Re: Trans brake reverse .
[Re: wyoming]
#2847321
11/16/20 10:51 PM
11/16/20 10:51 PM
Posts: 11,722 Portage,michigan
B3422W5
Portage,michigan
I think the OP is asking this.... he pushes the button and the car backs up, but there is drag on it while backing up. Think he wants that answered
[Re: B3422W5]
#2847331
11/16/20 11:18 PM
11/16/20 11:18 PM
Posts: 20,188 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Am I missing something? Why would he hit the transbrake button with a 727 in reverse???
[Re: pittsburghracer]
#2847340
11/16/20 11:29 PM
11/16/20 11:29 PM
B3422W5
Portage,michigan
He is talking about backing the car up. I am confident the guy races enough to know how to use a brake. It drags when backing up with it
[Re: B3422W5]
#2847345
11/16/20 11:38 PM
11/16/20 11:38 PM
Posts: 4,689 On the parachute mount
n20mstr
Call A&A and ask them how the brake is supposed to be used?? My Rossler trans you dont need the brake , you put it in reverse and it backs up. I know some brakes you use the button, but i thought they were with the shifter in R. Best bet... call the manufacturer and ask
....BAD A$$ STREET CAR.....
[Re: B3422W5]
#2847346
11/16/20 11:40 PM
11/16/20 11:40 PM
Posts: 20,188 PA.
pittsburghracer
"Little"John
"Little"John
PA.
He is talking about backing the car up. I am confident the guy races enough to know how to use a brake. It drags when backing up with it Do that on a powerglide and you will instantly come to an unexpected stop. Ask me how I know. That is unless it’s a “Pro brake” and then you have to push the transbrake button and hold it to back up. I’m sure if you look into and read up on 727’s hitting the button in reverse isn’t the best thing to do.
#2847369
11/17/20 01:27 AM
11/17/20 01:27 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
Many of the "Pro" 727 Transbrake require the driver to push the button on the transbrake for the car to back up.....
some allow this to happen while the shifter is in neutral or reverse.....my Tranzact will back up in either neutral or reverse with the button pressed....il
His complaint is ....the trans seem to drag while backing up in reverse.....
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
#2847382
11/17/20 04:16 AM
11/17/20 04:16 AM
Posts: 43,244 Bend,OR USA
Cab_Burge
To make it back up, the ones I've had needed that like the Powerglides do in my current S/P car
[Re: 70AARcuda]
#2847425
11/17/20 10:10 AM
11/17/20 10:10 AM
Posts: 20,188 PA.
pittsburghracer
"Little"John
"Little"John
PA.
His complaint is ....the trans seem to drag while backing up in reverse..... Well then like many posts on Moparts we have to guess whether he has a pro transbrake or not. My CRT 727 is older and I pushing the transmission brake button to back up was required.
[Re: B3422W5]
#2847490
11/17/20 11:39 AM
11/17/20 11:39 AM
Posts: 4,072 Mo.
racerx
Mo.
I think the OP is asking this.... he pushes the button and the car backs up, but there is drag on it while backing up. Think he wants that answered Yes that is it........last year before i put it up for winter everything was fine ,car haven't been out til the lasts part of the season this year and i discover this issue.
[Re: racerx]
#2847607
11/17/20 01:55 PM
11/17/20 01:55 PM
Posts: 20,195 Park Forest, IL
slantzilla
Park Forest, IL
I think the OP is asking this.... he pushes the button and the car backs up, but there is drag on it while backing up. Think he wants that answered Yes that is it........last year before i put it up for winter everything was fine ,car haven't been out til the lasts part of the season this year and i discover this issue. Can you push the car backwards with no drag when it's not running?
[Re: slantzilla]
#2847763
11/17/20 06:30 PM
11/17/20 06:30 PM
Posts: 4,072 Mo.
racerx
Mo.
I think the OP is asking this.... he pushes the button and the car backs up, but there is drag on it while backing up. Think he wants that answered Yes that is it........last year before i put it up for winter everything was fine ,car haven't been out til the lasts part of the season this year and i discover this issue. Can you push the car backwards with no drag when it's not running? Haven't tried that yet ,i no it goes forward easy i pushes it though the staging lanes myself. It's back on the trailer in the garage now.....
