does AndyF make a indy HEMI crossram linkage kit? #284684
04/11/09 01:54 PM
04/11/09 01:54 PM
Nazareth,Pa.
JACKSON Offline OP
JACKSON  Offline OP
Nazareth,Pa.
i know AndyF makes a throttle linkage kit for the indy 440-25 crossram and throttle bracket but does he make one for the indy hemi crossram intake with offset carbs?
maybe Andy will chime in.
im not a fabricator and need a kit for throttle and carb linkage.thanks
Re: does AndyF make a indy HEMI crossram linkage kit? [Re: JACKSON] #284685
04/11/09 03:29 PM
04/11/09 03:29 PM
AndyF Offline
AndyF  Offline
I make one for the Mopar cross ram when using 1850 carbs. Not sure if the spacing is the same for other cross ram intakes or not.
Re: does AndyF make a indy HEMI crossram linkage kit? [Re: AndyF] #284686
04/11/09 06:48 PM
04/11/09 06:48 PM
Nazareth,Pa.
JACKSON Offline OP
JACKSON  Offline OP
Nazareth,Pa.
ANDY looking or the indy version i dontthink the bolt pattern is the same as on the 440-25 setup, i suck as a fabricator, anyway you could find out thanks. i just bought a hemi intake from indy with the 1" offset and need a linkage setup and throttle bracket. thanks
