Re: Finally Got Chassis working, What do you think?
[Re: StrokerPost]
#285520
04/12/09 12:33 AM
04/12/09 12:33 AM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
Awesome! Are you gonna take it to Norwalk this year for the street assassin class?
[Re: StrokerPost]
#285523
04/12/09 12:45 AM
04/12/09 12:45 AM
Posts: 437 south central pa
bdaz smblk
south central pa
HOLY CANOLY!!! Yeah, shes workin. Lets hear about the motor and driveline.
It's a 440" small block with w-8 heads and a sheet metal ram with two 1050 dominator's and 4.56 gears and only leaving off the two step at 3,600 when it has a 6,400 converter in it.Thanks Kenny
3120lb, small block, 10.5" tire, NA, through exhaust, full int, WITH 83/4 REAR, 9.0 at 150mph
[Re: webemopes]
#285528
04/12/09 12:50 PM
04/12/09 12:50 PM
Posts: 636 Central,Ohio
FASTFISH420
Central,Ohio
Congrats Guys!!! Looks like the PRC carbs worked??
1969 Barracuda 8 second all/motor small block
2014 Shelby GT500 Mustang
Uratchko Racing Engines
www.URE-RACING.com
[Re: webemopes]
#285530
04/12/09 01:48 PM
04/12/09 01:48 PM
FASTFISH420
Central,Ohio
I know 2 carbs can be a pain in the butt at times..tell him to put a good cast manifold,and one big carb on it and let it eat.. 2 carbs are a tuning nightmare.. I told Kenny to come over to the Classic in Columbus next month and we can have some match races..That will most likely be my first time out with mine this year..would be alot of fun..
www.URE-RACING.com
[Re: RodStRace]
#285532
04/12/09 07:02 PM
04/12/09 07:02 PM
Posts: 16,928 NC
440Jim
NC
[Re: bdaz smblk]
#285533
04/12/09 07:20 PM
04/12/09 07:20 PM
ProSport
Akron, Ohio
I would love to race on a good track like Norwalk plus be with all you mopar lovers out that way.Kenny
The street assassin class is gonna be a weekly type race, must have 10.5 tires and stock frame rails. The frame rail rule leaves me out. Let us know if you come out to one of these events. Your car is incredible. My old tunnel ram with 2 QF carbs was one of the easiest setups I've ever tuned, but I wasn't tilting the car back like you on the launch. LOL
[Re: webemopes]
#285535
04/12/09 10:45 PM
04/12/09 10:45 PM
Posts: 1,340 Pennsylvania
proshiftcharger
Pennsylvania
Took flight last night. Now I need to get the bars on the car and see what she's got. BTW, it's a NA small block on a 10.5x29.5" tire stock frame rail car.
Happy Easter
Yeah looks like you got it working right. What track did you go to??
[Re: bdaz smblk]
#285537
04/13/09 08:16 AM
04/13/09 08:16 AM
Posts: 13,376 Marion, South Carolina [><]
an8sec70cuda
Awesome!! That thing's screaming!! Beautiful car too. CHIP
[Re: an8sec70cuda]
#285538
04/13/09 10:06 AM
04/13/09 10:06 AM
bdaz smblk
south central pa
Thanks for the kind words.I hope I can work on getting it to go in the 8's now.Thanks Kenny
[Re: webemopes]
#285541
04/13/09 09:53 PM
04/13/09 09:53 PM
Posts: 2,813 Blue Ridge, VA
Plumb Wired
Blue Ridge, VA
Looks good! Mike Gray
RIP Monte Smith
aka: OutlawFish '98 Bickel Dodge Dakota PST
[Re: Stroker Scamp]
#285543
04/14/09 01:24 PM
04/14/09 01:24 PM
bdaz smblk
south central pa
Happy Easter
i think that for a n/a small block thats got to be one of the quickest one on here, great job, love the car!
Thanks for the kind words.I've been a 9.03 and has gone 150m.p.h with a single four cast intake but I think it will go in the 8's now with the sheet metal ram.I hope anyhow.Kenny
[Re: webemopes]
#285545
04/14/09 01:38 PM
04/14/09 01:38 PM
Posts: 5,337 the house on the left.
cogen80
Happy Easter
awesome pic.
[Re: Plumb Wired]
#285548
04/14/09 05:39 PM
04/14/09 05:39 PM
Posts: 4,689 On the parachute mount
n20mstr
that is a BAAAAD Small Block! ! ! WOW that is working for sure, tame that wheelie and you are IN the 8's
....BAD A$$ STREET CAR.....
[Re: 64ssmax]
#285551
04/14/09 05:55 PM
04/14/09 05:55 PM
Posts: 268 South Central Pa
webemopes
South Central Pa
carbs were pro-systems.brand new and car would flutter and carry on for the first 150 ft or so then take off like it was run into by a freight train.that was even remotely trying to hook.if it would spin it wouldn`t miss a beat.single four worked fine but would spin when you tried to use the transbrake.we were always fighting one thing or the other.now suspension is working so we can concentrate on tuning susp back a little.sent the carbs to prc and he said they were a mess.this was on new carbs that we had been fighting with for about 15 passes or so.two passes later on the carbs and they have been responding the way they should.send badazsmblk ,or mopar to ya ,or me the dates for those races and we`ll see what happens.
Jake68's brother had the same problem with prosystems carbs. His were brand new two. Except he messed with them for 2 years before he tried another set.
Yea I'm not real happy with prosystems.I had $2,400 in them and it took another $1,500 to make them right.But atleast it's fixed now thanks to Steve Taylor at prc carbs.Kenny
[Re: HEMIDARTS]
#285554
04/14/09 08:44 PM
04/14/09 08:44 PM
bdaz smblk
south central pa
Thanks for all the kind words from all of you guy's.And Tony I hope your right I been trying for that 8 for a while now.I'm putting front end limiters on as we speak.If that doesen't work I put a nice set of chrome moly bars on it.Thanks again Kenny
[Re: Plumb Wired]
#285555
04/14/09 08:53 PM
04/14/09 08:53 PM
bdaz smblk
south central pa
Looks good!
Mike Gray
That front end has taken a beating under your dart and mine now and still works great.
Kenny, I was going to ask if you were still running the same front end. Glad to see that is still working well, it has been "battle tested" that's for sure!
Is it a CFE headed combo now? Were the W9's you had raised ports or std.? I they were RP's what kind of difference to the W8's?
One last question, LOL are you still using the Ultralink rear suspension?
Mike Gray
Hey Mike it's a cfe top end now.I think they make alot more power then the w-9's and they were the std port heads.And as for the rear suspension it is still the ultralink and I love it.The car don't twist all up because the bottom bar acts like a anti-roll bar.Kenny
[Re: bdaz smblk]
#285558
04/14/09 10:30 PM
04/14/09 10:30 PM
n20mstr
What shocks do you have up front?? You really need double adj to control the suspension from bottoming out on landings, it WILL improve you 330 an 1/8 mile. It made a big difference on my car.
I just have the strange single adj coil overs.Kenny
DOuble adj will really help out a lot, if you watch a video frame by frame, especially from the side like your pic, you will see that as the car lands and the front bottoms out, the rear tire will spin two or three revolutions. Not a lot, but if you get a good double adj on there you can stiffen up the compressions to keep the front control arms from bottoming on the bumpers and upsetting the weight dist. I have Afcos, If you talk to mike at MR2, he will tell you the Afcos are not that good, lol THe shocks are expensive but worth it. Also what T bars you have?? the 318 ones are a little better to run in your case as you may not need all the stored energy of a thinner bar. Also dont forget that raising the car 1" or so up front can stiffen the bars a little and take some of the stored energy out. Just count the turns on the bolt, maybe 3 turns? Good luck on getting that 8
[Re: n20mstr]
#285559
04/14/09 10:57 PM
04/14/09 10:57 PM
bdaz smblk
south central pa
I don't have t bars it's a coil over frontend but I think I can take alittle bit of travel out of it . It has like 5" of travel right now.I'll just take out 1/4" to 1/2" travel at a time or just get a good set of double adjustable coil overs or wheelie bars.
[Re: bdaz smblk]
#285560
04/14/09 11:06 PM
04/14/09 11:06 PM
n20mstr
ok, you got coil overs, they are cheap, get some extras that are different rates and try them thats all. Taking away stored energy and travel as well as controlling the landing will help a lot
[Re: n20mstr]
#285561
04/14/09 11:16 PM
04/14/09 11:16 PM
n20mstr
be careful with the bars, getting on them too hard will put the car into tire shake, Well at least that happens to me becasue i run radials. You want the car to come up, just touch the bars and then come back down, all the while moving forward rather than up. You need to keep them somewhat high because a small tire needs a lot of transfer ( at least my opinion) Youll get it, it just takes some testing to find what the car likes
[Re: n20mstr]
#285562
04/16/09 09:56 AM
04/16/09 09:56 AM
bdaz smblk
south central pa
Thanks for your help Tony.Will see what happens the next time out.Kenny
