1970 Cuda Rocker Molding Question? #287483
04/13/09 07:06 PM
04/13/09 07:06 PM
Georgetown Ontario Canada
anlauto Offline OP
anlauto  Offline OP
Were the original 1970 Cuda louvered "fish scale" rocker moldings a solid argent silver colour or was each louver originally "blacked-out" ?
CHECK OUT MY NEW WEB SITE !
Re: 1970 Cuda Rocker Molding Question? [Re: anlauto] #287484
04/13/09 07:43 PM
04/13/09 07:43 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Untouched Original
Re: 1970 Cuda Rocker Molding Question? [Re: Snoopy] #287485
04/13/09 07:43 PM
04/13/09 07:43 PM
Snoopy Offline
Snoopy  Offline
2
Re: 1970 Cuda Rocker Molding Question? [Re: Snoopy] #287486
04/13/09 08:15 PM
04/13/09 08:15 PM
anlauto Offline OP
anlauto  Offline OP
Thanks Snoopy....Looks like I have my work cut out for me with the reproductions I bought
Re: 1970 Cuda Rocker Molding Question? [Re: anlauto] #287487
04/13/09 08:16 PM
04/13/09 08:16 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
BTW, that paint is not textured argent, it's just silver paint. The texture was cast right into the part.
Re: 1970 Cuda Rocker Molding Question? [Re: ScottSmith_Harms] #287488
04/15/09 10:06 PM
04/15/09 10:06 PM
ohio
jaycuda Offline
jaycuda  Offline
ohio
Painting is easy if you do it the way I have in the past seems crazy but works perfect. the first thing you do is spray your black towards the black surface getting good coverage.Then simply spay the silver from the opposite direction with the molding held up on an angle with the black facing down along with your spray direction. This will leave you with a factory look and no time wasted on a tape off of your black. Good luck it will work fast and look killer. Jay
Re: 1970 Cuda Rocker Molding Question? [Re: jaycuda] #287489
04/16/09 09:47 AM
04/16/09 09:47 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
.....to paint each relief individualy is insane!.....I've used pretty much the same proccess, except I spray the whole peice black, then stand the mldgs vertical with the reliefs or "saw edges" facing downward, and only topcoat them in silver, in one direction, downward,.......this allows the black fillet, to be accented as original, without goin insane trying to detail them
Re: 1970 Cuda Rocker Molding Question? [Re: DAYCLONA] #287490
04/16/09 10:20 AM
04/16/09 10:20 AM
anlauto Offline OP
anlauto  Offline OP
How do they attach to the car from factory? Just simple screws?
Re: 1970 Cuda Rocker Molding Question? [Re: anlauto] #287491
04/16/09 12:23 PM
04/16/09 12:23 PM
Toronto (YYZ) Ontario
YYZ Offline
YYZ  Offline
I agree with the painting methods described above - it works exceptionally well.
There are special shouldered screws to hold the rocker mouldings on (contact m46rat for correct ones), otherwise I've just used stainless steel pan head screws to hold 'em in the past.
Re: 1970 Cuda Rocker Molding Question? [Re: YYZ] #287492
04/16/09 01:46 PM
04/16/09 01:46 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
Does anyone have a pic of the special screws that came off of an original untouched car? My last two unrestored '70 'Cudas used regular panhead screws.
Re: 1970 Cuda Rocker Molding Question? [Re: 70440+6bbl] #287493
04/16/09 05:10 PM
04/16/09 05:10 PM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
I wouldn't get all jammed up about the "special" screws, my 3,900 mile survivor has the pan head also.
Re: 1970 Cuda Rocker Molding Question? [Re: 70440+6bbl] #287494
04/16/09 06:51 PM
04/16/09 06:51 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Here's a pic {of the rocker screws} that Dwight{m46rat} had posted in a previous thread...
Re: 1970 Cuda Rocker Molding Question? [Re: HEMICUDA] #287495
04/17/09 10:45 AM
04/17/09 10:45 AM
Calgary, Alberta Canada
m46rat Offline
m46rat  Offline
Mike: If they are not a big deal to you, then why did you PM me about reproducing them?
Re: 1970 Cuda Rocker Molding Question? [Re: m46rat] #287496
04/17/09 10:55 AM
04/17/09 10:55 AM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
Reason for asking is that I bought a set from m46 last year thinking my car had the wrong hardware. I tried to replace the pan heads with them and discovered that the shoulder bottoms out before it holds the rocker molding down. My car has 100% original Chrysler made rocker moldings. The SPD of my last 'Cuda was A12 (Oct.12th '69) and the one I own now is B05 (November 5th '69), is it possible that the moldings were revised and made a little thicker at some point making the shouldered screws a necessity???
Re: 1970 Cuda Rocker Molding Question? [Re: 70440+6bbl] #287497
04/17/09 09:53 PM
04/17/09 09:53 PM
California
1970mopar Offline
1970mopar  Offline
California
yes, there wwas more than "one version" of the 70 rocker mouldings although they have the same part number.
