62 dart window tool #287034
04/13/09 11:29 AM
04/13/09 11:29 AM
gtx69 Offline OP
super gas
gtx69  Offline OP
super gas
Who sells the tool to remove the window handle on 62 dart?Can't seem to locate one
Re: 62 dart window tool [Re: gtx69] #287035
04/15/09 10:22 AM
04/15/09 10:22 AM
greenfield, ind.
P
PLMCRZY Offline
PLMCRZY  Offline
P
greenfield, ind.
if it is the little horseshoe type clip (like gm uses) any one that sells body shop tools should have it. even most local auto parts stores. local napa has it. dennis
Re: 62 dart window tool [Re: PLMCRZY] #287036
04/15/09 02:06 PM
04/15/09 02:06 PM
gtx69 Offline OP
super gas
gtx69  Offline OP
super gas
No horseshoe clips different
Re: 62 dart window tool [Re: gtx69] #287037
04/15/09 04:14 PM
04/15/09 04:14 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The '62 Dart handle has a built-in spring clip, locate the steel spring and push it sideways to release. There is a dedicated tool but I've never needed it, a screwdriver blade works for me.
Re: 62 dart window tool [Re: John_Kunkel] #287038
04/15/09 07:13 PM
04/15/09 07:13 PM
gtx69 Offline OP
super gas
gtx69  Offline OP
super gas
Finally found something that will work.The garden tool you use for pulling weeds with the forked tip.
