Latest on brake rotors #2869114
01/04/21 10:12 PM
01/04/21 10:12 PM
A727Tflite Online content OP
A727Tflite  Online Content OP
Any suggestions on currently available brake rotors - what to use and what to avoid?
71 B Body if it matters.
Re: Latest on brake rotors [Re: A727Tflite] #2869220
01/05/21 09:45 AM
01/05/21 09:45 AM
VA
dragon slayer Offline
VA
It does matter. The 70-72 B And E rotors are available. I have the Centrix versions from Rock Auto for the stock KH set up. These are solid versions. If you need the 2 piece unit for a show/points car, that has to be a used set. I do have a nice used pair if that is what your after. For a driver the centrix have worked very well for me and others I have seen post. Fit correct and come with the bearing seat installed.
