Anybody else ever heard of this nonsense
#2879863
01/25/21 01:34 PM
01/25/21 01:34 PM
Posts: 11,713 Portage,michigan
B3422W5
Portage,michigan
Was on another forum. Guy buys a crate motor and cant get it to run cool. Has thrown a new radiator at it, ect. No change. So he calls the company and they tell him, no problem, common issue, it will cool down 30 degrees once its “ broken in” Lol Trying to think of anything i have ever had that tan any cooler the next week, next month, next year. Being in the car business, i have driven literally thousands of brand new cars, cant remember any that didn't run cool initially, that didn't have to “ break in” to run cool. They probably figure he will throw enough parts at it to fix the issue before its broken in.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
Re: Anybody else ever heard of this nonsense
[Re: sasquatch]
#2879869
01/25/21 01:45 PM
01/25/21 01:45 PM
B3422W5
Portage,michigan
It can be true with a complete rebuild that it might run warmer on the first few startups while it does "break in" but not 30 degrees. Especially a stock type motor should not be running "hot" like that. Make sure to burp it good but I would not continue to keep running it until I identified the reason. Todd Right. This guy was told it was normal for the first 500 miles. Crazy.....
[Re: B3422W5]
#2879896
01/25/21 02:19 PM
01/25/21 02:19 PM
Posts: 1,927 Seaford, Va
Kindafast
Seaford, Va
500 miles at a 1/4 mile at a time could take years. LOL I would say either the engine is too tight or something in the cooling system is partially blocked. Does the owner have one of those digital thermometers ? If so I would read it all over the engine and find the hot spots
6.50 @105.26
[Re: B3422W5]
#2879933
01/25/21 02:54 PM
01/25/21 02:54 PM
Posts: 609 Boise
Moparteacher
Boise
Complete nonsense. Either the new owner is doing something wrong i.e., air trapped in the cooling system, timing, lean, wp flow direction etc. Or, there's a problem with the new engine. Head gasket(s) on backwards, blockage in the cooling passages, cylinder walls are too thin, engine is too tight (and I have doubts about that issue),,
Or, it's not running hot at all and there's a fault in the temp sender or gauge.
But running hot until broke-in is bs, slightly warmer...maybe, but noticeably hotter? Nope.
[Re: B3422W5]
#2879973
01/25/21 03:41 PM
01/25/21 03:41 PM
Posts: 4,682 On the parachute mount
n20mstr
Was on another forum. Guy buys a crate motor and cant get it to run cool. Has thrown a new radiator at it, ect. No change. So he calls the company and they tell him, no problem, common issue, it will cool down 30 degrees once its “ broken in” Lol Trying to think of anything i have ever had that tan any cooler the next week, next month, next year. Being in the car business, i have driven literally thousands of brand new cars, cant remember any that didn't run cool initially, that didn't have to “ break in” to run cool. They probably figure he will throw enough parts at it to fix the issue before its broken in. LMAO..... did they tell him take the rad cap off and let it run until it "burped" ??? Maybe they figure he just has air trapped and eventually its going to come out ??
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#2880044
01/25/21 05:51 PM
01/25/21 05:51 PM
Posts: 19,367 Las Vegas
Al_Alguire
Las Vegas
Makes zero sense for sure but it got him off the phone. Id suggest he checks his ignition timing and maybe even ad a few degress. Seen many engine run hot from not enough initial timing..But the why is a whole other story.
[Re: B3422W5]
#2880077
01/25/21 06:56 PM
01/25/21 06:56 PM
Posts: 12,100 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Too warm in January? It's really gonna suck this summer. "Broken in" or not.
Master, again and still
[Re: Al_Alguire]
#2880147
01/25/21 09:09 PM
01/25/21 09:09 PM
B3422W5
Portage,michigan
Makes zero sense for sure but it got him off the phone. Id suggest he checks his ignition timing and maybe even ad a few degress. Seen many engine run hot from not enough initial timing..But the why is a whole other story. Yea, he is driving it now(408 stroker) and its staying around 190 with it 40 degrees out he says. Hopes it will be “ broken in “ by summer time. Not sure where he lives
[Re: B3422W5]
#2880158
01/25/21 09:20 PM
01/25/21 09:20 PM
Posts: 10,554 Rittman Ohio
fourgearsavoy
Rittman Ohio
190 degrees is NOT hot even at 40 degrees outside. There are a lot of unanswered questions here. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: B3422W5]
#2880162
01/25/21 09:28 PM
01/25/21 09:28 PM
Posts: 21,825 Kirkland, Washington
Pacnorthcuda
Makes zero sense for sure but it got him off the phone. Id suggest he checks his ignition timing and maybe even ad a few degress. Seen many engine run hot from not enough initial timing..But the why is a whole other story. Yea, he is driving it now(408 stroker) and its staying around 190 with it 40 degrees out he says. Hopes it will be “ broken in “ by summer time. Not sure where he lives The guy is an idiot. You DiD tell him he’s an idiot right? If you didn’t.....why not? Seriously?
[Re: fourgearsavoy]
#2880179
01/25/21 10:03 PM
01/25/21 10:03 PM
B3422W5
Portage,michigan
190 degrees is NOT hot even at 40 degrees outside. There are a lot of unanswered questions here. Gus When it was 85 out the guy said it ran 215. Believe he stopped driving it after swapping in a radiator and it staying at that temp. Then he lets it sit and tries it again when its 40 out and it runs 190.
[Re: GarageDodge]
#2880306
01/26/21 09:44 AM
01/26/21 09:44 AM
B3422W5
Portage,michigan
This is the post by the owner of the new motorthat got me
“So it turns out that blueprint engines run hotter during break-in. I got ahold of a service guy there, and he said 210-220 is what the typically what they run during break in, and after about 500-1000 miles should slowly come down to 180 degrees. I do see the posts talking about that my timing is not advanced enough, I could maybe put lighter springs in so the full advance kicks in a lot sooner than 4000, but I can’t make it go past 34 degrees. That’s the max blueprint recommends.”
[Re: B3422W5]
#2880321
01/26/21 10:20 AM
01/26/21 10:20 AM
Posts: 4,723 Moved to N.E. Tennessee
GomangoCuda
“So it turns out that blueprint engines run hotter during break-in. I got ahold of a service guy there, and he said 210-220 is what the typically what they run during break in, and after about 500-1000 miles should slowly come down to 180 degrees. I do see the posts talking about that my timing is not advanced enough, I could maybe put lighter springs in so the full advance kicks in a lot sooner than 4000, but I can’t make it go past 34 degrees. That’s the max blueprint recommends.” Might need the curve shortened. It could have 0° at idle.
[Re: B G Racing]
#2880324
01/26/21 10:26 AM
01/26/21 10:26 AM
B3422W5
Portage,michigan
After checking all the usual suspects such as cooling system problems,timing and guage accuracy look at the spark plugs or co2 reading to see if a lean fuel condition is the culprit.Many times lean fuel and to much timing will cause an engine to run hot.Also make sure you run a thermostat or restrictor(usually a 5/8 hole) to allow the coolant to pass through the rad slow enough to be cooled.Don't realy on the engine supplier's opinion unless they have actually investigated all the circumstances.All the possible issues mentioned should be checked and eliminated. The point is, the company that built the engine said it was typical for them to run 30 degrees cooler 500-1000 miles down the road after they are “ broken in” I take that at face value. No mention of..did you do this or that
