Re: 438 stroker build
[Re: Theorio1025]
#2866775
12/30/20 11:09 PM
12/30/20 11:09 PM
Posts: 43,303 Bend,OR USA
Cab_Burge
Does your crank still have the Mopar rod journal sizes on it? If so think about having it reground to BB Chevy 2.200 rod journal size and have the crank grinder offset stroke it as much as they can get and then buy a new set of BB Chevy type long rods like 7.100 I beam or H beam rods with 7/16 rod bolts with the standard .990 writs pin sizes. You will need a set of pistons made for this build so it will be a custom built street motor that will outrun every non stroker 440 powered car out there Loose the RPM intake as most EFI system don't like dual plane intakes Contact the EFI system maker first before doing anything on this part of your build If you decide to have the 440 crank offset ground to 3.90 and have the block bored .030 over to 4.280 bore size that will make your motor have 448.9 C.I., if it needs to be bored to 4.310, .060 over stock bore size, that will make it be 455.2 C.I. I had one 400 block pump gas motor that was like your wanting now, stock stroke 440 crank cut down with stock 440 rods, that needed to be bored to 4.375 and it made 480 HP on CA pump swill back in 2002 with w single B.G. 850 CFM Speed demon carb mounted on a Mopar M1 single plane intake low deck intake. It had a set of mildly ported big valve 906 heads, not as good as your Eddy RPM heads with a pretty small Comp Cams hydraulic lifter cam and 1.5 set of Isky ductile iron adjustable rocker arms. On your deal I would look at using a cam like the Comp Cams high energy hi lift series with either the XE-285HL grind or the bigger (due to the 4 speed ) XE-295HL grind, buy a good set of adjustable 1.6 ratio rocker arms also Don't tell any of your buddy, especially the Chevy and Ford guys, what your stock 383 motor has in it other than a mild cam and lifter set up That combination will make well over 500 HP on a good brand engine dyno with a decent tune IHTHs
[Re: Theorio1025]
#2867111
12/31/20 06:42 PM
12/31/20 06:42 PM
Posts: 494 IL
EchoSixMike
IL
I just dyno'd a 406(400 at 4.375 bore), with lightly rubbed on steel 452 heads(240cfm at .500), Erson E419115 hydraulic roller cam using solid lifters lashed .008/.010, Isky ductile rockers, PAC beehive springs (I had like 135 on the seat and 380 open and it worked fine), a Performer(not RPM) intake and Holley vacuum secondary 750 out of the box. Icon pistons and 6.800 Compstar rods, it has 8.9:1 compression, it'll run on a rumor of octane. Stock distro with a Pertronix II. Milodon pickup truck pan.
It made 435HP and 440lbs of torque. It had 18 inches of vacuum. It peaked at 6000rpm. Crappy dyno headers I got for free from some dude on C-L when I bought a crank from him.
My opinion, worth what you are paying for it, and considering you are trying to save money. Use the Eagle rods if the guy doesn't seem like a parts breaking schmuck and they're under 250 bucks. Get the ARP2000 rod bolts if they don't have them, since you're going to have to get them sized anyways. Use the ICON IC689 piston in whatever bore size your block finishes at, talk to your machinist. These are available considerably under 600 bucks.
I would stay away from all the machine work trying to get a few more cubes or custom this and that and save the money and put it on a "basic, economy" roller camshaft. Flat tappets are just such a C/F these days. You'll pour money trying to band-aid the things together and at the end of the day you've got a flat tappet. If you use the same Erson PN I did, you will easily have the numbers you are looking for. Another very good option, are the Lunati Voodoo roller packages, very reasonable for what you get. The smallest or 2nd smallest Voodoo roller would be my choice. I would suggest the Mancini/HS roller rocker package, that's a very good deal. Use the Torker with your EFI kit, clean up the runners, match the ports with the gaskets so you don't have giant mismatches, but don't go crazy. S/F...Ken M
[Re: Theorio1025]
#2867619
01/01/21 03:30 PM
01/01/21 03:30 PM
Posts: 2,815 Sobieski Wi
bee1971
Sobieski Wi
My #s 383/432 Stroker 440 Source Kit Built it myself - Only the second motor that I have built so was a learning experience I run the E Street 75cc Heads and Comp XE 275 HL 10.5 Compression - 195 psi cold cranking on all eight 18 initial - 34 total on 93 Octane with 10% Ethanol Auto - 3:91 Rear I love the torque on the street - Just getting into the throttle at 25/35 mph is scary with 275/60 series tires out back Idles at 700 RPM s all day long with 13" of vacuum Never mind the wrong dipstick bouncing https://www.youtube.com/watch?v=gjFG6l_Whh8
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
