Re: car score gone wrong [Re: 67SATisfaction] #2887662
02/13/21 03:30 PM
02/13/21 03:30 PM
CA
crackedback Offline
crackedback  Offline
CA
Originally Posted by 67SATisfaction
Originally Posted by I_bleed_MOPAR
Trailer sway without a doubt. I towed an '01 Dakota ClubCab 4x4 home from NC behind my '06 2500 on a UHaul trailer. I wound up using backroads to get back as when I hit 55 it would start to sway.
Tim
So, just curious - what are the loading strategies to avoid sway? Is the goal to have the load balanced on the trailer so the hitch isn't loaded much, or is *some* load on the hitch better to plant the rear tires? ..maybe there are different solutions to different situations?
I've towed a few things in my lifetime, and I know what sway can feel like. But my loads and the trailers I used were fairly "ordinary" - construction site office trailers, boats, building materials, etc.
- Art
You need tongue weight. It helps to counteract swaying.
If you have a car on this type of trailer and can lift the trailer tongue up when loaded, you don't likely have enough tongue weight. Generally, in this case, you want anywhere from 10-15% of the loaded trailer weight on the tongue. He should have had 350-500# of tongue weight. With the car having batteries in trunk, should have loaded it backwards and maybe even kept it jacked up for clearance.
Then there are the ones that it starts swaying and they just keep legging it out at 65-70+... nothing wrong there. I see the opposite end all the time when the desert guys drag rigs out to sand dunes. Explorers/Tahoes/suburbans/PU's looking like they are popping the front tires off the ground being overloaded and TOO much tongue weight. They go ditch hunting quite often. Still hammering along at 60+ most of the time.
Re: car score gone wrong [Re: Moparite] #2887745
02/13/21 06:49 PM
02/13/21 06:49 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
Originally Posted by Moparite
Wonder if opted for the insurance? When you rent a u haul trailer they ask you what you are driving and what are you towing to see if it's acceptable. I'm sure the software that figures that out didn't know about the 500 pounds of batteries in the trunk.
I was wondering about insurance on the car itself. First thing I do when I buy a car is get insurance. Before picking it up or having it shipped, whatever. Not worth saving the money for a few days of insurance. As far as the trailer goes, he's probably covered with his vehicle. but I'm no so sure about the load. May become a civil case in court if he exceeded the load limit of trailer.
Facts are stubborn things.
Re: car score gone wrong [Re: 67SATisfaction] #2887974
02/14/21 09:30 AM
02/14/21 09:30 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
In this specific case the best strategy would have been to take the batteries out of the back of the car and put them in the bed of the truck.
Re: car score gone wrong [Re: Sniper] #2887985
02/14/21 09:51 AM
02/14/21 09:51 AM
RWG75
RWG75
Wheel base of the tow vehicle can be a factor in trailer sway. Tongue weight and load balance obviously matter. I suspect what nails most people is over speed, not paying attention and not expecting sway or not knowing how to react. I don't tow often but when I do I keep in the granny lane. How long the trip takes is way down the list of priorities vs keeping it out of the ditch. Kinda like winter driving.
Re: car score gone wrong [Re: ] #2888076
02/14/21 12:52 PM
02/14/21 12:52 PM
moparx Offline
moparx  Offline
of which the cardinal rule is : "keep it under a hunderd !"................... biggrin
beer
Re: car score gone wrong [Re: Sniper] #2888092
02/14/21 01:04 PM
02/14/21 01:04 PM
Spring City , Pa.
SIKPUP Offline
SIKPUP  Offline
Spring City , Pa.
Push the batteries up against the cab in the bed ! Center the weight in the tow vehicle , not added tongue weight !
Re: car score gone wrong [Re: lilcuda] #2888099
02/14/21 01:06 PM
02/14/21 01:06 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Originally Posted by lilcuda
Exactly how is that car a “score”?
Im sure to the new owner it was.
Re: car score gone wrong [Re: 67SATisfaction] #2888261
02/14/21 04:44 PM
02/14/21 04:44 PM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
I'll bet thae car had lots of weight in the trunk with the hydraulics.
Maybe should have backed on and had sway bars if he did not.
Additionally I wonder if he exceeded tow cap of the tow vehicle.
