Re: Dealer Mechanics
[Re: fal3]
#2874430
01/14/21 07:19 PM
01/14/21 07:19 PM
Posts: 19,974 Puttin' on the foil in Charles...
not_a_charger
Mr. Big Shot Moparts Moderator
I doubt a new car dealer would want the job in the first place, and I am certain that they wouldn't install a ring & pinion that you provided to them.
Earning every penny of that moderator paycheck.
DBAP
[Re: formula_s]
#2874441
01/14/21 07:46 PM
01/14/21 07:46 PM
Posts: 9,719 Home
SRT6776
I hate internal combustion engines!
Home
A new car dealer service dept isn't going to do an over the counter gear swap. They wouldn't even know what an 8 3/4 center section is. Try do find a dealer mech that can gap a set of point lately.? Use to work at a dodge dealer back in 2001, I had an 87 dakota - leaving work one day it wouldn't start. I went into the shop and nobody knew "how to work on anything that old" except ONE guy, and he figured out the issue in 2 minutes. He's probably retired now.
[Re: formula_s]
#2874909
01/15/21 09:20 PM
01/15/21 09:20 PM
Posts: 10,556 Rittman Ohio
fourgearsavoy
Rittman Ohio
A new car dealer service dept isn't going to do an over the counter gear swap. They wouldn't even know what an 8 3/4 center section is. Try do find a dealer mech that can gap a set of point lately.? I guess you've never been to the Toyota dealership where I work. All the writers know that I will work ANY transmission or rear axle. I set up Mopar, Toyota, Dana, and 9" Ford rears all at the dealership. Oh and I can set points and adjust a carburetor too Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: Dabee]
#2874912
01/15/21 09:23 PM
01/15/21 09:23 PM
Posts: 4,156 Canada -- Posts: 4034 -Registe...
5thAve
A dealer isn't even on my radar for that kind of work. Best bet is to find some small local shop that's been around a while and ask them. They would know where to go for that kind of work or could even do it themselves.
As far as only doing parts swaps, there are a number of dealers around here with mechanics who have the training to tear into engines or rebuild transmissions for newer vehicles.
