Page 3 of 3 1 2 3
Re: Bronze Gear Wear [Re: dthemi] #2853786
12/01/20 01:39 PM
12/01/20 01:39 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
The timing chain cover can have a big impact on a roller cam cam movement - The cam button can cause significant deflection in the factory cover letting the cam walk forward. Making a spacer and welding or epoxy it in place to go between the cover and the water pump is a cheap solution.
I also thing the quality of the bronze gear has gone down over the past ten years - its become a piece to be changed out on a regular schedule now
Re: Bronze Gear Wear [Re: DoubleD] #2853797
12/01/20 02:23 PM
12/01/20 02:23 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
McMaster carr has the hardened torrington washer. I remove material from the intermediate gear thrust surface equal to the washer thickness. A bronze gear running on a bronze bushing wears fast, leading to gear elevation change, leading to ground up gears.
A very cheap and simple way of avoiding these problems.
Re: Bronze Gear Wear [Re: TRENDZ] #2853930
12/01/20 06:21 PM
12/01/20 06:21 PM
missouri,usa
cryplydog Offline
cryplydog  Offline
missouri,usa
Sorry guys, that even confused me when I reread the post. Yes Cab, I have awlays used the best parts for my cars etc, top brands only and I like certain brands over others. I guess what I was trying to convey to others is very simply that these gears are needed to run 90* from each and on Center. Oh yeah, Mopar BB only for me but I have worked many other brands for high performance reasons.
Page 3 of 3 1 2 3
