Hughes Rockers on Indy 360-1??
#2856995
12/08/20 11:26 AM
12/08/20 11:26 AM
Posts: 1,015 Down South
DaKuda
Down South
Any of you guys that have ran the Hughes rockers made for the Indy 360 - 1 or 2 heads? What were your experiences with them? Using with a solid roller.
I'm in the market if any of you guys have a set for these heads available also. Hughes, T&D, or Harland.
Re: Hughes Rockers on Indy 360-1??
[Re: DaKuda]
#2857496
12/09/20 08:25 AM
12/09/20 08:25 AM
Posts: 1,927 Seaford, Va
Kindafast
Seaford, Va
I have a set on my 360-1 heads now. Superior quality and work great. I had a set of the junk crap made by Indy and broke one just driving normal around the block. I looked at all the other jobbers that sell rockers. Called Hughes and asked about them. Spoke with Dave " I believe that's his name " and he went over how they are made and told me if one breaks from any factory defect to send it back. No time line . He said he 100% stands behind the quality of his parts. So far so good. I have a stroker engine that I spin to 6700 with a mild 6.50 lift roller cam and they stay adjusted pretty good and no problems at all. Just my 2 cents
6.50 @105.26
[Re: justinp61]
#2857554
12/09/20 11:14 AM
12/09/20 11:14 AM
Posts: 4,991 new jersey usa
11secdart
new jersey usa
I have ran my 360-1 heads and rocker set up for a few years now with no problems but I am always worried about the rockers , my 408 combo is kind of mild, 600 lift mechanical cam and I shift at 6500. Its good to know there is another source for rockers should I have a problem.
[Re: 11secdart]
#2857728
12/09/20 05:20 PM
12/09/20 05:20 PM
Kindafast
Seaford, Va
The Indy Rockers are extruded Aluminum. I didn't know that until I did a little research. The same company that makes the TD Rockers makes them for Hughes so they say. I didn't get the Cryo treated rockers and I don't know the spring pressure but Larry Smith put the new springs on the heads and said they would handle just about any cam I wanted to put in. I don't know about longevity of the rockers but I do like the way Hughes does business.
6.50 @105.26
