904 trans fittings? #284414
04/11/09 08:26 AM
04/11/09 08:26 AM
in front of the computer
8
80arrow Offline OP
80arrow  Offline OP
I tried to do a search but I didn't find an answer, so are the tranny lines 1/4 npt where they go into the tranny? Thanks, Clint
Re: 904 trans fittings? [Re: 80arrow] #284415
04/11/09 08:41 AM
04/11/09 08:41 AM
moparx Offline
moparx  Offline
1/8 npt threads in the trans case.
Re: 904 trans fittings? [Re: 80arrow] #284416
04/11/09 08:41 AM
04/11/09 08:41 AM
scratchnfotraction Offline
I think they are 1/8
1/8 pipe thred to 5/16 flare
Re: 904 trans fittings? [Re: 80arrow] #284417
04/11/09 08:54 AM
04/11/09 08:54 AM
8
80arrow Offline OP
80arrow  Offline OP
thanks alot guys, Clint
Re: 904 trans fittings? [Re: 80arrow] #284418
04/11/09 09:29 AM
04/11/09 09:29 AM
off topic but this made me think of something that I'd been wondering about & that is if the fluid passages inside the trans are larger than the std size fittings/line if it would be beneficial to tap the case for larger fittings & use a larger line to get more volume in/out. With different vehicles I am regularly smelling slightly burnt fluid even w a large cooler.
Re: 904 trans fittings? [Re: 80arrow] #284419
04/11/09 08:34 PM
04/11/09 08:34 PM
Taneytown, MD
bigslant6fan Offline
Taneytown, MD
In the late 80s they were changed to 1/4npt and 3/8 lines to be compatible with the OD trans.
