Re: Engine run in stand [Re: cudaman1969] #2833909
10/17/20 03:18 PM
10/17/20 03:18 PM
moparx Offline
moparx  Offline
Originally Posted by cudaman1969
The old addage on running it hard off the showroom floor proved true.
without the standard FT cam break in ? shruggy
beer
Re: Engine run in stand [Re: moparx] #2833926
10/17/20 04:06 PM
10/17/20 04:06 PM
Washington
hemienvy Offline
hemienvy  Offline
Washington
Seems like the requirements for ring seating are not the same as for cam break-in.
Re: Engine run in stand [Re: hemienvy] #2834049
10/17/20 09:38 PM
10/17/20 09:38 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I worked at my uncles Dodge dealership from 69 to 73 never once did a factory car come in with a wiped cam. I’m preety sure most all wiped cams are on used-rebuilt engines and most likely poor assembly. Knock on wood I’ve yet to wipe one even changing a cam to 3 different engines and put lifters where ever.
Re: Engine run in stand [Re: 440Jim] #2834489
10/19/20 09:03 AM
10/19/20 09:03 AM
an8sec70cuda Offline
Originally Posted by 440Jim
Originally Posted by an8sec70cuda
Uses an old cast iron 4 speed bellhousing and flywheel I had laying around. Standard motor mounts.
CHIP,
Do you have a picture of how you supported the rear of the bellhousing?
Jim, no, but I can get you a pic. The bellhousing just butts up to the flat face of the angle iron and I drilled the 4 holes for the transmission mount bolts. Just something to hold up the rear of the whole deal.
Like I said, mine is ugly and crude, but I have basically zero money in it and it works great. I got tired of retorquing heads in the car after a fresh build...that's what led me to build this thing. It's SOOOO much easier now. Nice for when I occasionally build an engine to sell or for someone else.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Engine run in stand [Re: JERICOGTX] #2834618
10/19/20 01:21 PM
10/19/20 01:21 PM
NC
440Jim Offline
440Jim  Offline
NC
I made these adjustable length "arms" to use on a run stand to support the side engine mounts on a variety of engines.
This material is 1/8" wall thickness, so the 3/4 square tube slides into the 1" square tube.
Trying to make this stand adjustable for many types of engines, Chevy, Mopar, etc.
