Re: Early "B" guys, which oil pan for big block?
[Re: nd65]
#735625
06/28/10 03:44 PM
06/28/10 03:44 PM
Posts: 25,858 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Other than the original the 187 is about the only factory pan that will fit the BB early B. You'll have to fabricate your own 1/2" pickup for it.
A Max Wedge pan would be ideal for your situation but try to find one.
[Re: nd65]
#735627
06/28/10 05:31 PM
06/28/10 05:31 PM
Posts: 43,219 Bend,OR USA
Cab_Burge
The 1966 to 1969 street hemi pans fit fine in the early B body with the B and RB motors mounted on stock wedge K members with stock mounts Hemi shoulbd mount in the same place due to the trans crossmembers being the same BTW, I stock the Mopar OEM 1/2 oil pick ups for both the early and late B&E body Street Hemi motors with the stock oil pans.The late model 1970-71 street hemi and 440 6 pak pans won't fit in the pre 1966 B body K members with stock mounts
[Re: gtx69]
#735629
06/28/10 08:22 PM
06/28/10 08:22 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Be careful, the 66-69 K frame is diff than the early K frames. You see the K member is diff moving the engine forward 1 1/2-2" compared to the later 66 up K-frames. If it were my car, I would clearance the are needed with a carbide Burr and epoxy, or Mig weld up hole. Im pretty sure stock-ish style oil pans will fit with a clearanced K-member in the lip area. Look at Mancini Racing web site for pans and pics. I run the SS style pan with the drag link through the pan. My engine was/is at stock location. I located a Milodon pan that worked like a charm. If you have a truck pan, or 4x4 pan like the Milodon pan I would just use it.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
Re: 383man
[Re: lewtot184]
#735635
06/29/10 12:00 PM
06/29/10 12:00 PM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
Ron I run the 66 up Moroso 8 qt in my 65 also.Fit perfect.I just took a tiny piece out of the right K because it cleared but was close.I could have gotten by but liked the extra 1/4 I gained.My pan has been on for 12 years street and never came close to hitting even on Ohios bad roads.I used to run a 67 pan when I first had the 440 in.Ran that for over 25 years.Rocky
Chrysler Firepower
[Re: nd65]
#735638
06/30/10 03:19 PM
06/30/10 03:19 PM
Posts: 78 Parkville,MD.
bigjohn65
Parkville,MD.
have the mopar pan on b block, need to file little spot on k-member.
John
[Re: nd65]
#2848473
11/19/20 06:23 AM
11/19/20 06:23 AM
Posts: 348 Isle of Sheeps
Gtxxjon
Isle of Sheeps
Hi moparts,
Will the 6 quart 70/71 hemi pan fit in my 69 charger as the 402 pan is only 5 quarts ?
Many thanx from jon
Carpe diem, quam minimum credula postero, thanx Horace!
There’s no point trying to fix stuff that ain’t broke,,, 'but if ain’t broke',,, you is not trying hard enough...
[Re: Gtxxjon]
#2848732
11/19/20 04:17 PM
11/19/20 04:17 PM
Cab_Burge
Hi moparts,
Many thanx from jon Yes sir it does Those stock 440 6 pack and street hemi 1970/71 6 quart pans fit in B bodies from 1966 to 1971 that I know of
