This FCG Episode was on last night
#2861283
12/17/20 01:07 PM
12/17/20 01:07 PM
Posts: 16,160 Mesa, Arizona
dart4forte
Mesa, Arizona
One of the better episodes of Full Custom Garage. Guess the owner, Tommy traded it for a fat fender Ford
Abe Lincoln
Re: This FCG Episode was on last night
[Re: dart4forte]
#2861579
12/18/20 12:21 AM
12/18/20 12:21 AM
Posts: 10,750 North Dakota
6PakBee
North Dakota
I'd like to see some of his work in person. It just seems that he's really haphazard in how he does things. I remember I saw the DeLorean from the Back to the Future movies and that is a great 20 footer but up close it was crude. I just wonder how his work looks up close.
[Re: topside]
#2861940
12/18/20 08:41 PM
12/18/20 08:41 PM
Posts: 10,625 Freeport IL USA
poorboy
Freeport IL USA
The truck looks broken or bent at the firewall. It goes uphill towards the back, and it goes up hill towards the grille. It happens a lot, but that one shows up pretty dramatically. Its probably a fun ride and drives great, it just doesn't look right to me, but I suppose that is my problem, not his.
As far as crude, all my junk is crude, you don't have to look at it if you don't want to. Often times, a bit crude is a lot more fun, you don't have to worry about getting a paint chip. Gene
[Re: poorboy]
#2864653
12/25/20 03:48 PM
12/25/20 03:48 PM
Posts: 4,792 Star Idaho
67vertman
Star Idaho
It does look bent! Could be an optical illusion. I like the look of the truck, and would drive the Wheels off it.
My Monster are real!
Living within your means makes life pretty easy.
[Re: 67vertman]
#2864671
12/25/20 04:29 PM
12/25/20 04:29 PM
poorboy
Freeport IL USA
The "bent look" is probably caused by the way the body and box are set on the frame. Its very likely the frame is perfectly straight, but the body and box have a nose down mounting, and he failed to keep the grille and radiator height on the same plain,. The radiator height is probably 2" - 3" too high. Its easy to make that mistake, especially if you can't get far enough away from it when the body is set on the frame, or if you get in a hurry when its time to install the radiator. The fix could be as easy as lowering the radiator, or it could be a lot more complex.
I see it happen often, and it seldom gets fixed by the original builder. Sometimes the next owner fixes it, and the truck takes on an entirely different appearance. Some people like the look, and that is OK as well, its their ride. I'd have to fix it if it was mine. Gene
