Re: Got a new project
[Re: moparmarks]
#2856872
12/07/20 11:43 PM
12/07/20 11:43 PM
Posts: 16,147 Mesa, Arizona
dart4forte
Mesa, Arizona
Have this parts truck that luckily had a 360 in it so I pulled that motor and tranny cause I needed the 360 torque converter and a few other parts. I went ahead and stripped it and another 75 down so I have a pile of parts to use. Sway bar?
Abe Lincoln
[Re: moparmarks]
#2856993
12/08/20 11:25 AM
12/08/20 11:25 AM
dart4forte
Mesa, Arizona
Sorry that is the one I'm using on mime. Oh well, had to ask
Abe Lincoln
[Re: dart4forte]
#2857013
12/08/20 12:12 PM
12/08/20 12:12 PM
Posts: 10,721 North Dakota
6PakBee
North Dakota
In all your stuff would you happen to have the three pieces for the cab beltline chrome? My '72 W200 could use it. Looks like this.
[Re: moparmarks]
#2857362
12/08/20 10:01 PM
12/08/20 10:01 PM
6PakBee
North Dakota
I appreciate it. Thanks again.
[Re: 6PakBee]
#2858635
12/11/20 05:38 PM
12/11/20 05:38 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
Got the 360 installed today. Seems to run good. Radiator started leaking and need to get exhaust on it. Also the tranny dip stick is in the way of the headers so need to do a little relocation there.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
Re: Got a new project ,So
[Re: moparmarks]
#2970119
10/03/21 10:35 PM
10/03/21 10:35 PM
moparmarks
I did it. I lower it to where I want it. I didn't slam it to the ground. I still want to use it as a truck. I installed an 8.75 3.55SG with 11"x2.5" brakes and did an axle flip. I built a set of leaf springs and use that to set the rear height. In the front I cut a coil. I also added a front sway bar. I still need to go through the front end but for the most part I'm done with the chassis work. It corners and handles much better. Is fun to drive.
[Re: moparmarks]
#2970121
10/03/21 10:40 PM
10/03/21 10:40 PM
moparmarks
I don't know what others have done but I had to move the shock cross member forward to line up with the car shock plates. No biggie. Before and after shots. Sorry Jim and Don but she is my rig. You guys probably wouldn't like how loud it is either.
[Re: moparmarks]
#2970123
10/03/21 10:48 PM
10/03/21 10:48 PM
moparmarks
I also installed some Ramcharger buckets that I had in another truck. Had some new Autometer gauges and a stereo on the shelf so threw them in too. Oh and changed form manual to power steering. Really needed that.
[Re: moparmarks]
#2970199
10/04/21 08:20 AM
10/04/21 08:20 AM
Guitar Jones
[Re: basketcase]
#2971275
10/06/21 10:35 AM
10/06/21 10:35 AM
moparmarks
Okay so this truck I lifted 4" so it all balanced out in the end.
[Re: moparmarks]
#2972409
10/09/21 02:09 PM
10/09/21 02:09 PM
Posts: 570 USA
Hooligan
USA
Sweet Mopar! Good luck with it! Should be fun fixing 'er up!
