Removal of Thrust Buttons in 8.75 SG ?? UPDATE #287203
04/13/09 12:41 PM
04/13/09 12:41 PM
Retired now in Tennessee
Chi_Town_Runner Offline OP
I have an 8.75 SG 742 case that still has the Thrust buttons installed. From a very knowledgeable source I have been advised to remove these buttons since I have the green bearings installed on my axles.
The diff is mounted to my engine stand so I do have easy access to it.
When viewing the buttons through the axle openings how can I tell which way to drive out the pin holding the buttons in place?
As I look at it, one side of the pin seems to be machined flat and on the other side, the pin appears to have a dimple in the center. Am I correct to assume the dimpled side is the side that the pin was installed from, therefore, hammer out the pin from the smooth machined side.
If so, how much force to hammer it out.
I'm a first timer at this thrust button deal.
Any help would be greatly appreciated.
Thanks,
Frank
Remember - 2 wrongs don't make a right - but 3 rights make a left!
Re: Removal of Thrust Buttons in 8.75 SG ?? [Re: Chi_Town_Runner] #287204
04/13/09 01:12 PM
04/13/09 01:12 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
The roll pin will come out either way but first if you can just take a magnet and try to fish the buttons out. The pin is more than likely broken any way. All is is is a pin that holds the buttons in place for assembly. I haven't used a pin in them for years.
Alot of the time the buttons will fall out when you pull the axles.
Stand the axle on end if the pumpkin is in the houing and they may fall out too.
If the pumpkin is not in the housing they are a piece of cake to get out. Grab with a long needle nose pliers.
Re: Removal of Thrust Buttons in 8.75 SG ?? [Re: MoparforLife] #287205
04/13/09 01:20 PM
04/13/09 01:20 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
The pins do not come out if you have a cup and cone type Posi.( Sure Grip) Only the clutch type can be removed. (power Loc) (they have about 10 bolts securing the two halves together)
Either posi can be fitted in a 742 case, but most have the Power Loc.
Re: Removal of Thrust Buttons in 8.75 SG ?? [Re: MoparforLife] #287206
04/13/09 01:23 PM
04/13/09 01:23 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
... normally they will fall out when you are pulling the axles out when it's in the housing and you don't even realize it . I found a pair of the buttios in my bee rear , one in each axle tube grinding a notch in the axles ...
If it's a FRESHLY built rear it will have a new rollpin as the originals usually break after a number of miles , the rollpin is just to hold it together until the rear is completely assembled ...
Re: Removal of Thrust Buttons in 8.75 SG ?? [Re: MoparforLife] #287207
04/13/09 01:28 PM
04/13/09 01:28 PM
Thanks for the replys. It seems that the two thrust buttons are attached to each other via the pin. I have tried the magnet and the long needle nose plyers. They do float in the housing, meaning if I push on one the other side moves also. They are not frozen.
Again, I'm new to this so I went to Mancini to see what these things look like.
See the link: Mancini .
I'm not saying that these are the buttons in there, as I don't think this thing has been apart since '68, but looking at the Mancini part, the pin can only come out one way. But maybe your right for a '68 vintage gear.
In either case, those buttons are not floating independant of each other. They are fixed via the pin.
Frank
Re: Removal of Thrust Buttons in 8.75 SG ?? [Re: Chi_Town_Runner] #287208
04/13/09 01:37 PM
04/13/09 01:37 PM
JohnRR Offline
JohnRR  Offline
that is an interesting one Mancini has , maybe someone finally smartened up and made a pin to hold the buttons together and not have the retaining pin break keeping the buttons in place if you pull the axles,. I bet the other end of that countersunk pin has a counterbore in it and once the piece are installed you peen the counterbored end to keep the parts in place ? I'm guessing this may be what you have from the description of what you are seeing ?
Frank can you grab the pins with 2 pairs of needlenose pliers and turn one while holding the other still ? if so it's going to take a little more effort to get them out.
Re: Removal of Thrust Buttons in 8.75 SG ?? [Re: sthemi] #287209
04/13/09 01:53 PM
04/13/09 01:53 PM
Greg,
How can I tell if I have a cup and cone type SG?
Mine has 8 bolts holding the two halves together.
So far, every one has mentioned a "roll pin".
My understanding of roll pin is a round pin, hollow in the middle and split down the side to allow for compression. This pin is SOLID.
Not trying to sound too dumb or anal but maybe I'm missing something here. I defer to many members on this baod with far more knowledge than I.
Thanks to everyone.
Frank
Re: Removal of Thrust Buttons in 8.75 SG ?? [Re: JohnRR] #287210
04/13/09 01:57 PM
04/13/09 01:57 PM
John,
I tried the needle nose plyers. The buttons are definitely secure to the pin. If I turn one side the other side also turns.
Frank
Re: Removal of Thrust Buttons in 8.75 SG ?? [Re: Chi_Town_Runner] #287211
04/13/09 02:00 PM
04/13/09 02:00 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
If you have stock axles, a stock housing and snap-ring style green bearings you do not have to remove the thrust buttons.
If you want to remove the thrust buttons, reach an 1/8" punch through the differential side gear and drive the roll pin out. If you have thrust buttons that are held together with a rivot, drive the pin out with a 1/8" punch opposite the rounded head.
Re: Removal of Thrust Buttons in 8.75 SG ?? [Re: DoctorDiff] #287212
04/13/09 02:07 PM
04/13/09 02:07 PM
JohnRR Offline
JohnRR  Offline
Thanks for that Doc , is this also the case with the thrust block on a cone type and if so is this something that only pertains to the snap ring greens ?
Frank , if you have buttons like the one in the link above it's not a cone type , also you can not rotate the thrust block in a cone type it's fixed ,it can only move a little and you wouldn't be able to grab the block with pliers as is almost the same size as the hole the axle splines into .
Re: Removal of Thrust Buttons in 8.75 SG ?? [Re: JohnRR] #287213
04/13/09 02:19 PM
04/13/09 02:19 PM
John,
I don't know what type of buttons I have in there. I did some research to see how these buttons were held in place and I came across the Mancini site.
From all outward apperances the buttons do look the same as the photo. I can rotate the buttons, slide them back and forth, just not independantly of each other. They are fixed to that pin. I don't think it's a rivit. As I said earlier the pins face on one side looks almost machined, spiral groves, and the other looks like it's been dimpled in the middle, not by force but by machining.
Hope I'm not adding to the confusion with all of this discription.
Dr. Diff,
It is the stock housing, stock axles, I just don't know what type of green bearing I had installed 6 year ago. How would I be able to tell if they are the snap ring type.
I don't want to remove the thrust buttons if it's not necessary.
I really appreciate the patience exhibited here on "MY" problem.
Frank
Re: Removal of Thrust Buttons in 8.75 SG ?? [Re: Chi_Town_Runner] #287214
04/13/09 02:30 PM
04/13/09 02:30 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
You can't rotate the thrust spacer on a cone type differential. And the cone type does not have a pin because its a one piece. Sounds like a clutch differential to me. I have an NOS thrust spacer kit for a clutch sure grip and it looks just like the one in the link above.
Re: Removal of Thrust Buttons in 8.75 SG ?? [Re: 69Cuda340S] #287215
04/13/09 02:41 PM
04/13/09 02:41 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
If you have a Cone type S/G you'll see springs... if you have a Clutch type S/G you won't...
Cone style..
Clutch style..
Re: Removal of Thrust Buttons in 8.75 SG ?? [Re: 1_WILD_RT] #287216
04/13/09 02:42 PM
04/13/09 02:42 PM
Upper Midwest
Upper Midwest
Re: Removal of Thrust Buttons in 8.75 SG ?? [Re: 69Cuda340S] #287217
04/13/09 02:43 PM
04/13/09 02:43 PM
Bill,
I'm sure I have the clutch type based on the info I received here so far. Could you look at the thrust space kit you have and describe what the ends of the pins look like. If I can tell from the discription of what the face of each end looks like then I should be able to determine which way to hammer the pin out.
From the photo on the link it can only come out one way because of the one expanded head.
Frank
Re: Removal of Thrust Buttons in 8.75 SG ?? UPDATE [Re: Chi_Town_Runner] #287218
04/13/09 04:31 PM
04/13/09 04:31 PM
Yahooo
Got it
After all the help on this board I took a fine punch and with some FIRM taps was able to knock out the pin holding the buttons . My buttons resembled the ones from Mancini in the link above.
It appears that it does not matter in which direction you punch out the pin. I must have been at the chamfered side. The chamfer on the pin is not very solid and seperated from the pin to release it.
Just make sure you recover any pieces after the removal.
Thanks to:
Johnahah
Moparforlife
sthemi
DoctorDiff
69Cuda340S and
1_Wild_RT
I appreciate your help and time.
Frank
Re: Removal of Thrust Buttons in 8.75 SG ?? UPDATE [Re: Chi_Town_Runner] #287219
04/13/09 06:58 PM
04/13/09 06:58 PM
Upper Midwest
Upper Midwest
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: Removal of Thrust Buttons in 8.75 SG ?? UPDATE [Re: MoparforLife] #287220
04/13/09 07:50 PM
04/13/09 07:50 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Frank,
Glad you are on the right track, I think my thumb still hurts from 2001 when I was trying to get the buttons out of a cone type differential..
Re: Removal of Thrust Buttons in 8.75 SG ?? [Re: DoctorDiff] #287221
04/13/09 10:25 PM
04/13/09 10:25 PM
IL
71383beep Offline
71383beep  Offline
IL
I can verify this. I just got my axles in yesterday and have the clutch type SG w/ the stock axles and green bearings. The thrust button is still in the SG. After some other issues i got her together just fine.
'73 GK6 Challenger Rallye - 340 4-Speed
Re: Removal of Thrust Buttons in 8.75 SG ?? [Re: 71383beep] #287222
04/13/09 10:40 PM
04/13/09 10:40 PM
Hey 71383bee,
It was your initial post that caused me to look at my thrust buttons. I had not yet stabbed in the pumkin yet but I figured I would shortstop any poss prob.
Glad you got your issue resolved.
DrDiff is da man.
Frank
