Page 3 of 8 1 2 3 4 5 6 7 8
Re: Anyone Interested In W5 Mopar Heads Please Read [Re: B3422W5] #28450
07/19/06 05:44 PM
07/19/06 05:44 PM
State College, PA
RyanJ Offline OP
moparts member
RyanJ  Offline OP
moparts member
State College, PA
i like the x mainly because its production looking up top,and racy down low...plus roller lifters pop right in it... plus i am old and like old stuff lol
The R1A does not have the filled in valley like an R3. Here's a pic of one. They do have the meaty lifter bosses though and the 18 bolt head provision. It would be real nice if the 59* version could get an 18 bolt delete, so you did'nt have to deal with the bosses for rollers. So if you wanted an 18 bolt block it would be 48* only.
That is what I'd make, 2 different versions:
59* 340 main, 4 bolt, with 360 oil pan provision (so you can either bolt on a stock 360 style pan, OR if you already have a 340 style pan, you can use a pan rail spacer which are now available for sale) 9.610" rough deck height, so you don't have to deal with 9.560" deck BS with off shelf crank/rod/piston combos that are all designed for 9.600" deck height. 3.91" rough bore. This block would be for 10 bolt heads only, no extra bosses. I would plunge cut the lifter bosses to Std. LA height, so any V link bar roller lifter should drop right in with little or no clearaning. Standard 59* cam tunnel of course.
48* 340 main, 4 bolt, 360 oil pan #5 cap, 9.610" rough deck, 3.91" rough bore. This block would have all 18 bolt head bosses drilled/tapped from Chrysler. Any 48* Mopar or Chevy spacing .903 roller lifter would fit with no mods. The 48's should already have an .125" oil feed hole in the lifter bore like the new AC Part # R3 blocks, so you don't have to buy/use the cheesy MP 48* lifter bore drill tool. Standard 48 degree babbit cam tunnel, and should come with a new set of 48* babbit bearings in the crate with the engine like the R3's do, so you can avoid panic like Kammer & Kammer had when they did Rick's 48* R1A and the 59* cam bearings did'nt fit LOL
Re: Anyone Interested In W5 Mopar Heads Please Read [Re: 340RICK] #28451
07/19/06 05:54 PM
07/19/06 05:54 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
the question on the 48* blocks???
The answer is easy, they fit like a champ after Ryan elongated the pushrod slot because I have a 48* R block with my W5's on it. This is great cause you never no when you might want to throw some W9's on.
Because you always want to go faster
Here in lies the core problem. P5007065ab cnc chamber W9's can be had for under $1,000 for the pair, need about the same finish work, and yes, they need some $$ headers, but cheaper than TTI's? That being said, I could see a pair for a low buck valve train, low conversion labor deal.
Re: Anyone Interested In W5 Mopar Heads Please Read [Re: Leigh] #28452
07/19/06 06:10 PM
07/19/06 06:10 PM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
I think the a new version of the W5 head would sell like crazy, you can count me in for a set!
Re: Anyone Interested In W5 Mopar Heads Please Read [Re: 340_Dart] #28453
07/19/06 06:19 PM
07/19/06 06:19 PM
FastOne Offline
FastOne  Offline
oh yes please, I want a block also
Re: Anyone Interested In W5 Mopar Heads Please Read [Re: FastOne] #28454
07/19/06 10:00 PM
07/19/06 10:00 PM
johnal Offline
super street
johnal  Offline
super street
was thinking the other day of a set of heads for a back up to my battens and would buy a set of w5s if they made them again.so make some and wacth them sell.
Re: Anyone Interested In W5 Mopar Heads Please Read [Re: ram87] #28455
07/19/06 10:43 PM
07/19/06 10:43 PM
Muncie
Racebuddy Offline
Racebuddy  Offline
Muncie
I have the W-5 heads off of Ross Hartleys' old super gas arrow. one of them is broken completely in two. this car ran 8.60's with a factory 340 block.
I need one good head to try and match up all the extensive port work.
Indy says they may be able to weld it back together for $1000 bucks but with no guarentee.
I would really like to have a new set of W-5's
Re: Anyone Interested In W5 Mopar Heads Please Read [Re: Racebuddy] #28456
07/19/06 11:13 PM
07/19/06 11:13 PM
FastOne Offline
FastOne  Offline
if this idea was to go ahead what sort of time frame are we looking at here, a year?
Re: Anyone Interested In W5 Mopar Heads Please Read [Re: Racebuddy] #28457
07/19/06 11:13 PM
07/19/06 11:13 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline
with the new casting technology..
the "Foam filled casting core" type
the quality of the casting has gone way up.
no core shift..
seems to me this method would fix most of the core shift and poor casting issues...
i dont know how that figures into the old tooling core boxes /parts that are apearently still around..and being refer'd to in this thread
but since youd need the licensing from Mopar to make any of these parts.....they need to do something..
on the w5 heads if they just offerd a head with out pushrod holes machined you could do it either way 48*/52*...no?
cheapst.
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: Anyone Interested In W5 Mopar Heads Please Read [Re: cheapstreetdustr] #28458
07/20/06 12:02 AM
07/20/06 12:02 AM
San Antonio,TX
440W8 Duster Offline
San Antonio,TX
no core shift..
cheapst.
I believe that is the way Pro Filer makes their castings.Basically a casting that is ported.
70 Duster W8 motor.
1.29 60ft 5.79 1/8 at 120 mph
glide with 1.80 gear
@3170 lbs.
Re: Anyone Interested In W5 Mopar Heads Please Read [Re: 440W8 Duster] #28459
07/20/06 01:40 AM
07/20/06 01:40 AM
SoCal
Brian Hafliger Offline
SoCal
Hmmmm...casting an R1 block with X markings...why not cast XXX just for fun
Re: Anyone Interested In W5 Mopar Heads Please Read [Re: AndyF] #28460
07/20/06 07:17 AM
07/20/06 07:17 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
Those blocks would sell like crazy.
Ryan- if the R1A block tooling is based on production tooling, does it have provisions for the '85-up 318 and '89-up 360 roller lifter parts (dogbones and spider)? that would be the cats meow, and make it real cheap and easy to run a hydraulic roller in a good block...
2017 Grand Cherokee Overland
Re: Anyone Interested In W5 Mopar Heads Please Read [Re: patrick] #28461
07/20/06 06:34 PM
07/20/06 06:34 PM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
I have been looking for an R1 block for awhile now to put together a spare motor. I have a complete rotating assembly waiting to drop in one. If I could buy a new one for 1200 I would be set.
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: Anyone Interested In W5 Mopar Heads Please Read [Re: patrick] #28462
07/20/06 09:49 PM
07/20/06 09:49 PM
Pacifica, CA
Devilbrad Offline
Devilbrad  Offline
Pacifica, CA
Or better yet, the motor mount bosses for the late model Magnum motors like the R3's have?? Count me in on W5's and an R1A block (if it has the Magnum mount bosses, hehe)! My 318 is almost done, so time to start piecing together the stroker turbo motor for Dakota.
Re: Anyone Interested In W5 Mopar Heads Please Read [Re: Devilbrad] #28463
07/21/06 05:03 AM
07/21/06 05:03 AM
mass,usa
sickhemi Offline
sickhemi  Offline
mass,usa
if they do make the heads and the blocks they must be available(in stock ready to ship). i have been waiting 9 months for a 340 block if dart made one i would have had one already. if i had to wait 9 months for heads i would get indy's. I love the fact mopar performance makes speed parts but they are usually made of unobtanium. they need to understand. if the part is at the warehouse and won't take months to get we will buy them!!!!! i probably have more mopar performance parts on my car and in my basement than mopar has at their warehouses.I'm not bashing them i just wish they had the parts in the catalogue at the warehouses so i could buy them!!!
Re: Anyone Interested In W5 Mopar Heads Please Read [Re: RyanJ] #28464
07/21/06 07:12 PM
07/21/06 07:12 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
For me it is not really a cost factor that bothers me all that much. I mean Mopar stuff is always more expensive to buy. What get my Goat is the fact that you pay good money for something and is is basically junk!! You buy a resto block and can't even bore it past 4.00 before hitting the water jacket!!!!! then they give you a hard time returning it. Or you but a set of brand new heads and the leak from everywhere??? So what I'm trying to say is produce the stuff but make sure the quality is there or count me out!!!! Better yet produce a excellent core, something without core shift and let someone else do the machining. I think Barton does this !!! Matt
Re: Anyone Interested In W5 Mopar Heads Please Read [Re: MattW] #28465
07/23/06 02:42 PM
07/23/06 02:42 PM
PA
W5DART66 Offline
W5DART66  Offline
PA
Well I will put this back to the top.They are thinking about doing this so if you want to put links to other mopar sites or tell any one now is the time. Thanx Brett Miller.
Re: Anyone Interested In W5 Mopar Heads Please Read [Re: sickhemi] #28466
07/23/06 04:47 PM
07/23/06 04:47 PM
SE MI
Duster499 Offline
Duster499  Offline
SE MI
I heard from a Chrysler source that they list some parts in their catalog that don't even exist. They are just trying to determine if there is a market for them. What better way to P.O. your customers?!
Re: Anyone Interested In W5 Mopar Heads Please Read [Re: Duster499] #28467
07/23/06 07:17 PM
07/23/06 07:17 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
My old Arrington heads used W2-W5 exhaust patterns. In fact the subplates from my W2's were a perfect match. Seems to me these heads were perfect for strokers as I ran them at 48 degrees with nitrous. I would have liked 18 head bolts but this gets into rule issues in some classes. 48 degree stuff gets into rule issues in some classes also. Seems to me that W5 heads with the intake runners raised on up, the rocker pad raised longer valves. And come up with a new intake that would fit the "NEW W5" as well as W7-9 combos. I know I am asking a lot as the likelehood of a return of the W5 is probably slim. But, why not make it better. It's sad when bowtie boys can get complete race heads for less than $1K. And we are expected to invest $2K for something that is not as good. Mopar gave us a better starting point raised cam wide pan rails tall decks everthing wanted by brand X guys to make strokers we already have made in the blocks. If the repo blocks had been made like advertised they would have been perfect for these kind of builds. One problem I run into is when at SEMA or PRI I get rediculous answers to why MP done something that basically screwed the sportsman racer. I am reaching into a more hardcore market but take the alluminum block for instance it is a nightmare and cost the customer double to complete than the other brands. And when you ask that question the reply is well if we had it to do over again we would have done this. Not only did they redesign it but they raised the price and still did not give us what we wanted. I have a set of W8 heads that are at CFE and it is going to cost a fortune to repair. If they were chevies I could purchase them done for half the money. Everytime I think I have found a new casting for sale advertised drag race heads they turn out to be circle track stuff. I think any W5 offering would be a great opportunity but in my experience with MP it will never happen.
Re: Anyone Interested In W5 Mopar Heads Please Read [Re: Duster499] #28468
07/25/06 07:09 AM
07/25/06 07:09 AM
mass,usa
sickhemi Offline
sickhemi  Offline
mass,usa
i was beginning to think he 340 blocks didn't exist since i have been waiting 8 months!! attn David Haikim we need w5 heads and 340 blocks!!!
Re: Anyone Interested In W5 Mopar Heads Please Read [Re: RyanJ] #28469
08/19/06 12:07 AM
08/19/06 12:07 AM
Fort Wayne, IN
moparatheart Offline
Fort Wayne, IN
Ryan, I know of the perfect Foundry!! It does have the state of the art machining capabilities also!! Also they are capable of large quantities being put out daily!!! From start to finish and my husband is the plant super there!! Let's get MP guys to visit them how do we do that?
Jackie
