks as if the stuff would lock into the grooves running right to left instead of top to bottom. There is SOOO much wrong with the construction of that building. It was not a kit, as they generally have things like instructions and diagrams and the proper parts to put it together. This was clearly put together by someone who had no clue what they were doing. Sad about the truck but all they had to do was simply look UP and see the serious and obvious issues with that building and they wouldn't have parked it there...or even worked in that mess.
[Re: maxie]
#2891247
02/20/21 10:43 PM
02/20/21 10:43 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
Structurally that's the way they have to span. That and other clues led me to believe the design work was done by SRE, Southern Redneck Engineering, I've seen their work before.
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: Jer]
#2891249
02/20/21 10:48 PM
02/20/21 10:48 PM
Posts: 6,289 nowhere
Sniper
nowhere
I don't disagree with anything said and would like to point out that too many people do not enough of a basic foundation of knowledge to see the issues even if they looked up, which is why too many things like this get hired out to incompetent "experts" that talk a good game.
[Re: TJP]
#2891268
02/20/21 11:58 PM
02/20/21 11:58 PM
Posts: 4,954 WI
Dcuda69
WI
Any idea how much accumulated snow was on the roof ?? Bummer and glad it was insured I agree!! How much snow?? We currently have a couple feet of snow on the ground/buildings. I haven't seen anything about any roof collapses etc.I know they don't build for snow load down south but I gotta think a well built building would easily deal with 6 or more inches of snow load. Is this more snow than that? I also agree that the roof panels appear to be running in the wrong direction and that is a BIG beam to fail under snow load of any size. Lots of questions here. Hope they get everything handled....looked like a great truck!!
[Re: not_a_charger]
#2891385
02/21/21 11:17 AM
02/21/21 11:17 AM
Posts: 43,585 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
Yes it sucks, but that is what insurance is for, and that is nothing compared to "losing" a car in a fire. That truck is easily repaired, half of it can still be used! Don't try this at home, though the guy I sold it to had it back on the road the next year...
JB Rhinehart, Realist
A-Body's RULE!
[Re: 3hundred]
#2891481
02/21/21 01:50 PM
02/21/21 01:50 PM
Rhinodart
Rhinotruck
Rhinotruck
The Transam got saved? Yes, I put it on Craigslist and got a reply almost immediately. He was in the next town over and wanted to see it right away. Only question he has was if I had the build sheet and did it say Y88 on it, which it did, Gold Edition SE with T-Tops. By the time I delivered it he already had a gold parts car in his driveway! He was a true late 70's Pontiac guy as he had a 77 Can Am in the garage...
A-Body's RULE!
[Re: not_a_charger]
#2891547
02/21/21 04:19 PM
02/21/21 04:19 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
Truck is insured. Her husband and her father in law are very talented/skilled car builders, so I have no doubt it will get fixed. Sounds like the perfect opportunity to take a 2" chop from the roof Lemonade from lemons I'm an eternal optimist, sometimes Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: AndyF]
#2892090
02/23/21 03:31 AM
02/23/21 03:31 AM
Posts: 1,229 In The Hills
jughed
In The Hills
Sorry to see that happen, but I do agree with every comment that the building was so poorly built. Especially the first one... I'd hazzard a guess that that was not an engineered building. Just out of curiosity, where's the beam that's supposed to be supporting that I-beam ?? And roof trusses on what, 4-foot centers ?!?! Storing $100k vehicles in $100 sheds ... you kinda deserve whatever ya get !! and this one had me rolling. "SRE"...hilarious Structurally that's the way they have to span. That and other clues led me to believe the design work was done by SRE, Southern Redneck Engineering, I've seen their work before. This country isn't (yet) a 3rd world dump, so don't be cheap when it comes to building any structures. Code, or no code.
[Re: maxie]
#2892155
02/23/21 10:35 AM
02/23/21 10:35 AM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
seams odd to me that the grooves in the roof panels are not running in a direction that would allow the water/snow to drain down off the roof. Looks as if the stuff would lock into the grooves running right to left instead of top to bottom. I don't think the roof metal is running the wrong way. The purlings are running parallel to the side wall with the roof metal perpendicular to it. It appears to me that a splice in the rafter failed and the roof colapsed.
[Re: justinp61]
#2892178
02/23/21 11:06 AM
02/23/21 11:06 AM
Posts: 3,386 St. Charles, MO
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
seams odd to me that the grooves in the roof panels are not running in a direction that would allow the water/snow to drain down off the roof. Looks as if the stuff would lock into the grooves running right to left instead of top to bottom. I don't think the roof metal is running the wrong way. The purlings are running parallel to the side wall with the roof metal perpendicular to it. It appears to me that a splice in the rafter failed and the roof colapsed. I don't even see any purlins? It looks like the sheet metal is supported directly by the rafters, which is why they had to run the sheet metal grooves horizontally (which is wrong). If they had the correct purlins in place running horizontally between the rafters, then they could have run the sheet metal vertically on top of the purlins. This allows the rain and snow to drain off as it should. As others have said, there are several issues with the way that roof was built that contributed to the accident.
1969 Dodge Coronet Super Bee 383 A4 1970 Plymouth Road Runner 440 FC7 (sold)
[Re: wingman]
#2892220
02/23/21 12:37 PM
02/23/21 12:37 PM
Posts: 31,050 Oregon
AndyF
The I beam appears to be fractured which is a very odd failure for a beam that large. Steel beams that size don't usually fracture when overloaded, they typically bend and yield. The fracture seems to indicate that the beam was either made from very low quality steel or perhaps it was damaged at some point. Maybe poor welding or someone used a torch to bend it or something? I really can't say just based on a picture but if I was hired to figure out what happened to the building I'd start with that fracture.
Kind of looks like the old Liberty ship brittle fracture issue. Back in WWII there were a bunch of brittle fractures that sunk or damaged the Liberty ships. The issue was poor quality steel and poor welding practices. The steel became brittle in cold weather and the hulls would crack open. Possibly the same defect that caused the Titanic to crack open. Those kinds of problems aren't supposed to still be around these days since steel mfgs know better and welders are supposed to know better. So kind of scary to see that fracture.
[Re: wingman]
#2892339
02/23/21 04:08 PM
02/23/21 04:08 PM
justinp61
W. Kentucky
seams odd to me that the grooves in the roof panels are not running in a direction that would allow the water/snow to drain down off the roof. Looks as if the stuff would lock into the grooves running right to left instead of top to bottom. I don't think the roof metal is running the wrong way. The purlings are running parallel to the side wall with the roof metal perpendicular to it. It appears to me that a splice in the rafter failed and the roof colapsed. I don't even see any purlins? It looks like the sheet metal is supported directly by the rafters, which is why they had to run the sheet metal grooves horizontally (which is wrong). If they had the correct purlins in place running horizontally between the rafters, then they could have run the sheet metal vertically on top of the purlins. This allows the rain and snow to drain off as it should. As others have said, there are several issues with the way that roof was built that contributed to the accident. If that overhead door is on the a side wall what you are calling rafters are the purlings and the beam that was scabbed and broke is the rafter. Without more pbotos its almost impossible to know.
[Re: justinp61]
#2892344
02/23/21 04:13 PM
02/23/21 04:13 PM
Posts: 9,511 Super Spudsville
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
I got to say thats heartbreaking, glad no life was lost. No one builds anything with plans of it falling down, unfortunate.
STOP POTATO HATE!
[Re: AndyF]
#2892537
02/24/21 01:57 AM
02/24/21 01:57 AM
Posts: 4,153 Canada -- Posts: 4034 -Registe...
5thAve
Kind of looks like the old Liberty ship brittle fracture issue. Back in WWII there were a bunch of brittle fractures that sunk or damaged the Liberty ships. The issue was poor quality steel and poor welding practices. The steel became brittle in cold weather and the hulls would crack open. Possibly the same defect that caused the Titanic to crack open. Those kinds of problems aren't supposed to still be around these days since steel mfgs know better and welders are supposed to know better. So kind of scary to see that fracture. The end of the beam has marks on it that make it look like it was existing and had a plate welded on it.
