Re: Engine Diaper
[Re: jwb123]
#2884580
02/06/21 12:13 AM
02/06/21 12:13 AM
Posts: 2,152 Fancy Farm Ky
wyoming
Fancy Farm Ky
Another Vote for Russlerii, good drawing and pics, it will fit perfect, or mine have anyway. Dont see many pics on here right now with the Heat barrier on them, he will add if you need for the same price, if your close on your headers it will help.
Re: Engine Diaper
[Re: dvw]
#2884625
02/06/21 09:02 AM
02/06/21 09:02 AM
Posts: 10,032 MN
JERICOGTX
MN
I have a RusslerII on my car also. Great fit. I even got a Christmas card from him this year.
69 GTX
68 Road Runner
Re: Engine Diaper
[Re: dvw]
#2884646
02/06/21 10:29 AM
02/06/21 10:29 AM
Posts: 1,927 Seaford, Va
Kindafast
Seaford, Va
Mines from Russeleri as well. Sent him a drawing. Fits nice. Doug Not to change the post but Damn that is once clean and detailed undercarrige . Nice
6.50 @105.26
Re: Engine Diaper
[Re: Kindafast]
#2884937
02/07/21 12:50 AM
02/07/21 12:50 AM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
Mines from Russeleri as well. Sent him a drawing. Fits nice. Doug Not to change the post but Damn that is once clean and detailed undercarrige . Nice Yeah Doug's car is one nice machine but now I have to wonder what that gauge is that is mounted in front of the oil pump/filter Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
Re: Engine Diaper
[Re: fourgearsavoy]
#2884982
02/07/21 09:19 AM
02/07/21 09:19 AM
Posts: 9,847 MI, usa
dvw
MI, usa
Mines from Russeleri as well. Sent him a drawing. Fits nice. Doug Not to change the post but Damn that is once clean and detailed undercarrige . Nice Yeah Doug's car is one nice machine but now I have to wonder what that gauge is that is mounted in front of the oil pump/filter Gus Air pressure for the Master Lube (oil accumulator). Doug
Re: Engine Diaper
[Re: dvw]
#2884983
02/07/21 09:29 AM
02/07/21 09:29 AM
Posts: 1,646 Ringtown, Pa.
Dartsport540
Ringtown, Pa.
DRE diaper on mine . Have it on for about 10 years.
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
Re: Engine Diaper
[Re: 340Cuda]
#2885022
02/07/21 11:43 AM
02/07/21 11:43 AM
Posts: 2,512 PA
moparacer
PA
About 10-11 years ago I had a company in Ohio make me one for my car. I think it has a tag on it that says JJ? It held up well until my bumper dragging pan smashing episode last fall. I have to get a new one now too...
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
Re: Engine Diaper
[Re: old_racer]
#2885177
02/07/21 04:17 PM
02/07/21 04:17 PM
Posts: 4,684 Wichita
GY3
Wichita
a few of my friends are running belly pans now too. takes a little fab work but they seem to be happy with them. another option. Are there any minimum requirements for a belly pan when it comes to depth, height and width? They're saying 6.40 and faster requires pan or diaper now and I''ve surpassed that.
Re: Engine Diaper
[Re: n20mstr]
#2885349
02/07/21 10:22 PM
02/07/21 10:22 PM
Posts: 2,047 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
Belly pan has to have a 2” min depth . I have one on my car . A lot easier than a diaper Any pictures of it that you can post? Thanks, Brian
Re: Engine Diaper
[Re: n20mstr]
#2885396
02/08/21 12:36 AM
02/08/21 12:36 AM
Posts: 2,512 PA
moparacer
PA
The pans dont look like they would do a very good job of containing oil and parts if it kicks a rod out the side of the block...A diaper runs up both sides of the bock to the head gaskets.
Re: Engine Diaper
[Re: rebel]
#2885527
02/08/21 01:34 PM
02/08/21 01:34 PM
Posts: 422 montana
BANDIT
montana
My pans are wider and attach to the frame or cage, diapers suck! Hard to get off, get oily, hold heat in motor, just have always seemed like a PIA to me. I have a brake in shop, and access to sheet aluminum. It’s kinda fun to bend up your own. I talked with our NHRA tech guy, and he says there is no minimum spec on material until you get into fuel or top Alcohol type cars. I believe the aluminum I use is .029 or .039, have to go look for sure. Usually can use Addell clamps on cage tubing and slugs elsewhere. Always just have 4 attaching points. Just my personal preference tho. Jim.
64 Dodge Coronet 440. In progress 1998. Dodge Avenger. 8.35@165. 4400 DA 250” Neil and Parks Slip Joint. 7.36@183. 4600 DA 242" Mullis Dragster. 6.90@ 200mph
