New Tremec TKX Trans fits Mopars #2845443
11/12/20 04:49 PM
11/12/20 04:49 PM
usa
challenger17 Offline OP
usa
americanpowertrain.com/the-all-new-tremec-tkx-is-here
Re: New Tremec TKX Trans fits Mopars [Re: challenger17] #2845447
11/12/20 04:57 PM
11/12/20 04:57 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Boffin Emeritus
Re: New Tremec TKX Trans fits Mopars [Re: polyspheric] #2845640
11/13/20 09:59 AM
11/13/20 09:59 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Nice to hear this. I plan on putting a manual trans in my Barracuda once i'm done experimenting with the car and no longer go to the track. Whats the price on these for A body?
Re: New Tremec TKX Trans fits Mopars [Re: mopar dave] #2845700
11/13/20 12:20 PM
11/13/20 12:20 PM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
It appears there are no Mopar applications available yet. Looks to be around $2800.
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: New Tremec TKX Trans fits Mopars [Re: OhioMopar] #2845705
11/13/20 12:42 PM
11/13/20 12:42 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
In the questions someone asked if it would fit their 68 Dart and the answer was yes they had a kit for that.
Re: New Tremec TKX Trans fits Mopars [Re: 340Cuda] #2845928
11/13/20 10:17 PM
11/13/20 10:17 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Something that bolts in would be nice.
Re: New Tremec TKX Trans fits Mopars [Re: 340Cuda] #2845946
11/13/20 10:59 PM
11/13/20 10:59 PM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
Silversport says the length and mounts are the same, so it's a direct replacement for their TKO kits. You just don't have to cut the transmission tunnel, but I think I read the top of the torsion bar crossmember/brace, needs to be clearanced. I couldn't find the details on that. I thought they machined the TKO so you don't have to do that, but this new design requires it? That doesn't sound right.
Re: New Tremec TKX Trans fits Mopars [Re: OhioMopar] #2845971
11/14/20 12:31 AM
11/14/20 12:31 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
But then all the hidden costs start to mount up , driveshaft, clutch, TO bearing, pilot bearing , crossmember , mount, shifter handle, not sure if it will work with your stock bellhousing. Most of these conversions need everything but a new flywheel. You could easily be into this "bolt in" transmission for $4000 if you are frugal and get some good deals on parts.
So yeah $2800 sounds like a good deal but be prepared for the hidden costs.
Gus beer
64 Plymouth Savoy
Dana 60
