Re: 2013 5.7 some questions
[Re: moparcyco]
#2834164
10/18/20 10:45 AM
10/18/20 10:45 AM
Posts: 1,397 Toronto Ontario, Can
Glen440
If you want to put a blower on it, I would plan for that now and put rods and pistons in it. It can live at low boost with the ring gaps opened up but the pistons will fail if you try to run 15-20 psi. Really don't know what a safe boost is maybe 10 psi.
I'm sure a power steering pump off an eagle car engine will fit. The mds will need to be deleted with lifters and plugs. They make cams for the vvt engines so you can use either one. Eagle heads on early engines have alot of compression.
I have not used megasquirt, I had nowhere to put the computer as it can't get wet. I use Holley Terminator X, The X Max can do drive by wire throttle.
87 dakota 6.1 hemi
[Re: moparcyco]
#2838111
10/27/20 08:27 PM
10/27/20 08:27 PM
Glen440
Looking into it, it seems there is a changeup in pulley offset at some point. Likely best to make a spacer.
87 dakota 6.1 hemi
[Re: Glen440]
#2839228
10/30/20 11:30 AM
10/30/20 11:30 AM
Posts: 58 Wi
Scat
Wi
Looking into it, it seems there is a changeup in pulley offset at some point. Likely best to make a spacer. Found this out on my delma. 2009 to 2012 VVT timing covers and balancers are shorter then the 2013 and up VVT stuff.
73 Duster 340 a518 6pack
[Re: Scat]
#2839496
10/30/20 10:32 PM
10/30/20 10:32 PM
Posts: 2,255 IL
furious70
IL
Looking into it, it seems there is a changeup in pulley offset at some point. Likely best to make a spacer. Found this out on my delma. 2009 to 2012 VVT timing covers and balancers are shorter then the 2013 and up VVT stuff. Is that just for car/jeep or for Ram as well?
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: furious70]
#2839542
10/31/20 01:33 AM
10/31/20 01:33 AM
Posts: 58 Wi
Scat
Wi
Car is all I know of since I ran a car timing cover.
