Re: Franks Red Hot i put that @#$% on everything!
[Re: ricomondo]
#2885517
02/08/21 01:13 PM
02/08/21 01:13 PM
Posts: 2,113 Byron, NY
W.I.N. Racing
Byron, NY
I don't use it too often. Sometimes I will use it to make a quick "buffalo sauce" with some melted butter Franks and toss the wings in it.! That's the original Buffalo wing recipe - Franks and margarine. Franks for heat, margarine is the glue to hold it on the wing.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: Pacnorthcuda]
#2885604
02/08/21 04:43 PM
02/08/21 04:43 PM
Posts: 9,122 Tucson, AZ
Ramrod39
My New Title
My New Title
Tucson, AZ
Thia is the stuff we use on nearly everything down here. Made in Mexico, not horribly hot, great favor. Frank's is OK, but we like this better. like Tapatio....”that [censored] is everywhere”. Hey Ramrod.....did you ever solve your gun safe battery problem? I may(?) have solved the safe problem. I might have discovered that making sure the wheel/lever you turn to open the safe is fully backed off saves the battery. My wildazz theory is that if the lever is loaded a bit against the solenoid or whatever activates the release it drains the battery. Not 100% sure if that is really the case but since making sure the wheel is completely backed off every time I close the safe I've not had to replace a battery, been 2.5 months now.
[Re: Ramrod39]
#2885619
02/08/21 05:38 PM
02/08/21 05:38 PM
Posts: 21,825 Kirkland, Washington
Pacnorthcuda
Thia is the stuff we use on nearly everything down here. Made in Mexico, not horribly hot, great favor. Frank's is OK, but we like this better. like Tapatio....”that [censored] is everywhere”. Hey Ramrod.....did you ever solve your gun safe battery problem? I may(?) have solved the safe problem. I might have discovered that making sure the wheel/lever you turn to open the safe is fully backed off saves the battery. My wildazz theory is that if the lever is loaded a bit against the solenoid or whatever activates the release it drains the battery. Not 100% sure if that is really the case but since making sure the wheel is completely backed off every time I close the safe I've not had to replace a battery, been 2.5 months now. Interesting! That would be easy to check with a meter if you had the back of the door off. That is a bit wildazz but if you are right that’s a big deal. Would love to hear updates, if there are any. I was getting 6 months off Duracell’s in mine, so I decided to buy a $9 Amazon Lithium (not rechargeable) and I’m about 3 or 4 months into that trial. Sorry for the thread hijack! I’m guilty...illl stop now!!
[Re: Pacnorthcuda]
#2885657
02/08/21 08:41 PM
02/08/21 08:41 PM
Ramrod39
My New Title
My New Title
Tucson, AZ
Thia is the stuff we use on nearly everything down here. Made in Mexico, not horribly hot, great favor. Frank's is OK, but we like this better. like Tapatio....”that [censored] is everywhere”. Hey Ramrod.....did you ever solve your gun safe battery problem? I may(?) have solved the safe problem. I might have discovered that making sure the wheel/lever you turn to open the safe is fully backed off saves the battery. My wildazz theory is that if the lever is loaded a bit against the solenoid or whatever activates the release it drains the battery. Not 100% sure if that is really the case but since making sure the wheel is completely backed off every time I close the safe I've not had to replace a battery, been 2.5 months now. Interesting! That would be easy to check with a meter if you had the back of the door off. That is a bit wildazz but if you are right that’s a big deal. Would love to hear updates, if there are any. I was getting 6 months off Duracell’s in mine, so I decided to buy a $9 Amazon Lithium (not rechargeable) and I’m about 3 or 4 months into that trial. Sorry for the thread hijack! I’m guilty...illl stop now!! I'll keep you updated...
[Re: Ramrod39]
#2885710
02/08/21 11:39 PM
02/08/21 11:39 PM
Posts: 11,583 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I've tried Frank's.. Too vinegary for me IIRC. Been awhile.
Cholula and the original cock sauce, Sriracha, in my fridge right now.
[Re: CMcAllister]
#2885779
02/09/21 09:32 AM
02/09/21 09:32 AM
Guitar Jones
Frank's for wings, scrambled eggs and bloody marys.
[Re: Pacnorthcuda]
#2886248
02/10/21 11:04 AM
02/10/21 11:04 AM
Posts: 12,431 Warren, MI
71TA
Warren, MI
Thia is the stuff we use on nearly everything down here. Made in Mexico, not horribly hot, great favor. Frank's is OK, but we like this better. like Tapatio....”that [censored] is everywhere”. Hey Ramrod.....did you ever solve your gun safe battery problem? They have Tapitio on the tables at the restaurants in our local Mexican town. I get that sometimes too. VERY flavorful. Franks. That stuff is on the tables at the Waffle House. Yuck. I eat at the Waffle Hose (and risk my life) every time I'm out of town. You never feel "odd" eating alone at a Waffle House
[Re: 71TA]
#2886415
02/10/21 04:29 PM
02/10/21 04:29 PM
moparpollack
Lil Herman
Lil Herman
85086
Texas Pete for me it's good for everything.
[Re: moparpollack]
#2886416
02/10/21 04:32 PM
02/10/21 04:32 PM
Posts: 11,387 NJ
rdrnr6970
Your #1 source for current events
NJ
When they didnt have franks they substituted texas pete,wasnt bad.
OWNER OF EVERYTHING FROM 1956 300 B,IMPERIAL,NEW YORKER HEMIS,AND NEW HEMI TRUCKS.....5TH GENRAMS.COM... 1969/70 ROADRUNNERS ,DARTS/CORONETS, NORTHEAST HEMI OWNERS ASSOCIATION.....WWW.PHANTASMCUDAS.COM....MOPAR FAMILY FOR 50 YEARS AND STILL GOING!MOPAR OWNER COAST TO COAST!!!!
[Re: 71TA]
#2886427
02/10/21 04:46 PM
02/10/21 04:46 PM
Guitar Jones
The Frank's isn't really hot, I like the Tapitio too. Some of those sauces are just over the top though. I get heatburn easy enough so I'm not likely to use something too hot unless I want to suffer for the rest of week. I'm secure enough in my manhood that I don't need to burn holes in my esophagus to prove it.
[Re: moparjim79]
#2886559
02/10/21 09:42 PM
02/10/21 09:42 PM
Posts: 1,830 South Bend
John Brown
South Bend
My go to is Crystal. My son bought me a sampler from Walmart for Christmas from the Datl Doit company. Those are THE BEST hot sauces I have ever had, and you can only buy them during the holidays. The company will not sell them separately or break up the packages, but trust me, you'll love em all! https://www.datildoit.com
[Re: John Brown]
#2886564
02/10/21 10:02 PM
02/10/21 10:02 PM
Posts: 1,407 Central Pa
moparjim79
Central Pa
My go to is Crystal. My son bought me a sampler from Walmart for Christmas from the Datl Doit company. Those are THE BEST hot sauces I have ever had, and you can only buy them during the holidays. The company will not sell them separately or break up the packages, but trust me, you'll love em all! https://www.datildoit.com Hey man, thanks, but unfortunately, that doesn't even scrape the surface of the gift pack. Trust me my wife and I scoured the web and eBay. The 12 bottle mix pack is what I'm talking about. They DO NOT SELL THEM SEPARATELY
