Page 44 of 47 1 2 42 43 44 45 46 47
Re: 1969 Barracuda M code [Re: davesmopars] #2710934
10/29/19 02:05 PM
10/29/19 02:05 PM
ma.
duspan Offline
duspan  Offline
ma.
a good friend of mine had one, thought he could out run the cops with it.... but it cost him dearly,,,, the car was way more than he could handle!!!!!!
Re: 1969 Barracuda M code [Re: davesmopars] #2711282
10/30/19 02:58 PM
10/30/19 02:58 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Originally Posted by davesmopars
I am handling the 1969 Barracuda M Code Registry for now. I have all the info now formally Dave Goodwin and Tom Wenstadt
Any car or info let me know
Thanks Dave
Dave do you have a website and a link or did I miss that?
Thanks MikeR
(#8 M-Code Dart GTS on the GTS registry)
Re: 1969 Barracuda M code [Re: A12] #2711332
10/30/19 05:51 PM
10/30/19 05:51 PM
cheshire, ct
davesmopars Offline
davesmopars  Offline
cheshire, ct
Thanks Dave
Thanks MikeR
Mike,
I have been working on getting one.
Keeper of the 440 M code Cuda registry
mcodecuda@yahoo.com
Re: 1969 Barracuda M code [Re: blewbyu] #2711504
10/31/19 07:42 AM
10/31/19 07:42 AM
Nashville, Tennessee
Tempest Offline
Tempest  Offline
Originally Posted by blewbyu
Here is a pic of my 340 "CUDA
Love the retro look of your car!
Re: 1969 Barracuda M code [Re: Rhinodart] #2838036
10/27/20 04:00 PM
10/27/20 04:00 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Just thought I'd bring this back around because:
Jim I pulled the M-Code Dart out of storage and hoping to do a few things over the winter to get it (maybe luck ) on the track sometime next year. Lots of undoing the inner fender well header cut outs (have original sheet metal for both sides) and the transmission and console floor tunnel for when it was converted to a 4-speed. Has the original 3.91 rear and have two of most everything to chose from. Still thinking it looks more like F5 than F8 but no big deal it's still going to stay GREEN.....with a black interior (original). Undecided about the black vinyl but will probably stay and even though it's a "stripe delete" I always wanted a black tail stripe so that may go on............and still leave the front fender GTS callouts.
Here's what I have for a K-frame, what do you think? Does it look like an M-Code (big block) original K-frame........................and then there's that F5/F8 green paint confused
Mike
Re: 1969 Barracuda M code [Re: A12] #2838155
10/27/20 10:29 PM
10/27/20 10:29 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Here is the k-frame in my 69 GTS. Looks F5 to me...
JB Rhinehart, Realist
A-Body's RULE!
Re: 1969 Barracuda M code [Re: A12] #2838163
10/27/20 10:46 PM
10/27/20 10:46 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
My car is F5 body color with F8 upper and lower door frames. This photo shows original factory paint F8 lower door frame at right. In the center of the photo, F5 and F8 are next to each other, showing that the factory first painted the whole car and door F5 then masked around the door frames, then painted the door frames F8.
Re: 1969 Barracuda M code [Re: kentj340] #2838167
10/27/20 11:11 PM
10/27/20 11:11 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Originally Posted by kentj340
My car is F5 body color with F8 upper and lower door frames. ........
the other way around - Upper Door Frame (visible area inside of door weatherstrip) in F8 lacquer, allow to dry, tape that area off & paint entire car in F5 enamel up
Re: 1969 Barracuda M code [Re: davesmopars] #2838172
10/27/20 11:32 PM
10/27/20 11:32 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
1969 M code Numbers matching needs a lot of work
You need a fan shroud. M-codes came with solid black grills not painted. If you have painted one they where replaced at sometime
Re: 1969 Barracuda M code [Re: A12] #2848423
11/19/20 12:08 AM
11/19/20 12:08 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
When the "50 Fastest Muscle Car" list was done years ago how did they pick the cars that made it on that list and where did the M-Code Cuda and Dart end up....................did they even make the list, don't remember. I know the A12 RR was third at the time and IMO really a true 5/6 passenger muscle car with more than just two seats like aluminum skinned and fiberglass body sports cars in position 1 & 2 rolleyes The 5 passenger Dart and Cuda M-Codes should have been on there. Thought it was from back in the day magazine tests? Just trying to bump this up again wink
Mike
Re: 1969 Barracuda M code [Re: A12] #2848535
11/19/20 10:33 AM
11/19/20 10:33 AM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
M-Code Dart GTS was number 10, that's all I care about... grin
A-Body's RULE!
Re: 1969 Barracuda M code [Re: Rhinodart] #2848593
11/19/20 12:18 PM
11/19/20 12:18 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Was the criteria for making the list "back in the day" magazine road test articles??
If so then from the "50 Fastest" list I've seen and the June 1969 Drag Racing Magazine test the Dart GTS 440 M-Code should be listed as the SECOND fastest and FIRST QUICKEST real 4/5 passenger MUSCLE CAR of that era !
Check it out Jim E/T 12.70 @ 112 MPH boogie boogie
Mike
Re: 1969 Barracuda M code [Re: A12] #2848870
11/19/20 11:21 PM
11/19/20 11:21 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Here's another one from that article and has anyone ever heard this about the K-frame being "relocated" in the M-Code Dart and I guess Cuda? The way I read it is the K-frame was not modified but relocated in the engine compartment. Does that mean bolted in a slightly different position to the chassis? I also think there is little or no room to move the K-frame left or right but only forward or rearward where it is bolted but that would upset the entire driveline even if it was an inch or less, but would that matter? Don't think this is a true statement but.......................what's that "never say never" thing........... wink
scope is that a washer under the air cleaner wing nut....... wink panic laugh2
Re: 1969 Barracuda M code [Re: A12] #2848876
11/19/20 11:44 PM
11/19/20 11:44 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
This is first time I have ever heard of a "k-frame relocation", who is the author of this article? I have helped restore a few factory 440 Darts both 68 and 69 and the factory 383 k-frame had no changes that I could tell... shruggy
A-Body's RULE!
Re: 1969 Barracuda M code [Re: Rhinodart] #2848880
11/20/20 12:01 AM
11/20/20 12:01 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Quote
Dodge funny car driver Charlie Allen who states in the article that he also shoehorned a 440 into his own '68 Dodge Dart. Maybe he had to relocate the K-frame to do his 440 install and just assumed that's what Chrysler had to do? shruggy
Yeah that's right GREEN F8 GREEN boogie boogie
Re: 1969 Barracuda M code [Re: A12] #2848995
11/20/20 11:31 AM
11/20/20 11:31 AM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
What I would give for one of his funny car body's! Reed Koeppe had a 67 Dart funny car body about 10 years ago and I was too late to buy it. No idea if it was one of Charlie Allen's cars, but at that point I didn't care, I just wanted it! Who knows what he did to his, maybe he tried to set it back for better weight transfer? shruggy
A-Body's RULE!
Re: 1969 Barracuda M code [Re: Rhinodart] #2849007
11/20/20 11:54 AM
11/20/20 11:54 AM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
The former Charlie Allen Challenger funnycar body was on Ebay maybe 2 or 3 years ago.
Re: 1969 Barracuda M code [Re: A12] #2849032
11/20/20 12:33 PM
11/20/20 12:33 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Meaning the mounts were moved or made to accommodate the 383-440 engine big block. Never saw any difference on the car I had or the extra 69 383k-frame I still have. I’ll check the sb frame I to see if the pass side mount is the same, maybe both were moved.
Re: 1969 Barracuda M code [Re: cudaman1969] #2852334
11/27/20 09:07 PM
11/27/20 09:07 PM
northeast ohio
hulmule Offline
hulmule  Offline
northeast ohio
Owned a 69Dart GTS 383 4 speed car. Hated the light green color... They dropped the ball IMO on making a rally dash for Darts , at least GTS cars. Like the look of Cuda rally and wish M codes were a stick car. Would like to build a 69 Dart GTS clone. 440 -4 speed, rally gauges from a 70 swinger. maybe a couple other mods.
1969 Dodge Coronet R/T Convertible
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: 1969 Barracuda M code [Re: A12] #2905890
04/03/21 04:54 PM
04/03/21 04:54 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
And YES IT'S A GREEN M-CODE CUDA up
